05-27-2014, 12:53 PM | #51 |
Re: TCI to start new R&D Project with a C10!
That's nice. Very nice. I like the torque-arm set-up as well. Cool stuff.
05-28-2014, 08:41 AM | #52 |
Keep up the awesome work! Looks amazing guys.
05-28-2014, 12:18 PM | #53 |
I'm just glad to be here!
Looks great!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
06-05-2014, 10:55 AM | #54 |
06-26-2014, 02:04 PM | #55 |
We finished up some first articles this week. The long tedious process of confirming fixtures and parts begins now.
Stock parts = #342 lbs TCI parts = 270 lbs (Total weight savings of 72 lbs) We also picked up a 2nd chassis to use as a rolling display. It just happened to be a longbed so we made a How-To to show the process of making it a shortbed. -J |
06-26-2014, 02:37 PM | #56 |
That's an impressive weight savings! When will you get some road time with the kit installed?
06-27-2014, 11:34 AM | #57 |
Java Mechanic
Is there such a thing as "frame porn?"
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
06-28-2014, 09:06 AM | #58 |
Awesome! I'd love to see more....maybe my next build
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
06-30-2014, 11:38 AM | #59 | |
The Truckin Throwdown was in our back yard (Fontana) last Friday so I think that event helped light a fire. We can't let Rob be a glory hog. -J |
06-30-2014, 02:35 PM | #60 |
07-02-2014, 06:45 PM | #61 |
C-10 Club Member
sexy.....
Pretty sure this is the route I'm going
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
07-07-2014, 07:21 PM | #62 |
07-07-2014, 11:47 PM | #63 |
WOW, that is so sweeeeet...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
07-08-2014, 12:08 AM | #64 |
What is the max rim width your C/O arrangement allows (since this a 'touring' based app)?
07-09-2014, 10:28 AM | #65 |
07-09-2014, 11:53 AM | #66 |
Never Ending Projects
Looks great but a question. Having the rear coil overs outboard of the frame, won't that limit you on how wide of a wheel you can fit?
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-09-2014, 12:54 PM | #67 |
Yes... That's why I asked what the width limit was w/the set-up. I'm guessing maybe a 12" width max. Maybe less though (hard to judge accurately from monitor pics). But the outboard arrangement offers the best stability....
07-09-2014, 07:29 PM | #68 | |
BTW, the TCI outboard doesn't look any farther out than ours. 12" no problem (will need wider tubbs after 10") 14" can be done, but it's very tight. We did 345/30/19 on 19x12" wheels, had a 13 5.8 section width.
GoodGuys 2012 Pro-Truck Champion 2012 Truckin' Throwdown Champion GoodGuys 2011 National Champion 2011 Truckin' Throwdown Champion GoodGuys 2010 National Champion Proud to put our products up against all others! |
07-10-2014, 01:35 PM | #69 |
07-10-2014, 02:21 PM | #70 |
C-10 Club Member
Any guess on retail pricing yet?
07-11-2014, 12:36 PM | #71 |
I have to admit, you've got me curious about the dog bone for the torque arm mount. I was starting to wonder how you could have the rear axle solidly mounted and then have 3 pivot points on different planes without binding, but this is an ingenious idea! But I wonder how much you gain with a torque arm running with truck arms? Are you predicting enough flex in the rear end housing that the truck arms aren't enough to maintain a correct pinion angle? All cool things, just thought I'd spark some more conversation...
http://i981.photobucket.com/albums/a...pse1079adb.jpg |
07-11-2014, 09:20 PM | #72 |
Mike I had to take a close look after you posted this and was wondering how that would work. Well it looks like it will work fine. the truck arms we are used to are not truck arms at all. There is a pivot in the back making this a true 3 link. Kinda slick the way it is done.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
07-11-2014, 10:13 PM | #73 | |
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
07-12-2014, 08:28 PM | #74 |
I have stared at the picks several times and each time see something new. Wish the pics were bigger, I bet we would see lots of other cool things done on this setup. I am waiting for the pic with the engine and trans installed so I can see how they do the exhaust.
Jimmy
07-12-2014, 11:38 PM | #75 |
Truck and auto performance nut
subscribed...
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
