Old 12-03-2015, 10:08 AM   #326
wjjeeper
wjjeeper's Avatar
Re: Post Pics of your Static Drops!!
Updated pic. Still the same drop.
Follow me on Instagram
http://instagram.com/ryno._b
wjjeeper is offline   Reply With Quote
Old 12-03-2015, 10:31 AM   #327
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Originally Posted by dwcardfan View Post
3/5 spring drop with 18's
Most the time, when I see the bigger wheels on these trucks, it doesn't really look right to me.
The stance you have with those 18's - I like the whole look.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-03-2015, 02:39 PM   #328
dwcardfan
dwcardfan's Avatar
Thanks Lost.
dwcardfan is offline   Reply With Quote
Old 12-03-2015, 02:45 PM   #329
schpeen
schpeen's Avatar
The stance you have with those 18's - I like the whole look.Thanks Lost.
x2 I am running 15" rims
no one did that back in the day which is why it looks funny sorry to those who like the look! same goes for the trucks that sit lower in the back than the front!
sorry am i am showing my age here???
schpeen is offline   Reply With Quote
Old 12-03-2015, 06:40 PM   #330
That would be me too.
Old 12-03-2015, 07:20 PM   #331
The Rocknrod
Moderator
The Rocknrod's Avatar
+2
Old 12-22-2015, 01:58 AM   #332
Slambone
Slambone's Avatar
6/9 drop! 3" drop coils in front with a coil and a half cut and 5"drop coils outback with 4"blocks.
http://https://www.flickr.com/photos...posted-public/
Slambone is offline   Reply With Quote
Old 12-22-2015, 02:40 AM   #333
goatless
goatless's Avatar
https://www.flickr.com/photos/138860...posted-public/
Slight correction to the link above. Nice truck, too!
1964 C10 LWB->SWB, 283->454, SM420->200-4R
MECHANIC: "ME"
goatless is offline   Reply With Quote
Old 12-28-2015, 07:31 PM   #334
Evoracer
Originally Posted by C/10 King View Post
My 64' Seahag (w/63' grill) ...... cut coils in the front plus 5 inch dropped coils with 2 inch blocks in the rear.
It appears that you have 15" wheels, how close are you to the scrub line with 2 inch blocks?
Evoracer is offline   Reply With Quote
Old 12-28-2015, 07:43 PM   #335
Slambone
Slambone's Avatar
Old 12-28-2015, 07:50 PM   #336
TexasSixtyFourSW
TexasSixtyFourSW's Avatar
3 inch drop coil with 2 inch modular spindles up front
5 inch coils in back
TexasSixtyFourSW is offline   Reply With Quote
Old 01-23-2016, 10:25 AM   #337
Backpayne
I have only had my '64 for a month and plan on lowering the rear a little more. Rear tires are around 27.5" on 15" wheels.
I know it has drop spindles on front but don't know if anything has been done to the rear.
Backpayne is offline   Reply With Quote
Old 01-23-2016, 12:22 PM   #338
Jferrante
Jferrante's Avatar
Here is mine - just put new rear shocks in (belltechs) and rear shock relocators since the ride was bumpy. Still a little rough so might need to do blocks and proper springs. Will take pictures to help clarify it looks like t=just cut springs causing this.
Jferrante is offline   Reply With Quote
Old 01-23-2016, 07:51 PM   #339
Jferrante
Jferrante's Avatar
looks like stock arms due to the crud buildup but I may be wrong, this would mean I have lowering springs up front? If so I would like to do it proper with drop spindles at some point - anyone see something different?
Old 01-25-2016, 01:03 PM   #340
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks like stock arms and spindles in the front along with stock CUT springs. Based on the what I see in the photos, I don't think anyone put dropped springs in the front.
It does look like it could use a good scrubbing...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-25-2016, 01:45 PM   #341
Jferrante
Jferrante's Avatar
haha thanks - posted this in the general section as well and got similar response. I am guessing a proper drop spring would make the ride better or no?
Thanks again
Old 01-26-2016, 01:16 AM   #342
OsOdeDIABLO
OsOdeDIABLO's Avatar
2 coils cut in front, cpp 5" rear coils, 215 75/15s in front , 235 75/15s in the rear. Jimmy
NOMADSC.C.
OsOdeDIABLO is offline   Reply With Quote
Old 01-26-2016, 01:08 PM   #343
zach_carver
zach_carver's Avatar
I love this stance!!! Looks like I need a bigger drop in my rear. I have 6" springs with 2" blocks.. I need some more drop. Beautiful truck man!
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 01-26-2016, 04:03 PM   #344
suburban99
suburban99's Avatar
62 with a 78 disc front end, LS/4l60E swap.
4" lowering coils in rear, 2-1/2" drop spindles with 1-1/2 coils cut...
Tires are rollers (junkie) maybe some knows the amount of drop for 1-1/2 coils?
suburban99 is offline   Reply With Quote
Old 01-27-2016, 11:53 AM   #345
veltex
veltex's Avatar
2 1/2" drop spindles - 1" springs, 4" drop leaf. 215/75/15 on 6's, 235/75/15 on 8's
beater 65 gmc at the moment
veltex is offline   Reply With Quote
Old 01-27-2016, 12:53 PM   #346
60-66
60-66's Avatar
I like it !
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 02-04-2016, 01:35 AM   #347
chopper john
chopper john's Avatar
my 65 big window
chopper john is offline   Reply With Quote
Old 02-04-2016, 02:36 AM   #348
Slambone
Slambone's Avatar
Thank you!
Old 02-04-2016, 01:03 PM   #349
forestb
forestb's Avatar
Originally Posted by chopper john View Post
my 65 big window
WOW! If that is a static drop you are a braver man than I
forestb is offline   Reply With Quote
Old 02-04-2016, 01:10 PM   #350
goatless
goatless's Avatar
Hey, what size are those tires and wheels? I'm in the market, and am trying to get some ideas. Thanks.
MECHANIC: "ME"
