Old 03-06-2015, 03:27 PM   #1
rodzilla67
Lowering my 1970 C20
I am new to the board and have really enjoyed looking at everyones builds and the wealth of information found here. I am just starting a build on this truck and one of the first things I would like to address is lowering & converting to 5x5 lug and front Disc. I am hoping to drop front 5 1/2 " and possibly 7" in Rear.
I have some questions maybe you all could help me with:
Can I use a C10 Drop spindle kit on a C20?
What would be best way to achieve this drop?
Suggestions? Advice?
Thank you in advance for any and all help.
rodzilla67 is offline   Reply With Quote
Old 03-06-2015, 03:35 PM   #2
hdff
hdff's Avatar
Re: Lowering my 1970 C20
welcome from TEXAS!!!!!
i can't help ya with your drop question but you might post it the suspension section for more help.
and also wanted to say
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach
"Wanda"
Don't argue with idiots, People watching may not be able to tell the difference...
There's someone in my head........But it's not me......
cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394
hdff is offline   Reply With Quote
Old 03-06-2015, 03:40 PM   #3
rodzilla67
I agree on the pics, but unfortunately I live in Maine and we have had 127" of snow this year! Preparing for spring Sorry didnt see suspension thread.
Old 03-06-2015, 04:12 PM   #4
csfields
csfields's Avatar
I went with a 6 inch rear drop and 4 inch front drop. Used two inch lowering blocks and four inch shorter springs on the rear along with a bent pan hard bard for clearance and a c notch. The front was 2.5 inch drop spindle and 1.5 inch shorter spring.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 03-06-2015, 04:17 PM   #5
hdff
hdff's Avatar
snow? what is that.... lol we had a pretty cold morning this morning, got down to blustery 34*, burrrrr
"Wanda"
Old 03-06-2015, 04:23 PM   #6
rodzilla67
Did you use a C10 Drop Spindle? Did you convert your Bolt Pattern to 5 lug?
Old 03-06-2015, 10:12 PM   #7
Stranny64
Stranny64's Avatar
No 5 lug for me yet. I have 5/3 lowering so far. I used springs from GMC Paul's, relocated shocks and trac bar from CPP. Good luck!!!
1968 Custom Camper C/20, rebuilt original 327 with 350 hp., turbo 400 with shift kit, factory AC truck, original patina rust free paint from Oregon, 2/4 lowering springs + 1" blocks, GM 2500 8 bolt rally's with dually center caps with Firestone Destination 245/75-R16's. (My 50th birthday present from my wife!!!)
Stranny64 is offline   Reply With Quote
Old 03-06-2015, 10:34 PM   #8
70cst
70cst's Avatar
Hey rodzilla67 ...
to the forums and from Ohio.
I will move this to the "Suspension" forum where you might get addition help.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 03-06-2015, 10:52 PM   #9
Mike C
Mike C's Avatar
Looks like you posted twice.
http://67-72chevytrucks.com/vboard/s...d.php?t=662556
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-06-2015, 11:06 PM   #10
rodzilla67
Originally Posted by 70cst View Post
Hey rodzilla67 ...
Thanks I did post there after first response suggested it. No replies there yet.
Old 03-07-2015, 10:10 AM   #11
Mike C
Mike C's Avatar
As I commented in your other thread, ECE is the only company that will let you keep all the rest of your suspension stuff and run 5 lug brakes with their spindle.
Scroll down here and see the C20-C10 spindle.
http://earlyclassic.com/catalog.aspx...ry=New%20Items
And here is a good link that covers many of the questions you have.
http://67-72chevytrucks.com/vboard/s...d.php?t=662011
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 03-07-2015, 02:06 PM   #12
rodzilla67
Thank you for reposting this for me.
Old 03-08-2015, 08:58 PM   #13
rodzilla67
Just wondering if I can use C10 spindles on a C20? Are they that different?
Was also looking at the possibility of:
http://www.ebay.com/itm/391054955572...%3AMEBIDX%3AIT
Old 03-09-2015, 02:22 AM   #14
Tree-50
Doesn't mcgaughy have a 63-70 drop/stock spindle 5x5 and 6x5 setup? I just bought the 6x5 for my 68
Idk about spindles though if c10=c20
Basic 12" 5x5
http://www.mcgaughys-suspension.com/...ys-part-63156/
63-70 drop spindle used that year ball joints and tie rods.
http://www.mcgaughys-suspension.com/...ys-part-63173/
13" upgraded 5x5 kit drop spindle included
http://www.mcgaughys-suspension.com/...ys-part-63151/
Tree-50 is offline   Reply With Quote
Old 03-09-2015, 04:19 PM   #15
rodzilla67
Tree-50, thank you so much for the links and tips. If I can figure out if I can use C-10 spindles on a C-20 I'll be ready to go! lol
Old 03-10-2015, 08:19 PM   #16
rusty18
rusty18's Avatar
Rodzilla67,
Lots of info on front changeout.
What is your plan on converting the rear end to 5 bolt?
rusty18 is offline   Reply With Quote
Old 03-10-2015, 09:35 PM   #17
rodzilla67
Originally Posted by rusty18 View Post
Rodzilla67,
I planned on changing the axles. I assume this is a reasonable method? Also still wondering if I can use c10 spindles on a c20?
Old 03-10-2015, 09:50 PM   #18
lolife99
67-72 parts collector,…
lolife99's Avatar
Yes and No.
3/4 ton lower a--arms have a larger balljoint hole.
You will need 1/2 ton lower a-arms and you will have to switch to 1/2 ton balljoints and outer tie rods.
Simpler choice is to use the "3/4 to 1/2 ton CONVERSION spindles" offered by ECE.
Keith
Convert to disc brakes.
Old 03-10-2015, 09:51 PM   #19
lolife99
lolife99's Avatar
C20 spindles are TOTALLY DIFFERENT than the C10 version
Keith
Old 03-10-2015, 09:52 PM   #20
lolife99
lolife99's Avatar
X2
Best option to convert an 8-lug truck to 5-lug
Keith
Old 03-10-2015, 10:14 PM   #21
rodzilla67
Ty Lolife. Awesome info!
Old 05-08-2017, 08:59 PM   #22
goldenC20
goldenC20's Avatar
Where did you find the 2-inch lowering blocks and did they come as a kit with the longer u-bolts?
goldenC20 is offline   Reply With Quote
Old 05-08-2017, 09:11 PM   #23
bbbc10
Diggin The SquareLife
Just use google man not that hard
bbbc10 is offline   Reply With Quote
Old 05-08-2017, 09:20 PM   #24
lolife99
lolife99's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=196457
http://67-72chevytrucks.com/vboard/s...d.php?t=454824
Here's a couple good threads to look at.
Member way2lo2 is a good source for lowering blocks and u-bolts.
Keith
Old 05-08-2017, 10:16 PM   #25
csfields
csfields's Avatar
I got mine from CPP. They did include the longer U bolts and nuts.
Thanks,
Casey
