1966 F100 Short/Fleet Full Stock Resto Build Thread
I posted a few build threads before and had someone ask for me to post our newest build here. Our shop started a full restoration of a '66 F100 back to stock specs about a month ago. It was originally light tan and white two-tone. It's pretty straight, complete, and rust-free apart from the outer edges of the floors and radiator support. It had a 302 added at some point but the owner still has the original 352 and three speed transmission, the engine has been rebuilt already.
![]() ![]() ![]() ![]() This a picture that the owner sent us. The bottom and top of the roof was light tan. ![]()
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
Re: 1966 F100 Short/Fleen Full Stock Resto Build Thread
Teardown pics.
Fiberglass patches in the floor and kick panel, not a good sign... ![]() Found the original masking lines under the trim and behind the bed. ![]() ![]() Front clip, bed, and doors removed. ![]() ![]() Engine/trans removal. ![]() ![]()
More teardown.
Cab stripped bare. ![]() ![]() Rust in the floors. ![]() ![]() ![]() Cab off, frame disassembled. ![]()
We had the frame sandblasted and I shot it with a few coats of PPG DPLF epoxy, let it sit over the weekend and lightly wetsanded it with 500 grit to knock down the orange peel and nib the dust/trash.
I sprayed the frame using PPG Omni MTK single stage urethane, flattened with 1/3rd PPG One Choice matting agent, and reduced 10%. Sprays very well and covered great since it was going over the black epoxy. Nibbing the Epoxy made the paint lay down much smoother- as you can see in the "wet paint" pics.
Straight out of the gun- ![]() ![]() ![]() Starting to flatten out. ![]()
That was looking pretty solid until the f/g came out. Nice and straight too...
Robert |
Tot Roddin'
Nice progress!
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#8 | |
![]() Thanks!
Got the cab and doors back from the blaster. There was more rust-thru than expected, and the passenger side door has some wrinkles right through the upper body line. I stripped out the seam sealer (it was too soft for the blaster to remove) and will be picking up a couple quarts of Ospho so it can sit in bare metal without flash rusting while we do the metalwork. All the metalwork and dent repair will be done before priming with epoxy. We will also re-blast the seams to fully clean them out before we shoot epoxy on it. I picked up a gallon of PPG DP74LF epoxy that is the same color as red oxide, which I believe was the original primer color.
The next step will be to repair the rust and fit the doors to the door openings. The bodylines will be matched up, the gaps will be evened out by welding 1/8" welding rods to the edges and grinding the gap even, and the doors will be reshaped to fit flush with the cab and fender. I make a feeler gauge the size that the gaps will be and grind the welding rod to fit the feeler gauge. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Here is how the doors fit before removal. It will require a bit of work to make them fit flush with even gaps and body lines.
Passenger side: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Driver's door fit.
This is a '65 C10 that I restored (my first paint/restoratioin job), this is what the gaps and panel alignment will look like after we rework them.
#13 |
I found pictures of this 15K mile original paint truck which has the same color scheme. It show the dash painted white, tan column/wheel and gas tank, and the masking lines in the rear door jamb.
#14 |
Cut out the rear floor rust to get inside the floor brace. We'll blast and prime inside the brace before welding the floor pans back in. We didn't cut the front floors out yet since the new pans aren't here yet- didn't want to cut too much.
![]() ![]() Blasted and primed the wheels and brake drums with PPG DPLF epoxy. ![]() ![]() Cleaned out the drums, had new races installed, and had them turned. ![]() ![]() Sandblasted the front suspension parts and pulled the bushings out. We are sending them out to have the king pins replaced and then we'll prime/paint them all separately. ![]()
#15 |
If anyone's interested, we have taken about 380 pics so far of the teardown. Most of it is just boring stuff for reference when we start reassembly but I know you guys are picture junkies!
Link to pics: http://apicdn.viglink.com/api/click?...-thread-3.html
#16 |
That's going to turn out great! Great work on the 65 too! Do you have an actual shop or is this something you do on the side at your home? If it's a shop I'd love to stop by some friday or so that I have off and check out your progress!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#17 | |
#18 |
The front drums are painted, cleaned, and bearings are packed and installed. I sprayed epoxy on the axle last night, then nibbed it and sprayed flattened single stage urethane on it after lunch today. I left the carrier in red oxide primer as the factory did. We're getting more of the pieces blasted so we can start reassembling the frame. I will get the rear brakes installed on the axle later today.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Picked up a bunch of parts yesterday at Early Ford V8 Sales in Easley SC. ![]()
#19 |
Had a hold-up with the brakes, it'll be Friday before Napa has the rear brake hardware (didn't order it all the first time)... I did get the lines and wheel cylinders installed. Anyone have a source for the vent bolts that hold the brake line distribution block?
![]() ![]() ![]() ![]() Drums ready to install. ![]()
#20 |
I'll definitely be tuned into this one!
#21 |
#22 |
This is all looking really nice! Keep up the good work.
![]() Chad
Success is not final, failure is not fatal: it is the courage to continue that counts. Winston Churchill DD 2000 Chevy Suburban 4x4/5.3 Vortec/4L60E/4:10s, 18" Escalade rims, Electric fans Project Dooley One-Ton 4x4 on 38.5s Corn-binder build |
#23 |
Thanks Chad!
Few more recent pics. Got the rear suspension parts blasted, epoxied with PPG DPLF, and painted. Those rear leaf and hanger bushings were a pain to remove! I'll shoot epoxy on the front suspension parts tomorrow. We bought a 110# soda blaster and a couple bags of soda (non abrasive) for blasting the 352. It was poorly repainted when it was rebuilt and we don't want to paint over the rattle can paint that's on it. We'll have single stage color matched so we can spray it with a hardened paint for better oil and gas resistance. Epoxy: ![]() Flattened single stage: ![]() ![]() ![]() ![]() The I-beams were blasted, then new king pins and bushings were installed. They're prepped with PPG DX series Metal Cleaner and Metal Conditioner and ready for epoxy. ![]() ![]() The manifolds were blasted and coated with Calyx manifold dressing. ![]() Posted via Mobile Device
#24 |
Great attention to detail as always.
81 GMC C15 RC SWB 5.3L 4L80E project ![]() |
#25 |
Thanks!
I picked up some "EZ-Slide" graphite based lubricant paint for the leaf springs, I found it at Tractor Supply. Should let the springs move easier so it rides better. Also picked up some model paint for the paint marking on the transmission. ![]() Lightly washed the trans to document the paint dabs. Yellow "6Y" ![]() Orange along the edge. ![]() This one showed faint traces of orange paint. ![]() Outlined to see it better. ![]() Another orange spot. ![]() ![]() Blue spot. ![]() Two yellow dabs. ![]() Another yellow spot. ![]()
Thread Tools | |
Display Modes | |
