Old 09-10-2014, 11:37 AM   #2426
boynton
boynton's Avatar
Re: 1969 Short Wide
Thanks for the extra pictures! Your truck looks great. I am so far seat from where you are, but I will get there... eventually
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 09-13-2014, 12:41 PM   #2427
mjensen
mjensen's Avatar
Re: 1969 Short Wide
One day when I grow up.... Truck looks amazing, and I may just have to "borrow" that filler setup idea for mine.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 09-16-2014, 09:59 AM   #2428
SeTx67
SeTx67's Avatar
Re: 1969 Short Wide
It's been a while since I checked in and I missed a lot. Your truck turned out absolutely amazing.
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline   Reply With Quote
Old 09-16-2014, 10:16 AM   #2429
Dean'smeanmachine
Dean'smeanmachine's Avatar
Re: 1969 Short Wide
very cool!!
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 09-16-2014, 02:17 PM   #2430
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by boynton View Post
Awesome
Thanks and yes you will get there, it just takes time and lots of work.
thanks Mike. You are welcome to take that idea.
Thanks for complements and checking in on my thread.
Originally Posted by Dean'smeanmachine View Post
very cool!!
Thanks Dean.
Old 09-23-2014, 04:25 PM   #2431
shearjs
shearjs's Avatar
Re: 1969 Short Wide
Mike,
Have you been putting some miles on the truck? How's the LS working for you? Looks great buddy!
shearjs is offline   Reply With Quote
Old 09-23-2014, 04:39 PM   #2432
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Originally Posted by shearjs View Post
Mike,
Thanks Jason. Unfortunately, I haven't put very many miles on it. I'm working through some problems on my rear end. It was an old used 2:72 from a mid 70s truck. I installed a set of 3:73 gears in it from a donor 68 I had in my parts stash.
Apparently, I didn't get everything perfect so there was a howl noise when coasting.
I took everything back apart last night and am going to try to set again tonight. Hope to be back on the road soon.
I will get some pictures of the progress.
Old 09-24-2014, 01:03 AM   #2433
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Looking forward to this update because I've got this in front of me too. I know you'll show us the right way and some trick way to do it! What set did you have running in the video?
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 09-24-2014, 07:57 AM   #2434
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I don't know about any tricks or the right way . I have really struggled with this rear end project. It's not as straight forward as I had hoped. I have had the pinion and gear carrier in and out at least 10 times trying to get the pattern right. There seems to be some black magic to installing them. This is exactly why it costs so much to have a new set installed.
As for the video, I was running the stock 2:73 gears. I know I like the way the 3:73 gears pull much better, I just couldn't deal with the howling noise.
Old 09-24-2014, 09:49 AM   #2435
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Random Pictures of what I have going in the shop.
Old 09-24-2014, 10:30 AM   #2436
boostedc10
boostedc10's Avatar
Re: 1969 Short Wide
Mike your pinion depth is too shallow. You need to get it moved deeper into the mesh.
I have done hundreds of rear ends and I can tell you that when I first started doing them it was a lot of trial and error. The biggest thing is to not get frustrated and just take your time.
Luckily I was young and in a dealer when I was learning and was shown some of the tricks to make pinion shim corrections quickly.
Another big thing when checking your patter is to make sure you have some drag on the unit. This will ensure you get a good read every time.
Let me know if you have any questions, I am sure I can help you out. I am swapping in a new 3:42 and posi currently in a 12 bolt this weekend.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 09-24-2014, 10:40 AM   #2437
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Boostedc10. The pics are from when I first started adjusting the gears. I have since moved the pinion deeper but I am still having trouble getting a nice pattern. It seems that the edge is very sharp, almost as though the pinion contact is out of time? Anyway, I'd love to get your contact info. I have been fighting with this thing for what seems like 40+ hours. I have gotten so frustrated a few times I just called it a day early.
If you don't mind me pestering you about the setup send me a pm.
Thanks.
You have an awesome project going yourself. BTW I think 3:42 would be better choice for my setup but I had the 3:73s already so I figured I'd give them a try.
Old 09-28-2014, 04:45 PM   #2438
tune_1
Re: 1969 Short Wide
Sorry to hear about the rear end problems. But you will get it soon. It makes the signature line even more real "Built not bought". Another story to add to the truck.
Dwight
tune_1 is offline   Reply With Quote
Old 09-30-2014, 07:48 AM   #2439
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Dwight
It's all good Dwight. I knew it was a possibility back when I installed the rear end in 2010. It had a lot of slack, I just didn't know it was that bad .
I have it back together and on the road again. I am now confident I can set up my new posi when I get to that point.
I wanted to say thanks to Mark (Crash_OK) for helping me pull an extra rear end I had in a 68 chassis my stash. It was in a tight spot and I couldn't have gotten it out without your help.
I also had a bunch of help setting up the gears from member boostedc10 (Thanks Brandon!).
Old 09-30-2014, 07:56 AM   #2440
Crash_OK
Crash_OK's Avatar
Re: 1969 Short Wide
Glad you get it all setup and working correctly.... I am also glad we have a differential specialist in the group now..
Now get the front aligned and drive it...!!
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 09-30-2014, 08:00 AM   #2441
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
I'm glad to have it back on the road too. I am taking it to alignment shop this week. I will definitely be driving it some too. Count on it.
Old 09-30-2014, 08:00 AM   #2442
boostedc10
boostedc10's Avatar
Re: 1969 Short Wide
Glad I could help you get it back on the road. If you need anything else you got my number.
Brandon
Instagram: DRVFSTR
Old 09-30-2014, 08:16 AM   #2443
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Pics from gear swap:
Setting backlash for the hundredth time
Not right:
Back together
Old 09-30-2014, 08:31 AM   #2444
jlsanborn
jlsanborn's Avatar
Re: 1969 Short Wide
Way to go on the R&P setup Mike!
Old 09-30-2014, 11:06 AM   #2445
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks. Just chalk up more of my phrase "still learning" to the build.
Old 09-30-2014, 12:33 PM   #2446
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Don't worry I will hit you up. Thanks again
Old 09-30-2014, 02:59 PM   #2447
Low Elco
Re: 1969 Short Wide
Glad you got 'er back on the road. I's eskeered o' them geer thangies.
Low Elco is offline   Reply With Quote
Old 09-30-2014, 09:13 PM   #2448
jeh
jeh's Avatar
Re: 1969 Short Wide
Good to see you rollin' again Mike...
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 09-30-2014, 10:44 PM   #2449
Bennett68C10
Bennett68C10's Avatar
Re: 1969 Short Wide
Glad to see you got the gears figured out Mike, now you can get back on the road and enjoy her.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 10-01-2014, 09:30 AM   #2450
mcbassin
Still Learning
mcbassin's Avatar
Re: 1969 Short Wide
Thanks Chip. You have such a way with words. remember that bumper/window decal back in the 90s? "No Fear"
Thanks Jason
Thanks Keith
