Old 06-12-2012, 01:15 PM   #626
wutnxt
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
Re: My 57 Pro Street
Nice ride.......
You do good work....I bet you can't wait till it's done...
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[
1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123
1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909
1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625
Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic
Aluinum Radiator Dealer pm for details
wutnxt is offline   Reply With Quote
Old 06-12-2012, 03:52 PM   #627
Kim57
Kim57's Avatar
Originally Posted by wutnxt View Post
Nice ride.......
Thanks.
You're right I can't wait till I'm where you're at on yours.
If I could just leave well enough alone I'd be farther along.
I'm in the middle of putting hydraulics on it to operate the bed and also lowering my tank from its original position. After seeing it in for a while I decided it was to high.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-12-2012, 04:52 PM   #628
faribran
is that a KWIK AC bracket ?
faribran is offline   Reply With Quote
Old 06-12-2012, 07:24 PM   #629
Kabwe
Certified Car Nut
Kabwe's Avatar
Everything is looking great Kim.
Kabwe is offline   Reply With Quote
Old 06-12-2012, 08:34 PM   #630
Kim57
Kim57's Avatar
Yes it is.
Thanks Bam.
Kim
My build thread
Old 06-13-2012, 08:53 AM   #631
focusedontheprize
focusedontheprize's Avatar
Your truck looks real good Kim. Incredibly impressed by your metal fabrication skills.
focusedontheprize is offline   Reply With Quote
Old 06-13-2012, 11:55 PM   #632
Kim57
Kim57's Avatar
Thanks.
Kim
My build thread
Old 06-14-2012, 12:05 AM   #633
Kim57
Kim57's Avatar
A little update.
The more I looked at the tank the more I hated how high I had it sitting in the frame.
I ended up putting it under it instead of on top.
I got some weld in bungs and put them in and bolted the tank to them.
The move meant some rerouting of the fuel lines and a smaller pre-filter which I still have to mount.
It should still be hidden by my bed once its on.
Kim
My build thread
Old 06-14-2012, 12:11 AM   #634
Kim57
Kim57's Avatar
I decided to use hydraulics to raise the bed.
Linear actuators just weren't going to raise it as high as I need it to go without a lot of trouble.
I got a system that the low riders use for their suspension and adapted it to work for my bed. It should take the bed vertical without any problems.
Kim
My build thread
Old 06-14-2012, 12:13 AM   #635
Kim57
Kim57's Avatar
A few more pics of the hydraulics. I had to re-route some fuel lines to make room for the hydraulic lines.
Kim
My build thread
Old 06-14-2012, 10:19 AM   #636
oldman3
oldman3's Avatar
Kim, looks real good....Jim
oldman3 is offline   Reply With Quote
Old 06-14-2012, 08:59 PM   #637
Rude Dude
Rude Dude's Avatar
I like the hydro set up same pumps as lift gates, great work!
Rude Dude is offline   Reply With Quote
Old 06-15-2012, 09:24 AM   #638
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: My 57 Pro Street
I can't wait to see this done. This going to be a bad truck.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-15-2012, 09:53 AM   #639
Kim57
Kim57's Avatar
Thanks.
It turned out to be the best fit for my situation. Has a real smooth operation.
I hope to get the frame blasted and painted in the next couple of weeks.
Kim
My build thread
Old 06-15-2012, 01:06 PM   #640
Daze57
Daze57's Avatar
kim
your skills absolutley rock !!!
Daze57 is offline   Reply With Quote
Old 06-22-2012, 11:23 PM   #641
blue57
blue57's Avatar
looks really nice. Are two filters really needed? i am just wondering because i am almost at the point where i need to get all my components together to get my frame togeter.
blue57 is offline   Reply With Quote
Old 06-22-2012, 11:27 PM   #642
Kim57
Kim57's Avatar
Originally Posted by Daze57 View Post
kim
Thanks.
Not sure if they're really needed but I want to keep stuff out of the pump to make it last as long as possible. Plumbing for it was easy so the only down side is the cost of the filter.
I got one that filters 100 micron or larger to keep the restriction down.
Kim
My build thread
Old 06-22-2012, 11:30 PM   #643
blue57
blue57's Avatar
Originally Posted by Kim57 View Post
Thanks.
Kim
ok, thanks. I see an LS motor in the back ground...... is that what you will be running in this truck? If so what headers will you be using?
Old 07-10-2012, 09:52 PM   #644
parkwood
parkwood's Avatar
Kim you're going to have to leave the bed off so everyone can see all the great work... nice job...
parkwood is offline   Reply With Quote
Old 07-10-2012, 10:41 PM   #645
hotrod1
56 - autocross
hotrod1's Avatar
Hey Kim:
As one of the members said at the Brothers show, I want to see you make all your own bolts and nuts.
hotrod1 is offline   Reply With Quote
Old 07-10-2012, 11:32 PM   #646
paintman5851
friggin....just..... well......just.......friggin WOW
paintman5851 is offline   Reply With Quote
Old 07-10-2012, 11:43 PM   #647
Kim57
Kim57's Avatar
LS2 from a 07 Trailblazer SS. I'm running Sanderson headers.
Thanks. I've actually thought about leaving the bed open.
Originally Posted by hotrod1 View Post
Hey Kim:
I have made a few special nuts that I couldn't find and I think I'm a little nuts on my own for doing some of this stuff.
Kim
My build thread
Old 07-11-2012, 02:08 AM   #648
BC Toy chest
BC Toy chest's Avatar
Hey Kim it was really nice to meet you at the Brothers Truck Show. Looking forward to seeing your ryde in person.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 07-11-2012, 10:30 AM   #649
Kim57
Kim57's Avatar
Same here BC.
Kim
My build thread
Old 07-30-2012, 04:16 PM   #650
hp1957
hp1957's Avatar
Kim57 Extra effort in custom fabrication looks great!!
Harvey
1957 Chevy Stepside
1958 GMC Fleetside C4 build thread
http://67-72chevytrucks.com/vboard/s...65#post5510465
hp1957 is offline   Reply With Quote
