Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Suspension > Suspension Marketplace
Old 02-03-2012, 08:53 PM   #1
robnolimit
robnolimit's Avatar
No Limit Spy Photos
Spy Photos
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 02-03-2012, 09:36 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: No Limit Spy Photos
New "NoLimit Member" jig?
Keith
Convert to disc brakes.
Old 02-03-2012, 10:40 PM   #3
SCOTI
SCOTI's Avatar
Very interesting.....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-03-2012, 10:55 PM   #4
lolife99
lolife99's Avatar
Kinda Chris Alston looking,... isn't it.
Keith
Old 02-10-2012, 06:50 PM   #5
robnolimit
robnolimit's Avatar
New Parts
Old 02-12-2012, 09:23 AM   #6
andrewmp6
You going to offer it coilover or air bags?
Old 02-12-2012, 02:17 PM   #7
robnolimit
robnolimit's Avatar
your choice, we'll have both.
Old 02-12-2012, 03:36 PM   #8
SCOTI
SCOTI's Avatar
How long before there's a product info/marketing release?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-13-2012, 01:31 PM   #9
robnolimit
robnolimit's Avatar
Hopefully in two weeks. - need to make sure there ready to go. Plus, No Limit dealers get first crack at a pre-release.
Old 02-25-2012, 09:34 AM   #10
duallyjams
duallyjams's Avatar
Any spy photos for the rear ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-26-2012, 08:32 PM   #11
Devillusion
Devillusion's Avatar
What gen is this for? 73-87?
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 02-26-2012, 08:39 PM   #12
robnolimit
robnolimit's Avatar
We are working on an updated version of our Wide-Ride 3 to fit as a bolt-in for 63-72, and 73-87
Old 02-26-2012, 08:40 PM   #13
Devillusion
probably a stupid question, but would this work on the old square body 1 tons? or is the frame a different setup on them compared to the 1/2's?
1970 Chevelle
Old 02-27-2012, 12:41 AM   #14
ItsRandy
ItsRandy's Avatar
Hey Rob, do you have any of the rear sway bars for '67 - '72 coil sprung chevy c10's like the one on JT yet?
ItsRandy is offline   Reply With Quote
Old 03-05-2012, 08:15 PM   #15
duallyjams
duallyjams's Avatar
Is the spy still on special assignment ?
James
IG duallyjams
Old 03-19-2012, 05:15 PM   #16
m6z
m6z's Avatar
any updates?
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 03-19-2012, 06:12 PM   #17
robnolimit
robnolimit's Avatar
The spy is wet sanding today. We are finalizing motor mount towers at this point. Complex forming is holding us up, have to make new forming dies.
Old 04-06-2012, 08:13 AM   #18
duallyjams
duallyjams's Avatar
update ?
James
IG duallyjams
Old 04-06-2012, 10:00 PM   #19
robnolimit
robnolimit's Avatar
Motor mount towers are done, and after a week, we're finally rested up from the Del Mar thrash. We are shooting an install this weekend, well saturday, I'll post up some on monday. Happy Easter.
Old 04-15-2012, 08:06 PM   #20
duallyjams
duallyjams's Avatar
tomorrow is Monday.
James
IG duallyjams
Old 04-17-2012, 03:28 PM   #21
BustedTruck
BustedTruck's Avatar
Will this work with the current rack & pinion set up you offer? Is there going to be control arms offered also?
BustedTruck is offline   Reply With Quote
Old 04-18-2012, 11:21 AM   #22
robnolimit
robnolimit's Avatar
This crossmember is on a bit of a different track than most. We are moving away from the C-10 components. This will be a new version of our Wide-Ride IFS, a complete IFS package including the crosmember, A-arms, coil-overs, shockwaves, or bags/shocks, spindles, brakes, power rack, and sway bar. The spindle is based on a late model Impala, with 12" drilled/slotted rotors, your choice of any 5 lug pattern, sorry, no 5 lugs yet. The track width is 63" hub to hub. Groung clearance on the crossmember is raised 2" over stock, and ride hieght, without a dropped spindle is a 4" to 5" drop from stock, and 2" drop spindles are avail. Motor mounts are included, and will fit SBC, BBC, and LS.
Old 04-18-2012, 12:22 PM   #23
PBFAB.COM
PBFAB.COM's Avatar
Looks good Rob!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 04-20-2012, 01:43 PM   #24
robnolimit
robnolimit's Avatar
Update
Old 04-20-2012, 07:22 PM   #25
duallyjams
duallyjams's Avatar
Is the Impala spindle taller them the c10 spindle ?
James
IG duallyjams
