Old 07-25-2016, 03:46 AM   #326
tinydb84
tinydb84's Avatar
Re: Used Parts Build
This was my weekend.
I'll post up a bunch of pics tomorrow. I'm beat.
David
Instagram: myfabguy
Old 07-25-2016, 04:45 PM   #327
tinydb84
tinydb84's Avatar
Here are the pics and write up from this weekend: http://www.67-72chevytrucks.com/vboa...d.php?t=713378
David
Instagram: myfabguy
Old 08-01-2016, 01:22 AM   #328
tinydb84
tinydb84's Avatar
Got this on Friday
They have a 30 day rent back. So I wont be moving in for a month. Which also means I need to get my truck a roller in 30 days.
David
Instagram: myfabguy
Old 08-01-2016, 01:23 AM   #329
tinydb84
tinydb84's Avatar
Got my bed assembled and on the truck
Started making the mounts
Lots of props and clamps
Got four done before it got too dark and ran out of steel.
David
Instagram: myfabguy
Old 08-01-2016, 01:52 AM   #330
DblTrbl
DblTrbl's Avatar
Looking great man! ����
83 Crew Dually build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=686192
Instagram: lofab77
DblTrbl is offline   Reply With Quote
Old 08-01-2016, 06:43 AM   #331
rip2174
nice work.
rip2174 is offline   Reply With Quote
Old 08-01-2016, 08:30 AM   #332
Joe Pass
Joe Pass's Avatar
congrats on the house...nice work
Joe Pass is offline   Reply With Quote
Old 08-01-2016, 01:45 PM   #333
daddyjeep
daddyjeep's Avatar
Congrats on the house.
remind me...you cut down a long bed right? Are you not cutting the 6" off of the back of the bed?
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 08-05-2016, 10:06 PM   #334
tinydb84
tinydb84's Avatar
Originally Posted by rip2174 View Post
nice work.
Thanks guys. I cut down a long bed but took all 20 inches from the front and left the rear long.
David
Instagram: myfabguy
Old 08-05-2016, 10:07 PM   #335
tinydb84
tinydb84's Avatar
Making more mounts
The idea
Cut. The other pieces are to support the 4 link crossmember.
Holes drilled
Bought a new tool. Need to weld some braces to it and build a stand
David
Instagram: myfabguy
Old 08-06-2016, 12:38 AM   #336
SkinnyG
SkinnyG's Avatar
SWEET!
Reinforce the frame (the arms want to splay)
Also make a wheel for it, instead of a crank. I bent 1" 16ga tubing around an S10 rim, and made spokes out of 3/4". Steering wheels work well too.
Got a skateboard wheel? I made a tipping wheel with a Princess Auto (Harbor Freight) sprocket with the teeth ground off.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 08-29-2016, 05:53 PM   #337
tinydb84
tinydb84's Avatar
Originally Posted by SkinnyG View Post
SWEET!
started bracing it. Need to get a steering wheel still. Good idea for the tipping wheel. Do you know anyone who makes extra dies for it?
David
Instagram: myfabguy
Old 08-29-2016, 05:54 PM   #338
tinydb84
tinydb84's Avatar
Filled a bunch of holes on my tailgate:
Got my bed mounts done:
Bed is all bolted on and together. Made some shims to get it to the proper height. Didn't get any pics though. Then this happened:
Grinding some metal and had a bit get behind my safety glasses. By the way they use a bur to remove the rust ring that forms where the metal was.
David
Instagram: myfabguy
Old 08-29-2016, 05:55 PM   #339
tinydb84
tinydb84's Avatar
Been trying to get the truck together enough to tow it to my new place.
And I had to puppy sit this guy again
Anyway, on to the truck stuff. Got my steering all together.
I went to put a set of wheels on that I got as take offs from the Cannonball C10 but they were too wide and the backspacing wouldn't let me even get the wheel on the lugs. I pulled a wheel off my 66 just to give me an idea of what wheels I can run. I am probably going to get some inexpensive steel ones just to get me rolling.
These wheels are 205/60/15 so they are only 26''. I am probably going to run a 235/65/17 to give me a 30'' tire (which I should lay out on).
David
Instagram: myfabguy
Old 08-30-2016, 09:29 AM   #340
aggie91
I'm just glad to be here!
aggie91's Avatar
Congrats on the new place!
I have been to the eye doctor to many times for my own good to get metal and rust out of my eye. Its not real fun, but the tools are cool!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 08-30-2016, 09:56 AM   #341
68Timber
I know the pieces fit
68Timber's Avatar
I had a co-worker once that had previously worked as a welder, he said he got stuff in his eyes pretty often. He said they'd put a Q-tip gently against the eye next to the metal and twist it slowly, the fuzz would grab the metal and pull it out. It's no substitute for professional medical treatment, but might help in a pinch. Congrats on the house.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-30-2016, 12:55 PM   #342
daddyjeep
daddyjeep's Avatar
I had my right eye removed. Now I am 50% less likely to get metal in my eye.
Because of that, I wear glasses with the foam around them to make a good seal and also use a shield whenever possible. When you only have one left you need to take care of it.
04 1500 crew cab
Old 08-30-2016, 03:53 PM   #343
SkinnyG
SkinnyG's Avatar
I think Eastwood sells fancy dies for the same machine. The dies yours and mine come with are really just for rolling beads. Eastwood has fancier.
I have a lathe, so I tend to make my own
Old 08-31-2016, 09:37 PM   #344
68Timber
68Timber's Avatar
Doc let you have the 8-ball eye?
John
74 Honda Z50 build
Old 08-31-2016, 09:57 PM   #345
daddyjeep
daddyjeep's Avatar
I hope he does. I get the new eye on the 12th.
04 1500 crew cab
Old 09-01-2016, 01:57 PM   #346
tinydb84
tinydb84's Avatar
Thanks! Not fun. I hope I never have to do it again.
That's actually what they did (after they numbed it). They had to use a bur to remove the rust that formed on my eye though.
I bought a full shield helmet for grinding and cut off wheels now. I prefer glasses but think I will use the helmet for this stuff.
I want a lathe so bad. My brother runs a high end machine shop but wont let me use the tools...
That would be pretty damn cool.
David
Instagram: myfabguy
Old 09-01-2016, 02:09 PM   #347
tinydb84
tinydb84's Avatar
I epoxy coated my garage floor last night: http://www.67-72chevytrucks.com/vboa...d.php?t=716686
David
Instagram: myfabguy
Old 09-11-2016, 11:27 AM   #348
Ivybilt
Sweet build and very informative! I'm anxious for you to start on your 66. I have a 63 I need ideas for.
Ivybilt is offline   Reply With Quote
Old 09-12-2016, 12:12 PM   #349
tinydb84
tinydb84's Avatar
Thanks. I want to start on my 66 but don't have the space to work on two at the same time. I have a couple ideas for the 66 but don't really have any plans for it yet. I really want to sit down and plan it out so I don't end up redoing a bunch of crap like I did on this one.
David
Instagram: myfabguy
Old 09-12-2016, 12:12 PM   #350
tinydb84
tinydb84's Avatar
And she is holding her own weight!
Need to cut my fenders and bed to air down completely but she rolls! We kinda... The back driver wheel seems to be dragging on something. Not sure if it is the caliper or something else but its good enough to trailer it over to my new place.
David
Instagram: myfabguy
