#51 | |
![]() Join Date: Aug 2010
Re: The 1960 - 1966 Chevrolet & GMC Pickups Factory Correct Restoration Thread
Black sealer/primer on hood, fenders, and box. Red oxide on cab and doors. Underside of hood is low gloss black. |
#52 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Do you think the black finish under the hood could be the same as on top of the hood? In other words, they simply primed the whole thing but painted the top?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#53 | |
1961 crewcab
I ran the vin, and it comes back as :63 3/4 ton 4wd cab chassis, from the st louis plant. I will look at the data plate next time I am out there and see if there is a paint code....
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#54 |
![]() Join Date: Jan 2011
Two Tone Paint on 60-61 GMC How does the two tone paint work on the firewall to the front of the cab. In other words, is the bottom color continued to the firewall up to the cowl and the white painted on the bolt on parts, fender cowls, vent cover(part that covers the vent and has the wiper drivers). I'm not sure I would be correct and I haven't seen the firewall's of factory two tone GMC's
1961 GMC. Start date 1/20/2011 Past projects: 1958 Fleetliner 14ft Runabout 1966 Caprice 2dr 1970 VW Squareback |
#55 |
I found this old truck today, I beleive it to be an original one owner truck... I thought the two tone on the door panels and dash might be helpful to someone. notice the chevrolet in script on the glovebox door
#56 |
Nice find, hard to believe that all of the knobs and the script are still in there! I am not 100% positive but I think that the script was only in 60..
Where the hell did my coffee cup go?!! ![]() |
#57 | |
#58 |
In my literature they define the color as Charcoal Black on the Dispatch Box. Is the color the same all over the dash and door inserts or is it two tone?
#59 |
One thing i noticed on both of my trucks and even on some at the junkyard is a light lime-green-yellowish color under the black inside the hood. dont think its a coinsidence, maybe a plant specific paint scheme. srry couldnt get a good pic of the color.
'66 chevy lwb c10 '65 chevy lwb c20 |
#60 |
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 10-22-2011 at 07:05 PM. |
#61 |
#62 |
I think I know what you are talking about. I'm guessing it's zinc chromate primer. For mid-year Corvettes, this yellow/green primer must be present in certain places in order to pass the rigorous inspection of their knowledgeable NCRS judges.
#63 |
#64 |
great info....subscribed
#65 |
#66 |
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 10-24-2011 at 02:27 PM. |
#67 |
there are some of those big truck mirrors on ebay right now. for 1965 prices too. I almost jumped on them. intill i realized how much of a pain they would be in a parking lot.
#68 |
![]() Join Date: Oct 2009
after scanning a good original and retouching it, i have got a open ended file that you can add your option list to. not sure about earlier trucks but 64-66 used this on the glove box door. pm me if you want this file...
after printing on thin card stock i stained with weak coffee and sprayed with matte finish clear... looked great |
#69 |
clemdaddy nice of you to share with everyone. The coffee stain thing is priceless!
#70 | |
![]() Join Date: Mar 2011
#71 |
have emptied my mailbox if interested in the glovebox file, please e-mail me so i can reply with the file. it is a photoshop file and i will send as a layered pdf.
you should be able to modify with your option list and vin #. thanks, clem clem@hogeye.com |
#72 |
Very nice! SPIDs started in 1966 though, so it's only correct for that one year.
#73 |
These came with my Grandpa's 1965 ... the first is a SPID or list of all options that came with the truck ( what ever they called it in 1965 ). The second is a sheet where it was gone over at the dealer ( all fluids and pressures checked ) before it was turned over to my Grandpa.
#74 |
heres another little detail thing i got together. scanned a decent aluminum gvw tag off the leftside kick panel and touched it up. then took it to a screenprinter who printed 6 up on sheet aluminum in a medium blue/grey color. i cut them out, stamped the right numbers in and drilled the rivet holes. had a pretty nice new looking tag.
not sure what years had this but i'll offer the artwork for any guys anal enough to do the same. clem@hogeye.com |
#75 |
That looks good! I used a slightly different process back when I made one for a '65 I restored.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 01-03-2013 at 07:57 PM. Reason: Fix dead pic links |
