#276 |
Re: 1967 Mustang Coupe Build (Electra)
Well the good news is i finally finished welding in the floor panels. The bad news is she wont start anymore. I suspect the battery to be near dead as the corrosion to the alternator is BAD!!!!! The wire was almost breaking by barely touching it. Either way I have a new Concour headlight wiring harness, headlight switch, and dimmer switch here waiting to be installed. I also ordered a new alternator wiring harness so i could get rid of all the crazy rigged up tap and bad wires. Just to be on the safe side I ordered a new solenoid as well. So soon ill be re-wiring all that junk and probably charging the battery.
PLEASE HELP WITH PROJECT UNDERHAULIN http://67-72chevytrucks.com/vboard/showthread.php?t=306320 Gemini - 1978 GMC C15 High Sierra - 305 c/e - Given to Mother Electra - 1967 Mustang Coupe - 302/w 3 speed Build Chyna - 1968 Chevy C20 Long Stepper
#277 |
Cool bro!
-Rus |
#278 |
Looks like it's coming together man. While my '78 C10 is in the shop trying to get healed from it's hard shifting and odd speedometer issue, I'm looking for a '69 fastback to work on. I'm still learning about cars but I figure with a Chevy in the garage and a Ford, I'll eventually learn a thing or two! Ha ha.
#279 | |
#280 | |
![]() Join Date: Nov 2004
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#281 |
Yeah, from my experience the fords are a little more complicated. Especially the wiring
#282 |
Changing a timing chain on a 289/302 is one of the biggest pain in the ass things I've ever done. Everything has a specific order it has to come apart and go back together and almost every part fits over another part... etc...
#283 | |
Posted via Mobile Device |
#284 |
Well ordered some used CONTINENTAL CONTIPRO CONTACT tires. 225/45/17 for the front and 245/45/17 for the rear. I plan to try to work on the wiring this weekend and get her back up and running. Well hopefully....You never know and it may take longer then i expect
#285 | |
![]() Been on vacation (FINALLY) for the past couple weekends, spent a full 8 days in Destin, FL. After I finish the paint and trim on the bonus room above the garage the 65 is getting new suspension stuff.
#286 |
Now that sounds nice! The vacation too! lol
#287 |
Is your car a ***** to start? My C10 sat just as long as the Mustang, and she fired right up yesterday after two pumps. I had to pump the crap out of the mustang, then it started, died, then started up again. I also have to hold the pedal down 1/4 of the way to start it when it's hot (it's actually a ford procedure, it will not start unless I do that). I guess it's the manual choke carb vs the electric choke edelbrock on my truck. Carb is rebuilt and works great, timing is good, car runs great, just doesn't like to start. If I drive it everyday, it will start right up when cold, but sitting 3, 4 or more days and it takes a good bit of cranking/pumping.
#288 |
The mustang has always been really easy to start. 3 pumps and it fires right up. My truck can be a problem though so yeah... Now if i can fix the wires and charge the battery it will start again
#289 |
Do you know if you have a "modern" carb w/ electric choke (like edelbrock/holley, etc) or if it's the original Ford autolite?
#290 |
Its an older holley with electric choke...Atleast I think, I havent looked at it in awhile but i know its electric choke
#291 |
New tires are good!
=MATTHEW 69 Stepper...Stroked & Bagged ![]() 2003 Chevrolet Z71 Ext. Cab 1995 Cavalier gas saver! |
#292 |
awww yeah
#293 |
Ha! it even has 67 on it! lol
-Rus |
#294 |
Niiiiiiiice!!!!!
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
#295 |
Yeah, and a "V", too, you know, for any part of your body that may start with that letter!! Congratulations, though. Always a big step with all the crazy rules about registering something from out of state.
#296 | |
Posted via Mobile Device Posted via Mobile Device |
#297 |
V for VROOM!!!!
#298 | |
#299 | |
On the mustang side, I found this but it's still expensive. http://phoenix.craigslist.org/nph/cto/4103898663.html. I wish the fastbacks weren't so much. Posted via Mobile Device |
#300 |
And the parts stash shall continue...Just ordered new shocks and struts. 65-70 KYB EXCEL-G SHOCK KIT to be exact.....Tires are supposed to be delivered today and with any luck ill get the car headlight harness and alt harness installed this weekend
