Collector of Projects
Stock Manifold Options for LS Swaps
I have been thinking about Trailblazer SS manifolds. I did some searching and found part numbers. They are supposed fit almost any frame from 60's to 80's.
12600526 MANIFOLD. Engine Exhaust Manifold - LH. Required: 01LHD. 12600527 MANIFOLD. Engine Exhaust Manifold - RH. Required: 01RHD. LINK to data page. www.GMPartsDirect.com Left Side: $51.18 Right Side: $48.49 ![]() Please feel free to ADD PICTURES. I would like to see some installed on 67-72 4x4 trucks.... Last edited by usmcchevy; 07-03-2012 at 07:14 AM. |
A guy with a truck
Re: TBSS Exhaust Manifold Info (Pictures)
Wow, good prices. GMpartsdirect generally kills you on shipping though. Check out the build thread index-- I know there are a few running them in there for sure. Or, do a search for TBSS...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Has more rust than truck...
I used them, Only clearance issue was between the motor mounts and the manifolds. I shaved the bump off of the mounts. Others just do a little clearanceing with a grinder.
I'm using TBSS manifolds with dirty dingo adjustable 73+ mounts with the matching stands and rubber. They fit great with zero issues, they are not even close to the mounts or stands. I did notice the part numbers cast on mine are 12567483(LT) & 12567484(RT). Not sure what the difference is.
Always a work in progress
They charge $25.41 to ship them for a total of $125 so not too bad if you don't have maninfolds that work already.
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Does anybody know it the GMparts direct manifolds come with the heat shields?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
meowMEOWmeowMEOW
Lists a seperate part number...in my experience with them, anything listed separate that doesn't have a "*, kit, package" listed means its the item ala carte. I would expect to get the manifold alone, no studs no heatshield.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
They don't ship to Canada!! AAAAAHhh!!
#9 | |
A guy with a truck
I do! ...and mine come with heat shields and pipes...
http://67-72chevytrucks.com/vboard/s...d.php?t=530619 Same engine, same chassis, stands to reason same manifolds. Never look at an SSR the same again...
Re: Stock Manifold Options for LS Swaps
2004+ GTO : 12563277 and 12563278
They look like they tuck close to the block and ont have two vertical studs. Should be plenty of frame clearance... ![]() ![]() Last edited by mcmlxix; 07-03-2012 at 09:54 AM. Reason: added pic |
Boosted Member
I used those GTO manifolds too....but in a little different configuration
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Any input on which (if any) manifolds for a stock '57 front end?
Didnt the ssr have different heads with d port on exhaust ?
#15 |
I dont believe so. They started in 2003 with the 5.3L so it should be round port exhaust....
PS: I have a pair of 5th Gen Camaro manifolds on the way. I'll post pics when I get them... |
#16 |
Also test fit the 2010 Camaro manifold... Camaro on the left, Sierra on the right...
#17 |
Registered Cruiser
Anyone know if the TBSS manifolds will fit with a 5.3/Dropmember set up?
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
#18 |
Registered Cruiser
Anyone?? Can't seem to find what headers guys are running in the squares, with DM and LS Swap....
#19 |
Its 7" from the last manifold bolt on the head straight down to the flat gasket surface of the flange.
It sticks out 5.25" from the side of the block at its widest point. (Opposte of where the starter would attach.) ![]() ![]() ![]() |
#20 | |
does anybody know if the stock LM7 flange fits the TBSS manifolds?
i see they are both three bolt flanges, i was wondering if i could get that lucky. i need a set of manifolds, but was hoping to still use the pipe and flanges. i know i will have to cut the pipes loose from the y so they will fit in the frame. Quote:
#21 |
The ones I have bolted right up. I think I have the SSR manifolds but they are identical to the TBSS ones
Posted via Mobile Device |
#22 | |
Registered Cruiser
What are people using for reducers/collectors for the TBSS Manifolds? Do I have to find a TB and grab the exhaust system off of it, or is there an aftermarket piece?
#23 | |
Registered Cruiser
Anyone? ![]() I wonder if an exhaust shop can fab some collectors for the manifolds?
#24 |
I unded up using the Camaro 2 bolt manifolds but I had the local waterjust guy cut two 3/8" steel flanges for a 2.5" OD exhaust pipe....
#25 |
Registered Cruiser
Ya, looks like I'm just going to have some made, or make my own ;P... Thanks mcm
Tags |
fuvk off |
