02-11-2013, 12:28 AM | #101 |
Re: Your Favorite Budget MODs ($50)
I had rebuilt my factory windshield washer pump once, but was never happy with it's performance, especially compared with any of the new vehicles in the driveway. For less than the cost of the gas to drive to the wreckers, I swapped in a tank and pump out of a '90's Chev truck. It works so well, the washer fluid sprayed over the cab into the box before I adjusted the nozzles down.
And for a couple of bucks I repainted my bowtie to match the truck. |
02-11-2013, 01:30 AM | #102 |
fun night got me a new washer fluid bottle.
also an old mod i had done i found a steering wheel and in bed carrier in the basement. to fix the problem of crawling under the truck for the spare
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373 1984 Chevy C10 short bed 2001 Chevy Impala police cruiser 2001 Chevy Silverado 1500 Z71 4wd extended cab dd |
02-11-2013, 10:14 AM | #103 |
Tired of the gauges messing up because of the connection so I Built a new wiring harness for the gauge cluster. At the same time i didnt want to hack the harness in case this harness ever went bad
What you need: Extra Cluster for cutting Hot Glue Gun Solder Gun 20 pin PC ATX Extension Molex® Crimp Terminals 08-50-0134 CONNECTOR A Test light and 12v power source (If you like to test everything like me) So Basically the trick is pull back the fil a bit and solder your wires to the circuit board. I cut my ATX extension in half and soldered it down. Made sure all the connections were not touching and hot glued that baby in place. I then ran 12v to each wire and tested the board to verify connection. Success Then I built my adapter with the other end. I cut the connector out of my spare harness and followed the stains to drill holes on the top and into the sides of the connection. I then used molex connectors to put in the holes to put my connections in place. once the connectors were in place I hot glued them in to hold them firm and keep the wires from moving and touching each other... Its a slow process but ultimately i think its worth never having to worry about my connections on my cluster screwing up lol
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
02-11-2013, 02:40 PM | #104 |
new halo headlights I got recently...$38 plus shipping..one of the koolest things I ever put on my truck so far.
02-11-2013, 02:51 PM | #105 | |
where did you get those??? Those are awesome!!!!
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
02-11-2013, 03:09 PM | #106 |
You can get them on ebay and on amazon
02-11-2013, 03:30 PM | #107 |
bought them on ebay. had to mod the headlight buckets to fit but they work great. now I just have to adjust my high and low beams. they're a bit off. just hooked up the halos for now. I'm thinkin about running a separate switch to the other blue lights
09-22-2013, 10:29 AM | #108 |
This is one of my favorite threads!
I recovered my dash like 1978chevybigten mentioned on the second page. Cost $37 for the fabric and glue. I haven't done this yet but I saw it in another thread. This place: http://www.automotivetouchup.com/ sells "touchup paint" in aerosol spray cans. They color match the factory paint that is on your truck. It seems like it would be great for smaller areas like rocker panels after rust repair. The basecoat cans are $20 and the clear cans are $8.
1982 GMC Crew Cab 4x4 - "River Truck" build thread 1973-1987(91) Chevy/GMC How-To Videos |
09-22-2013, 10:37 AM | #109 |
I don't smoke so I cut the upper screen type thing and the little hook in the lower corner out of the ash tray. Then I sprayed the inside and the part of the outside that you see with Plastidip. It makes a great place for my iphone (or whatever). Plastidip is a very cool removable rubber coating. It's pretty amazing stuff. People are coating whole cars with it now. Anyway, I think the spray cans are around $8 at Lowes.
09-22-2013, 12:17 PM | #110 |
I think this may have been mentioned already.... If you're steering shaft rag joint is causing your loose steering, you can swap in a Jeep XJ Cherokee steering shaft to eliminate the rag joint. It is a very easy swap for older square body trucks. The earlier trucks have a different steering column (changed around 1981) that makes it more difficult. The Jeep shafts are usually less than $50 at a junk yard.
09-22-2013, 12:23 PM | #111 |
One more...
I needed tie downs in the bed but having them in the bed floor won't let me use a bed mat. I bought some stainless threaded rings and replaced the bottom bolt that attaches the front bed panel to the side panel. I backed the rings with some large washers and nylock nuts. These won't be for holding lots of weight. Just to keep things from rolling around or sliding out the back when the tailgate is down.
09-22-2013, 07:19 PM | #112 | |
2004 Silverado Crewcab (Dark Spiral Gray) |
12-07-2013, 06:25 PM | #113 |
Bump... Looking for more ideas!
12-07-2013, 06:48 PM | #114 |
One of my favorite threads...let's see some more!
12-07-2013, 07:35 PM | #115 |
12-07-2013, 09:49 PM | #116 |
Add or replace cab lights for $29. I already posted the details but I thought it was worth repeating: http://67-72chevytrucks.com/vboard/s...d.php?t=605771
12-13-2013, 08:34 PM | #117 |
this is THE best thread i have found here. i did a quick change of my blinkers and running lights to LEDs so they are way brighter and dont draw as much as my old lights. if u buy the lights from a led website they will run u under $10 i also painted behind my grille flat black so in the daylight you can seen any of my lights behind the phantom grille. i also bought a led light bar for my license plate for under $10 which i thought was a bit different
i dont know why the pics are all upside down if anyone can tell me how to change this it would help all of u
Jeremy '86 GMC 1500 dropped 6" in the front and 6" in the rear 2003 Land Rover Discovery Low Life |
12-13-2013, 08:46 PM | #118 |
Robert Olson Transport
my two favorite mods are to swap out the interior lite with the old jet style with the two eyeball lights
also I always like spraying the bezels and grille with the duplicolor paint the light silver it is a good match to the OEM color
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-13-2013, 10:12 PM | #119 |
Funny those door panels pictured are now in my brown truck lol. I went over them with $10 duplicolor bed liner and it doesn't have any grit. Looks nice on everything else
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-13-2013, 11:47 PM | #120 |
a few times a year Pick'n'Pull has a 50% off day - got a bench seat in really good condition for $25 - took it to local car wash with a detailing shop and they steam cleaned it for $20
12-14-2013, 02:28 PM | #121 |
they help up decently for me. I even put my bmx bike in the cab then i go places and it beats around. i figure its safer in there than the bed
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
12-14-2013, 03:07 PM | #122 |
Okay....I paid $20 at a swapmeet for a perfect leatherwrapped steering wheel from an early 90's S-10 Blazer LT.
I scored a Theftlok GM CD player from a boneyard along with a 1990 Suburban instrument cluster bezel and with the radio harness adapter I had to buy new I had right at $50 in it all. That gave me a 1.5 DIN opening to keep it looking factory and allows me to plays CD's now. Another $50 upgrade/mod was the brushed silver instrument cluster overlay from LMC to finish the above mod. What else..... I Also scored buckets and console courtesy of a 1990 Suburban from a junkyard for $45 and after a couple power wash/scrub session it all looks brand new. |
12-14-2013, 04:42 PM | #123 | |
This reminded me of another mod I did on my 86 K10-I used 88-91 Suburban wiper arms with the built-in washer spray nozzles and retainer-it keeps you from shooting fluid at the glass and instead flows along with the blades as they move up/down. Cost me $5 for the wiper arms at the junkyard. |
01-15-2014, 03:40 AM | #124 |
I bought a 73 Suburban recently and noticed it was backfiring on cold start. Check for spark and the spark seemed weak.
then checked for voltage at the BAT terminal of the HEI...only 11.4Volts. Checked the voltage during cranking and it even dropped to only 7-8Volts. This is a common problem with old cars. A lot of stuff runs of the IGN, but upgraded parts (like point to HEI ignition) and old wiring cause voltage drops. Solution is simple: use a relay to supercharge your HEI directly to your junction on the firewall where the alternator keeps the voltage at max. http://www.hoigto.com/tech/powerHEI.htm The cost is well under $5 so a very affordable great upgrade. result: cold morning starts are great, backfires didnt happen anymore and idle is nice and strong
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
01-15-2014, 12:35 PM | #125 |
kikkegek - great idea
