Old 06-02-2008, 08:23 PM   #1
GRIMSS
GRIMSS's Avatar
fillers for the wheels for my panel
Just got my fillers for my wheels that I'm going to us on my panel. terrellautosports laser cut them last week. Later this month i'm on vacation so hope to start welding them in.
_
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 06-02-2008, 10:03 PM   #2
BlueJeep
BlueJeep's Avatar
Re: fillers for the wheels for my panel
Wow, that looks like a lot of work!!!!
Hope you can chuck it up in a lathe and turn down the welds when you're done rather than having to grind all of those.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 06-02-2008, 10:40 PM   #3
GRIMSS
GRIMSS's Avatar
I like that idea. I'll have to look into that.
I'm sure once done someone will be making smooth 20's and I could have just bought them instead. That's how my luck is.
2001 GMC SIERRA
1968 Camaro
Jared
Old 06-04-2008, 05:03 PM   #4
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
They do I have them on my truck in 22"s.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 06-04-2008, 05:11 PM   #5
drunkbus
New Member
drunkbus's Avatar
I don't know if you will be able to get those balanced after all that welding.
drunkbus is offline   Reply With Quote
Old 06-04-2008, 06:33 PM   #6
GRIMSS
GRIMSS's Avatar
I've seen them. how much did the set cost ya?
2001 GMC SIERRA
1968 Camaro
Jared
Old 06-08-2008, 10:02 AM   #7
chevyrestoguy
chevyrestoguy's Avatar
I'm really anxious to see how this turns out. I love it when people use their ingenuity to make something look trick while still being "on the cheap". I see those wheels all the time, and never gave them a passing glance until now.
chevyrestoguy is offline   Reply With Quote
Old 06-08-2008, 11:35 AM   #8
GRIMSS
GRIMSS's Avatar
Yea, I can’t really afford to buy wheels that are over 2k then put tires on them. Just not in my priorities, plus those smooth billets just are not the look I’m wanting. Even if they were painted. I want a stock look with the cheap painted caps. My time is cheap and if it doesn’t work out I’m not out too much.
2001 GMC SIERRA
1968 Camaro
Jared
Old 07-01-2008, 09:19 PM   #9
GRIMSS
GRIMSS's Avatar
started today on a wheel. Was not too bad. here's pics.
1/2 way on one wheel.
2001 GMC SIERRA
1968 Camaro
Jared
Old 07-02-2008, 12:16 AM   #10
Kim57
Kim57's Avatar
Looking good.
Kim
Kim57 is offline   Reply With Quote
Old 07-02-2008, 12:42 AM   #11
Sinisterspeed
Sinisterspeed's Avatar
looks like lots of work. First one looks like it is turning out great. Are you going to mount it up and get it balanced before going through all that on all of them?
There are two kinds of people, those who finish what they start and so on.
70 GMC Longhorn (A.K.A Money Bucket)
57 Chev 3100
05 Chevy LLY Dmax.
67 Chevy Camaro
Dad's Budget Build 55
My Longhorn Build
Sinisterspeed is offline   Reply With Quote
Old 07-02-2008, 07:32 AM   #12
GRIMSS
GRIMSS's Avatar
I'm only planning on doing one to make sure it works then start on the others or purchase another wheel. We'll see what happens.
2001 GMC SIERRA
1968 Camaro
Jared
Old 07-02-2008, 02:19 PM   #13
mylow53
mylow53's Avatar
since these plugs aren't structural, and your painting them you might concider less welding. the more you weld the more you grind and the more chance of having a wheel that need lots of lead to balance. Don't forget those thick welds could warp your rim due to excessive heat...i'm no expert welder, so feel free to correct me.
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 07-02-2008, 02:44 PM   #14
GRIMSS
GRIMSS's Avatar
Well I have no idea what i'm doing so this wheel could be trashed. When i'm done with it i'm taking it to a friends tire shop to see where i'm at. If it's trashed i'll get another.
2001 GMC SIERRA
1968 Camaro
Jared
Old 07-02-2008, 03:23 PM   #15
BlueJeep
BlueJeep's Avatar
I'm also curious to see how you'll dress it up when you're done grinding. Maybe you could spread a thin layer of bondo on it and put it in your buddy's spin balancer and hold sandpaper as it's going around to get it smooth....
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
