What's normal for inline HP fuel pump noise?
Just finished up a ~2200 mile road trip in my recently "completed"
![]() The noise is annoying but I can deal. Just want to make sure I'm not burning up the pump. Has anyone else noticed a lot of variation in the sound of Walbro pumps? Or is this an automatic "something's not right, check it out"? The one other thing that appears to have an effect is ambient air temp. Every time it's been excessively noisy, it's been 90 or above. I changed the first filter just as it cooled off for the night, and then drove around on the coast for the next week. Here at home it's not often super-hot. On the last leg of the drive back, it was hot before AND after I changed the filter, and no difference was apparent in the pump noise. Does this make any sense at all, or is it coincidence? Thanks guys!
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
Re: What's normal for inline HP fuel pump noise?
With external pumps the outside temperature will affect the noise output of the pump. Where is the pump mounted? I would suggest to make sure it gets plenty of airflow to help keep it cool.
x2. I use large external pumps on my late model builds and if it's a hot day (especially sitting in traffic- they start screaming. you also don't want to run the tank below 1/4 level or you risk burning up the external pump that way too
That's all good to know, thanks!
We've been filling up at 1/4 (1/8 in extreme cases), even though I know in our tank there are several gallons sloshing around even when the gauge reads completely empty. I figure the pump shouldn't have to "pull" from the tank, I just want gravity to do its job feeding the pump. It does seem a little louder when the tank is less full. The pump is mounted on the inside of the frame rail as close as possible to the tank. Plenty of airflow, and it does appear to be loudest when going slow, in traffic, when it's hot. Going through Moab yesterday it must have been 100*, and waiting in a turn lane it was sure making some noise. As long as this is normal I won't worry about it. Just didn't know what to expect...
#5 | |
Not sure about the second inline filter. Definite no on the first filter (the one I've replaced a couple times), it's a $5 basic 3/8" inline filter.
When you say they don't last as long - is that short-term enough that I should carry around another pump for replacement on the side of the road? Would hate to just give up the ghost while on top of some mountain pass or something.
#7 | |
meowMEOWmeowMEOW
Do you know what the Micron rating on the filter is? I'm wondering if you have too small of an orifice, causing the pump to fight the filters. When you add heat and load, it gets worse.
My 255 whined occasionally until we switched the feed from -6 to -8. I have tank foam, and fill up as soon as it gets to the foam (about 1/3 left)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
This^^^^ There isnt a $5 3/8 filter on the market that I know of that is the right size, micron wise. I bet youre restricting it too much.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Good to know. You guys have any source for inline filters you know are the correct micron size? Don't recall seeing micron size ratings on anything I've looked at. I'd be willing to try something different.
http://www.robbmcperformance.com/products/filters.html This is what I'm using, 100 micron, made in the USA and less than $30.
meowMEOWmeowMEOW
I have the Earls 40 Micron billet inline filter. I think it was $22.
I have bad luck with ALL pre-filters tho, except the "Sock" on intank pumps. I just run a single filter after the pump, and thats it.
Thanks guys, that's super helpful. Will try one of those options out, and if the pre-filter just doesn't work out long term I'll try BR3W's route. This forum is awesome!
![]() Join Date: Apr 2005
Another thing to check is the gauge of wire you are running to the pump. I would use no smaller than 10 gauge via a relay. I would not run it through the truck wiring system. Connect the power wire directly to the battery with a 30 amp fuse or circuit breaker and then trigger it via the ecm.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
