![]() Join Date: Dec 2013
The Dirty-Burb sure looks good in my driveway.
New to the forum, i just picked this up on saturday. I'm sure you guys have seen the build thread on this but i am excited to keep going with it. I will have my share of questions getting to know this vehicle. Talk to you guys soon
Dustin |
#2 | |
The Older Generation
Re: The Dirty-Burb sure looks good in my driveway.
Hey Dustin, That would look really nice if you could get it an inch or two lower... ![]() Great looking Burb and welcome to the truck board... LockDoc
What?
Hey Dustin,
Welcome to the forum! I know that burb too. What are your plans for your new ride?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
So sick. Welcome. And I'm so jealous...That's been my favorite burb on here for a long time.
Aaron Anderson *1971 GMC Burban - Daily *1962 Nova |
67-72 parts collector,…
![]() Join Date: Nov 2002
Welcome to the board!
Congrats on your new purchase.
Junior Member
Welcome. You got a sweet burb from Dave. It sounds like you got a deal too!
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Thanks guys.
Plans right now are to fix a bunch of little miscellaneous things. New window regulators, door hinges are sagging, new rubber, new grill trill and modify the hood release since it has a forward tilt hood. The release does not quite open all the way so its hard to get the hood open. Then build a new center console and put a headliner in. Right now its just sprayed orange with a bunch of stickers. It looks cool and gives it a surf wagon look, but i prefer a nice headliner. Maybe black with some orange cross stitching. Then upgrade the stereo a little. The two speakers on the dash are not quite enough. I have some stuff laying around at the house from previous builds i can throw in there. Any of you guys had trouble with your door hinges? I was going to try to find new ones, or maybe replacement pins/bushings? |
One of my favourite Burbs, I really dig the roof treatment. Does it look as cool in person as it does in pics?
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
What?
I've personally never seen or heard about these trucks having sagging door hing issues, are you sure the hinges are the problem and not striker plate shim or placement issues?
YbNorml- It does look cool. It has 3 coats of clear with orange flake and then 3 coats of clear on top of that. I think over time it will need to be repainted. I was told it was painted about two years ago. It still looks good but there are very slight hints of surface rust in areas. It is not bad at all, i just think over time it will need to be sanded down and painted. Maybe since clear is not really a sealer. Either that or it did not get every single spec off of it when it was prepped. The truck has always been garaged and i keep it garaged as well, so it should last for awhile. One day i will probably shave the handles and gas filler and repaint the car. I love the look of it but personally i would not do it again due to those reasons.
Vectorit- When i open the door,i can lift up on it and get at least 1/8". Maybe even 1/4" on one of the doors at the furthest point. I almost have to lift the door up to get it to close properly. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I have seen that burb all over good to see its stayin on the board ... Are you a member of sunset?
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
No not a member of Sunset. Found about this forum while searching for the thread on the suburban before i bought it. I live in Southern California so i will try to hit as many local shows as i can.
member
The doors on the 67-72 trucks often weaken and the door itself will crack around the upper door hinge. It can be hard to see.
John
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
Yup, hinge bushings go bad, which leads to hard hits and the door cracking issue. LMC/Classic/Jim Carter/Brothers sell pin and hinge kits. 10 min with a hammer and BFH, once they're off.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
