#26 |
Re: Project 59 Fleetside
#27 | |
If I recall, bottom of rocker panel is approximately 4" lower than the frame rails. Side frame rails under the cab approx 10"-12" from the ground would put the rockers around 6-8". |
#28 | |
![]() ![]() Your youtube link is on private? I wanted to hear your 500+ HP engine you call not very impressive... I hope to get around 180 Hp on a stock 350 ![]() ![]()
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
#29 | |
Your 496 (based on the dyno info) looks real strong for a street motor and should be alot of fun. The reliability will be based on what parts you used and who put it together. But looks like it will work good for you. I posted up some more info and pics on my boat and my 496 engine info on my build page so it didnt clutter up your build page, so check it out there on post #157
My Build: 57 Chevy Pro-Street |
#30 |
![]() Join Date: Jul 2012
The video clip was marked private when I clicked on it. I really like the looks of the accessory drive and I haven't seen that company before. Will have to go check them out.
#31 | |
I know I am taking a risk here but I spent countless hours looking at this and drawing it multiple times in CAD and think I can make it work. If not I'll just regroup. This truck was running this size wheel and tire at one time I believe. http://image.trucktrend.com/f/754902...ache-front.jpg |
#32 | |
I fixed the youtube link. I think... Are you going to keep your truck blue in color? |
#33 | |
Here is the link for Jones Racing Products (The company I purchased the accessory drive from) http://www.jonesracingproducts.com Click on the 2015 Catalog button on their homepage and look at all the cool stuff they offer. Call them up too. They are very nice and helpful guys that go out of their way to make sure you get what you need. |
#34 |
Engine sounds...and looks...awesome! Thanks for the Jones catalog link. Gotta look at their LS components.
#35 | |
![]() ![]() Mine is going to be semi gloss black with high gloss red. It would have been different if it was the original color, but the blue was a really bad overspray. In the Netherlands, at least in my youth, we learned English, German and French in school, but that was some time ago ![]() ![]()
#36 |
Here are the bed sides and some of the other sheetmetal before and after sandblasting and epoxy primer
#37 |
These pictures show what was waiting under the old paint and scale. As you can see I made a few too many rookie mistake when picking out this old truck
#38 |
Here is the way I transported the cab back to my house from my buddies shop. Not sure how many guys have ever done this but it worked great for me.
Should have taken the cab straight to the scrap yard but it stayed at my house for a little while. |
#39 |
Did some searching on craigslist and was able to find a cab in better condition. It was in VA about 4 hours away but originated in Arizona and was in fare shape with respect to rust. It even came with some paperwork....
#40 |
Here some of the sheetmetal replacement on the new cab.
#41 |
This was the aluminum block LS engine I was going to use before changing my mind and deciding to go with a Big Block 496
#42 |
Cool build. I love the 58-59 fleetsides. I have a 62 I am building now, but I really want a 59 long bed after this one is done.
84 GMC One ton 4x4 454 4 speed 62 Chevy C10 short fleet plus about 13 previous gm trucks from 1960 to 2000 |
#43 |
Nice work so far! The frame really looks good! I definitely like the look of the rims. I've been looking at those myself. Good luck with the rest of the build. I will definitely be watching your progress.
#44 |
![]() Join Date: Jan 2016
A question I have.When I was putting the motor in my 58,I needed to level the motor and trans before I installed the mounts,I put level on manifold where carb goes,and noticed the manifold there the carb mounts tilts forward and cat level it from there or motor will tilt back.where do I put my level?
#45 | |
#46 | |
It's learning about all these details and importance of them that makes this stuff fun! |
#47 | |
#48 |
I am new to this forum. And don't know how to find different post. Today I think I will try and install motor parallel with frame
Posted via Mobile Device |
#49 |
Looks like you're making good progress.
Cool to find a better cab than you started with. Kim |
#50 |
Bummer on your first cab!
You're lucky to find parts for these trucks. Overhere that's almost impossible, or at a price that is a mile high!
