#276 |
![]() Join Date: Jul 2012
Re: 1961 Crew Max
Man that looks good! Where did you get the tubes?
#277 |
SAVING ONE TRUCK AT A TIME
![]() Join Date: Feb 2010
Re: 1961 Crew Max
The boost tube kit was a universal aluminum kit from ebay. It came with everything needed and was more than enough. We used 3" cast aluminum 90's at the intercooler and tig'd it all together. It was thicker tubing at 2mm. I then ordered separate hump style silicone couplings to make the connections at the intercooler and turbo. The lower water hose is cast aluminum 90's with a piece of 2" aluminum piping.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
#278 |
Re: 1961 Crew Max
Very Nice work.
1987 GMC R2500 SC 454 T400 1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors |
#279 |
![]() ![]() Join Date: Oct 2011
Re: 1961 Crew Max
Nice progress!
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#280 |
Re: 1961 Crew Max
The pipes look great. Will the hump style couplings give enough flex for the vibrations? The inner fenders like that will give you a great spot to put tools when working on the truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#281 |
Re: 1961 Crew Max
I believe the hump style couplings will give the piping some room to flex. yes A flat style raised inner fender will be a nice area to set random stuff when working on it. Beer,tools.
#282 |
Re: 1961 Crew Max
Looks super!
Cant understand how you can have more room for the brake MC than I have though :-) I actually bought the same Wilwood unit. I'll make it fit. /Thomas
1965 c10 BBW LWB - Duramax 2010 Camaro SS - Whipple (721hp) 2017 Volvo V60 diesel-hybrid (233hp) 2008 volvo XC70 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=677577 |
#283 |
Re: 1961 Crew Max
Is your D-max from a van? That would explain less room as everything is coming forward from the back of the motor. If the only thing in the way is boost tube and maybe glow plug module then just relocate as needed. Build is looking great. Just make it fit.
#284 |
Re: 1961 Crew Max
Yes I have a van engine. LBZ from 2007.
#285 |
Re: 1961 Crew Max
Some progress from today. Got new front fenders at portland swap meet for $350 last weekend. Overall fit is pretty good at door jams. Had to cut front of passenger rocker as it was sticking out to far for alignment. Only areas that will need some massaging are front lower corners were they meet the core support. I think we might weld the seam at the front between the edge of the grill and fender. The pinch welds are not great were they joined the two pieces. Also tried to fit the hood I planned on using and the back brace is really bent like someone was standing on it. Option either cut a brace out of another hood I have or find another hood. It has very little rust but has dents. Thanks CHIZZLER.
#286 |
Re: 1961 Crew Max
That was a nice score on the fenders and a pretty decent fit too. Truck is looking good Chizzler.
#287 |
Re: 1961 Crew Max
Looking good ,staying tuned in .
#288 |
Re: 1961 Crew Max
Well that worked out pretty good.
#289 |
![]() ![]() Join Date: Jul 2002
Re: 1961 Crew Max
Those came out looking good one there.
#290 |
Re: 1961 Crew Max
Look's good . Great find at Portland. I also scored there.
The Snortin' Bull |
#291 |
Re: 1961 Crew Max
WOW just went through your build and one word (AWESOME).. Takes a lot of creativity to tackle something like that, awesome sheet-metal work.. I'm usually not a big fan of lowered trucks cause I like the 4x4's but that is going to be a one of a kind custom truck.. and I also love your garage the outside of it with the ole barnwood...and the corrugated metal at the bottom..I'll be watching this build....
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#292 |
Re: 1961 Crew Max
Made some progress over the weekend. Got the 14 bolt sf back from being narrowed. Had it cut down to 60" with the brakes. Went pretty smooth using captain fab's weld on trailing arm mounts. Great fit. Only thing we had to do was cut the PB lower shock mount bar and bend a new piece and weld it back in the middle. Pumpkin size is bigger and was hitting. Fuel tank will be next and going to replace the back frame section with some 4x3 steel and connect the back together. I was able to send the axles to dutchman and have them cut down and re-splined. Thanks CHIZZLER
#293 |
Re: 1961 Crew Max
Diff looks really good sitting in there. Your lucky you could shorten the shafts, I had to buy custom. How big is your fuel tank?
#294 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 1961 Crew Max
Nice work!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#295 | |
Re: 1961 Crew Max
Thank you.
#296 |
Re: 1961 Crew Max
looking sweet man!
1961 c10 longbed - gone 1964 c10 swb |
#297 |
Re: 1961 Crew Max
#298 |
60-66 Nut
Re: 1961 Crew Max
Did they just cut and weld the axle tubes in between the center section and the backing plate flange?
#299 |
Re: 1961 Crew Max
Nice progress, lookin' good. Very cool
The Snortin' Bull |
#300 | |
Re: 1961 Crew Max
Thank you.
