Old 02-25-2015, 08:41 PM   #126
rusty76
rusty76's Avatar
Re: Blake's 67 GMC stepside build
Are you TIG welding all this stuff or MIG? It all looks great. I love the fit and finish of it.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 02-26-2015, 11:11 AM   #127
reaper71
reaper71's Avatar
Thank's Doug, it is very time consuming but in the end it helps prevent those annoying pin holes LOL..
Originally Posted by Advanced Design View Post
Nice process on the back weld Mark. Looks good!
reaper71 is offline   Reply With Quote
Old 02-26-2015, 11:19 AM   #128
reaper71
reaper71's Avatar
To answer that ?
Most of it was Mig welded and some Tig thrown in the mix..Mig is alot faster but builds more heat and material (meaning the weld itself ) to be ground down later.
I did a timed comparison one day and welded an area with both, then did the metal finish. The Tig took longer to do the welding but the grinding and finish were very minimal compared to the MIG.
So at the end of the day you ask yourself would you rather spend more time grinding or under the welding hood?
Old 02-26-2015, 11:28 AM   #129
reaper71
reaper71's Avatar
Update...
Pic #1. Profile view of firewall..(much better than stock!!! )
Pic #2. The passenger side upper corner had some issues that needed some attention.
Pic #3. The new piece tacked in place.
Pic #4. After welding and finish..
Drivers side next...
Mark...
Old 02-26-2015, 01:24 PM   #130
rusty76
rusty76's Avatar
Originally Posted by reaper71 View Post
To answer that ?
It all looks great and you are doing a great job. I'm impressed.
My build thread
Crossmembers CC
Old 02-27-2015, 10:29 AM   #131
reaper71
reaper71's Avatar
Thank's Rusty76, much appreciated!!
Pic #1. The drivers side rot removal..
Pic #2. New piece tacked in place.
Pic #3. All finished..
Pic #4. Finally in Epoxy primer!!!!!
Old 02-27-2015, 06:22 PM   #132
RockinKees
RockinKees's Avatar
That is some nice metal work!
Looks great!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 02-27-2015, 08:47 PM   #133
Advanced Design
Advanced Design's Avatar
That does look good Mark. Nice rust repairs and channel looks much better.
Advanced Design is offline   Reply With Quote
Old 02-27-2015, 08:48 PM   #134
yj4000
yj4000's Avatar
Looks really good all one color. Very nice work. I may have try this when I get started on my truck.
Ryan.
yj4000 is offline   Reply With Quote
Old 02-27-2015, 10:35 PM   #135
rusty76
rusty76's Avatar
That looks great.
My build thread
Crossmembers CC
Old 02-28-2015, 04:58 AM   #136
swamp rat
swamp rat's Avatar
Nice clean look, and if ya wanted to you could still run some wiring thru it if needed.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-28-2015, 11:59 AM   #137
reaper71
reaper71's Avatar
Thank you Guy's for the support and continuing to follow the build...
It was a very time intensive project but worth the effort in the long run.
Swamprat....We usually try and get the wires ran behind the fenders to keep them hidden, but like your thinking..
Old 03-02-2015, 10:53 AM   #138
reaper71
reaper71's Avatar
Update...
Pic #1. The cab in the process of being stripped..
Pic #2. 2nd view.
Pic #3.First look after the paint was removed and Epoxy primer sprayed on..
Pic #4. 2nd view.
Pic #5. A shot of it in the high build primer. (I used Mar-hyde )
Old 03-02-2015, 12:25 PM   #139
slowcpe
slowcpe's Avatar
Wow you make that look easy. Nice progress!
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 03-02-2015, 02:44 PM   #140
Advanced Design
I agree! Good looking place around there too.
Old 03-03-2015, 11:31 AM   #141
reaper71
reaper71's Avatar
Thank's again Guys...
although the place is not mine it is Dad's as is the shop, I'm fortunate enough to be able to utilize it!!
Update...
Pic #1. Finally getting to the doors.
This is the passenger side as I started the paint stripping..
Pic #2. After stripping was done and wire wheeled.
Pic #3. The front side of door, If you look closely you can notice the multiple holes in the lower section that they had filled with bondo that will need addressed.
Pic #4. Mirror holes being welded up.
Pic #5. And again more Mirror holes this time with some plugs I made.
Old 03-03-2015, 07:49 PM   #142
yj4000
yj4000's Avatar
Moving right along. Wish my doors were that nice.
Ryan.
Old 03-04-2015, 11:09 AM   #143
reaper71
reaper71's Avatar
Ryan before you speak to soon....
Pic #1.Here is the bottom section of the door after I did a clean up with the wire wheel...Needs some TLC.
Pic #2. A pic after it was cut open (notice the yummy treat inside)
Pic #3. After the patch work was done and metal finished.
Pic #4. This is the Drivers side. (this was a door from a doner vehicle the stock door was mangled up pretty bad!! )
Till next time..
Mark...
Old 03-04-2015, 04:33 PM   #144
RockinKees
RockinKees's Avatar
That's a nice repair on the door!!
Cheers!! Kees.
Kool Guyz CC
Old 03-04-2015, 06:41 PM   #145
Advanced Design
Yeah, I was thinking the same thing. Nice repair Mark.
Old 03-05-2015, 10:59 AM   #146
reaper71
reaper71's Avatar
Kees and Doug thank you...
Pic #1. A quick shot of more rot (and new hinges)
Pic #2. And more rot...
Pic #3. Oh yeah....More ROT!!!
Pic #4. The solution was to get a new lower door patch.
Pic #5. Pic of the new piece..
Mark...
Old 03-05-2015, 12:00 PM   #147
sduckworth13
sduckworth13's Avatar
Your doing some very difficult repairs, looks great.
Scott
sduckworth13 is offline   Reply With Quote
Old 03-05-2015, 04:01 PM   #148
Low Elco
Great Lookin' stuff, Mark!
Low Elco is offline   Reply With Quote
Old 03-05-2015, 10:12 PM   #149
yj4000
yj4000's Avatar
Very nice work. I will need to get the lower patch panels also. I'll be paying close attention.
Ryan.
Old 03-09-2015, 10:17 AM   #150
reaper71
reaper71's Avatar
Thank's guys....
Pic #1. The first shot of the fitting of new lower section.
(this replacement piece is not the best fitting panel I've seen)
Pic #2. Here is another example of the poor fitment. (The lower hinge section was entirely the wrong shape so I cut it out and will re make it)
Pic #3. Another example of poor fit. (but I can fix it!!)
Pic #4. This is what I had after I cut things apart and then made the flat section fit and welded in place. (You can also notice how I made 3 cuts and moved the metal to match the door shapes and welded)
Pic #5. The 2nd piece that will fill in the opening..
Till next time...
Mark...
