Old 02-04-2011, 11:54 PM   #26
VA72C10
VA72C10
VA72C10's Avatar
Re: How to: Ruin a perfectly good C10
Love it! Ruined it good
Thanks for the interesting write-up and pictures. Now get back out there and ruin it some more
Old 02-04-2011, 11:57 PM   #27
72BlckButy
Tot Roddin'
72BlckButy's Avatar
What did you use to mount the bedsides to the raised bed floor?
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 02-05-2011, 01:39 AM   #28
gringoloco
A guy with a truck
gringoloco's Avatar
Haha- you're welcome! It's cooooold out there, hence the reason I'm in here
I did it the 'permanent' way.
With the bedsides removed, I cut the inner bedside floor mounting flanges off about 1.5" up from the bend, drilled holes through them at evenly spaced intervals, then plug welded them to the opposite bedside in the same position, just flipped 180*, and 3" higher than stock. I used the right side pieces on the left and vice-versa. Same process with the header panel. I also had to take 3" out of the rear stake pockets where they mount to the floor and moved the spot-welded 'L' brackets up.
This way, the floor stays whole and you still have all of the rear cross-sill mounting bolts securing the bedsides. I've seen where people cut the floor at the rear corners and leave the stake pockets intact, but I didn't like the idea of the bedsides flexing or bowing outwards causing tailgate alignment issues since these trucks tend to do that in a stock configuration, not to mention modified.
I still need to pull it apart again to finalize some things; when I do, I will try to remember to take some pictures. This is not for the faint of heart, as you are hacking up perfectly good bedsides, so you'd better be committed. Some think I should be committed
I think it looks stock enough that most don't catch it and I don't lose any noticeable capacity. Many ways to skin this cat, but I think 3" is a good height since the tubs come to just under the upper body line of the inner bedside; any more than this is doable, but would turn into a lot of sheetmetal work. I have hauled a ton of crap in this bed and it stands up to the abuse- no worries about using this truck as a truck- even with the raised floor...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-05-2011, 02:14 PM   #29
Slick67
Sofa King Crazy!!
Slick67's Avatar
That bed looks stock! Do we get to see a pic with the tailgate down also???? I enjoy watching you ruin stuff.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 02-05-2011, 10:08 PM   #30
gringoloco
A guy with a truck
gringoloco's Avatar
Wish I'd known you wanted one, I pulled the gate off today. There is a 3" step from the gate to the floor.
-Chris
Old 02-05-2011, 10:24 PM   #31
gringoloco
A guy with a truck
gringoloco's Avatar
Baby steps today...
Once I raised the bed floor, the wheel tubs would not sit flush against the inner bedsides since they are 3" above the stock cutout. There is a lip on the tubs that keeps them from fitting all the way to the bed.
After removing the tubs (what a pain, these fasteners rust quickly), I proceeded to remove the offending metal with my trusty angle grinder/cutoff wheel.
-Chris
Old 02-05-2011, 10:31 PM   #32
Orangetonicclicc
Orangetonicclicc's Avatar
I'm ruining a perfectly good one myself!!!!!! But I think I'm doing what should be done!!!!!! Plus it's mine!!!!!! I love the mods!!!!!! i'm glad you changed that bed back I must admit!!!!!!
Orangetonicclicc is offline   Reply With Quote
Old 02-05-2011, 10:33 PM   #33
gringoloco
A guy with a truck
gringoloco's Avatar
Also had to create a little notch where the body line was preventing the bottom of the tubs from sitting flush. Note the placement of the new mounting holes 3" higher than stock. They fit MUCH better now
My Blazer tank parts did not come in today as scheduled due to inclement weather...
-Chris
Old 02-05-2011, 11:31 PM   #34
VA72C10
VA72C10
VA72C10's Avatar
Nice work!
Old 02-05-2011, 11:44 PM   #35
SCOTI
SCOTI's Avatar
Hey, I like that bed lift idea. Seems like it worked well .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 02-05-2011, 11:53 PM   #36
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Awesome work, subscribing.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 02-07-2011, 08:44 PM   #37
RCbowtie69
RCbowtie69's Avatar
keep pictures coming
RCbowtie69 is offline   Reply With Quote
Old 02-08-2011, 11:08 AM   #38
67cheby
67cheby
67cheby's Avatar
Nice work
67cheby is offline   Reply With Quote
Old 02-13-2011, 03:17 PM   #39
dougminton
dougminton's Avatar
subscribed, keep on ruining it.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 02-13-2011, 09:16 PM   #40
Painter D
Painter D's Avatar
Just watching
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 02-13-2011, 10:12 PM   #41
Solego
Dr. Frankentruck's Monster
Solego's Avatar
You make it look so easy! I hate you!
I'm not prejudiced, I hate everyone.
Project SLOMO
http://67-72chevytrucks.com/vboard/s...d.php?t=430494
Solego is offline   Reply With Quote
Old 02-13-2011, 10:35 PM   #42
mooseknuckles
mooseknuckles's Avatar
awesome job on the rasied floor bed! .....thanks for not ruining it by putting that other box back on!!
mooseknuckles is offline   Reply With Quote
Old 02-13-2011, 11:01 PM   #43
trevrolet65
Great work! That raised bed looks factory.
trevrolet65 is offline   Reply With Quote
Old 02-14-2011, 03:35 AM   #44
franky69c10
chevy runs deep
franky69c10's Avatar
Nice work
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline   Reply With Quote
Old 02-14-2011, 03:54 PM   #45
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks to all who have posted- you guys keep me motivated It's hard sometimes to keep the vision- it occasionally just looks like a directionless pile of junk to me. I think if I could stay off these forums, I could maybe finish this little project- there are just too many great ideas floating around here. There has been ZERO physical progress since my last tiny update due to being out on business for a bit, but I plan to get back to it with a vengeance and make up for lost time ASAP, which leads to the next revelation...
Any of you following my '72 Blazer build know that I parted ways with it, not necessarily by choice, but for good reason. It was like pulling off a band-aid, you don't really want to, but you know you have to, so the wound will properly heal... Between that time and now, I have managed to piece my life back together and am stable and headed in a new direction, which gives me an opportunity to think about playing in the garage again Boosting this newfound(re-found?) interest is a recent conversation I had with my soon-to-be wife about the truck. She thinks that it will be cool to make the truck a part of the coming wedding celebration (how awesome is that?!) She would like to see it in a semi-completed state so we can have it on-site for photo ops and be used for hauling some of the props, decorations, etc and to be used as something for the guys to paint with shoe polish and hang cans off the bumper... She also knows that working on this old junk keeps me happy and relaxed, which is a good thing
The snag is, it can't just get painted and appear complete, it must be road-worthy, capable of some fairly long distance interstate travel while also being reliable and semi-comfortable. We are to be married in June, so that leaves a small window to get everything done in, and necessitates the installation of the Classic Auto Air kit I have sitting on a shelf... I have started putting together a punch list of items that need to be completed to make it happen. The hard part is finding the balance between what needs to be done and what I want to do, and without cutting corners. Luckily, I have most of the parts already and the required funds for completion are being added to the wedding budget , finding the time may prove to be the hard part.
Sorry for the long, drawn-out, lack-of-update post. I wanted to put this out there, so hopefully you guys can hold me accountable
...and yes, I am one lucky guy. I am very blessed to have found such a wonderful woman who wants to integrate the things I like into our life together. Another upside is that since the truck will now be 'a part of the family', she won't ever ask me to sell it
-Chris
Old 02-14-2011, 04:16 PM   #46
VA72C10
VA72C10
VA72C10's Avatar
I'll be here to remind you whever you are slacking!
Congrats on the upcoming marriage!!!!
Old 02-14-2011, 09:13 PM   #47
sourkraut
sourkraut's Avatar
nice build, will be watching
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 02-22-2011, 12:54 PM   #48
yukon ratrod
yukon ratrod's Avatar
very nice project! was going to build a daily driver, but somewhere got sucked in to going the full mile. keep up the progress.
yukon ratrod is offline   Reply With Quote
Old 03-01-2011, 12:58 AM   #49
gringoloco
A guy with a truck
gringoloco's Avatar
Managed a half a day off work today so I decided to spend some time rebuilding the front suspension. It was filthy from a trip to the metal scrap yard on a rainy day- I will NEVER make that mistake again. The majority of my time was spent cleaning and painting everything; if it wasn't so disgusting, the job would have gone much faster.
The first couple of pics show the state of the front end when I started. Also some pics of the carnage. The lower arms are actually the ones that were removed from my old Blazer when the DM went in. I used them on the truck after I 'accidentally' bent the right side doing a little off-roading. This truck has been neglected for entirely too long...
-Chris
Old 03-01-2011, 01:25 AM   #50
gringoloco
A guy with a truck
gringoloco's Avatar
Here's a few more of the progress, including a crappy cell phone pic of the truck on stands that I sent to my fiance when she asked what I was doing today
The 'new' parts were cleaned, painted with rust encapsulator and chassis black, and rebuilt today. The lowers are a set I picked up a while back which got new balljoints; the uppers are actually the same ones from the previous post that I removed earlier today, just cleaned, painted and with new Moog offset cross-shafts and balljoints. The 1.25" anti-sway bar, poly bushings, and ECE lowered mounts are more hand-me-downs from the Blazer that have been sitting on the shelf for a while.
The springs are new Moog 6102s that I picked up on Amazon for $40! I love me some free super saver shipping! They will be losing a full round tomorrow before installation Don't mind the rusty calipers, they will be getting the treatment tomorrow along with the spindles and rotors. Time to flip the lever on the ratchet the other way and start installing some of this stuff...
-Chris
