12-17-2010, 12:49 AM | #51 |
Re: '66 GMC BBW w/351E and Factory Buckets
I'd have to say leave it blue!! I got a chance to peek through some of your pics, definitely looks sweet!! And I'm glad to see another local GMC guy!
1966 GMC Extended cab 1 1/4 ton 4x4 My build thread 1958 Chevy 1 ton dually flatbed My Dad's build thread 1966 GMC Custom Trim Big Back Window W/351e My Time-Killing Project Truck 1966 (Not So) All Original Chevy Custom Trim Suburban My Dad's Time-Killing Project Truck |
12-17-2010, 12:56 AM | #52 |
Well we decided to rebuild the Rochester carb we had. Dropped it off to a friend of my fathers Monday and picked it up today. He told us that is was real rough inside, but he managed to get it all cleaned up for us! My girlfriend and I put it on this evening and buttoned it all up. (In the process of showing her how to work on real trucks because for some reason she likes f@rd)
So tomorrow should consist of replacing plugs, and seeing if she'll fire up if this snow doesn't interfere!! Posted via Mobile Device Posted via Mobile Device
12-17-2010, 12:57 AM | #53 |
I bought a 63 chevy grille for my GMC... I also have a chevy hood and tailgate, just becuase that was all i could find. I feel guilty now looking at your purebred GMC's guys
1982 K10 SWB 1987 V20 - Sold - Doh! |
12-20-2010, 12:47 AM | #54 |
It's ALIVE
I replaced the plugs and a bad part of rubber fuel line I missed the first time, primed the fuel lines, and after a few backfires through the carb we had her running, revving, and leaking exhaust! It's sounds mean... Yesterday I threw on new exhaust gaskets and plugged a random drilled hole in the exhaust manifold, fixed a hole in the rad. hose and found a few other little things that need replacing. Today I went back and noticed antifreeze around the thermostat housing so I picked up a new gasket and thermostat that I'll put on tomorrow and see if there is anything else I need
12-30-2010, 01:13 AM | #55 |
Replaced the radiator hoses, new battery, new cables, all new fluids and I have her running smooth. I got to the point where I was about to take it off the trailer and she wouldn't move. after 15 mins of being stumped, my grlfriend says "Did you put transmission fluid in it" Guess who's never living that one down...
The truck runs, drives, stops, and steers amazingly!!
1966 GMC Extended cab 1 1/4 ton 4x4 My build thread 1958 Chevy 1 ton dually flatbed My Dad's build thread 1966 GMC Custom Trim Big Back Window W/351e My Time-Killing Project Truck 1966 (Not So) All Original Chevy Custom Trim Suburban My Dad's Time-Killing Project Truck Last edited by oklahomaduner; 12-30-2010 at 03:20 AM. |
12-30-2010, 07:49 AM | #56 |
That is so nice. Truck sounds really good.
01-22-2011, 08:35 PM | #57 |
Well I have been tinkering with the truck for awhile, chasing parts, and cleaning it up. I was able to bring it home and drive it short distances. I picked up a buffing wheel and some compound to try buffing up the paint, it worked pretty good to give it a little gloss and it cleaned up the rust stains.
I've also spent some time looking at wheel/tire options to get it a little more road worthy. We have looked at a few different styles but we kept coming back to the rally's. So my dad managed to track down 2 with 6 rings and 4 caps. He got them cleaned up and painted. And we also stumbled across a set of 235/75-15
01-22-2011, 08:39 PM | #58 |
more pics
01-22-2011, 09:58 PM | #59 |
That's a good looking truck. Post a wide shot with the new wheels/tires.
01-22-2011, 09:59 PM | #60 |
That is looking real good!!
01-22-2011, 10:06 PM | #61 |
Thanks guys! Berean, I Haven't gotten the rear wheels yet but once I do I will definitely post up a pic!
01-23-2011, 12:27 AM | #62 | |
Thinking about dropping the front and back down a bit, but aren't sure if we want to go that direction.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
01-23-2011, 12:45 AM | #63 |
The first pic in my son's earlier post (#57) shows a 275/60r-15 that originally came on one of the two 15x8 rally's we found. We kinda liked that size (especially if we are dropping it a bit), but that tire was trash.
In our searching for "not new tires", we found a set of nearly new 235/75r-15 BFG all-terrains on CL for less than the cost of one new tire...while not our first choice, these were too nice of condition to pass up.
03-31-2011, 12:33 AM | #64 |
I've been slowly working through this truck... very slowly. I drove it around a couple days and it started starving for fuel real bad due to a clogged filter. So we decided to tear into it and pull the seat, carpet, and tank. While it was out I cleaned all the old gunk off the floor, got all the wiring in order so everything works now, and just cover the basics.
We had decided to replace the tank with a new one since ours was pretty bad. We bought the new tank and put it in only to find out that it wasnt the same... we had the 20.5 gallon tank from the factory. So we changed our minds and went back to the stock one. My father and I aren't too fond of coating the inside of it and seeing how this truck is on a tight budget we wanted to try cheap methods of cleaning it out... So after talking with an old-timer we got the idea to dump a couple gallons of orange juice into the tank and let it eat away at the rust. It actually worked decently, but not good enough. So next we used muriatic acid, which worked really well. So now the tank is back in and the interior is done for now until I can afford upholstery and carpet. On to the engine, we decided to convert it over to HEI using a 1978 Buick 231 distributor with the proper adapters, all the parts are sitting in the garage almost ready to drop in. (the dist. shaft needs a little mod) Also we have a two barrel holley 500 on its way in to help out a little more. We did finally manage to chase down 3 more rally's which I am in the process of painting. So the last big item on our mind is a new 6-lug rear end with 3.42's and she should be running good!
03-31-2011, 09:46 AM | #65 |
What a COOL build! I love to see success stories of old abandoned trucks being resurrected. There's lots of them out there capable of running, and in this economy, they can be had for a song. What I like about this truck is the fact that it's a GMC with lots of really cool, rare options. That's a very unique truck.
You and your Dad should be knighted for your great deeds in bringing old soldiers back to life!! Keep it up!!!!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
03-31-2011, 10:33 AM | #66 |
Great score!! You're gonna like those bucket seats. I had a '67 CST with those in it. I kinda regret getting rid of them.
Anyways, good luck with your build and congrats! Ray |
03-31-2011, 07:59 PM | #67 |
wow thats in greaat shape is that chrome grill orianal
03-31-2011, 08:22 PM | #68 |
Hollister, CA.
Father/Son team at its best !! Love the actions shot, and the GREAT score on an awesome truck !!
Good Job Man ... keep it coming !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
03-31-2011, 10:57 PM | #69 |
fan of "Butters" Stotch
Love the patina! Maybe fix the nasty spots (like the bottom of the one fender) but leave as is & enjoy!
64 shortbox fleetside replacing rusty junk with more junk, and one day to become a real truck again |
03-31-2011, 11:23 PM | #70 |
Very nice. If you still have the seats out can you please post up some pics of them?
Posted via Mobile Device |
04-01-2011, 10:26 AM | #71 |
Sweet ride! Good job in persuing this one.
Daniel 66 Chevy C10 LWBSupport our troops! |
04-04-2011, 01:53 PM | #72 |
Theres an original tu tone '66 GMC parts truck (no title) being sold on ebay #320680555803. Has the rare bucket seat option also. Looks like alot good parts. Anyone in Colorado?
04-05-2011, 12:41 AM | #73 |
Thanks for the encouragement. My boy and I are struggling with convincing Mom that this really is a cool truck and that all the leaks will eventually be fixed. We hope to have the carb and hei in within the next week or two and be able to use it while we tinker with it.
Joemomma1, I thought I had more pics of the seats out, but could only find these...
04-05-2011, 12:55 AM | #74 |
Thanks for the pics, thinking about using the style of those seats. I'm partial to a sort of stock appearance.
04-05-2011, 01:20 AM | #75 |
Junk Yartist
Way cool truck for your collection!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
