#351 |
Re: Project Beatrix
Just some random pictures of where she sits today. Still working on the cab, and bed. On top of getting my fuel system buttoned up and turbo manifold built. Like a never ending list of things to do!!!!
![]() ![]() ![]() My buddy that painted my valve covers thought it would be funny to metal flake the inside of them!!! ![]() ![]() ![]()
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
#352 |
Re: Project Beatrix
Looks great keep up the good work
#353 |
Re: Project Beatrix
#354 |
Re: Project Beatrix
Engine looks good!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#355 |
Re: Project Beatrix
Thanks Duane, hopefully I will have the cab finished before the spring and ready for some paint to make it look as nice as yours!!!
#356 |
Re: Project Beatrix
WOW! that's awesome work. you're running a 4l80e? how long is your front drive shaft? mine looks like it's going to be very short as well...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#357 |
Re: Project Beatrix
Thanks Moose. Ya it's an 80e 2.5 diameter shafts. Front is about 17.5 inches and rear is 35 inches. The slip yoke is an out 6 inches. Works perfect for my setup.
#358 |
Still Learning
Re: Project Beatrix
Awesome work Brandon! This puppy is gonna be too nice to drive
#359 |
Re: Project Beatrix
Thanks Mike, trying to get this thing in paint by late spring so I can actually enjoy it!!
#360 |
![]() Join Date: Dec 2012
Re: Project Beatrix
I love how everything is so clean and sanitary..You do very nice work!!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#361 |
Re: Project Beatrix
Thanks Mike, its my OCD kicking in hard on this project!
#362 |
![]() Join Date: Dec 2006
Re: Project Beatrix
Wow that motor and trans look amazing Brandon, love the detail.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#363 |
Re: Project Beatrix
Thanks Keith. You back on your feet again?
#364 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: Project Beatrix
I really like the contrast there. That is funny on the metal flake.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#365 | |
Re: Project Beatrix
#366 |
Re: Project Beatrix
Your friends sound like my friends do
#367 | |
Re: Project Beatrix
![]() ![]() ![]() Oh, and thanks for your help with the wiring on my swap. You've been my biggest help and I appreciate all of your guidance.
#368 |
Re: Project Beatrix
Yeah, been rehabbing the knee for the past 2 months. Had a minor setback but not a big deal. Haven't been able to work on the truck yet, hopefully soon. Thanks for asking.
#369 | |
Re: Project Beatrix
Good to hear, I thought I was the only one with a55holes friends
![]() Quote:
![]() Man 2 months would drive me nuts but i'm sure the end result will be worth it.
#370 |
Re: Project Beatrix
Cool build! subscribed!
72 GMC highlander nicknamed by my then 6-year-old brother "stripes" http://67-72chevytrucks.com/vboard/s....php?p=7378180 Check out my Youtube channel @Chad's Fab |
#371 |
Re: Project Beatrix
Started buttoning up so little things on the truck this weekend while the weather was abnormally nice here in Michigan.
Had a buddy come by and help me get my fuel lines started. Feed is done and return will be done today. 5/8 feed and 1/2 return. ![]() ![]() Also dropped the pressure in my power steering pump to work with the Mustang II rack using the Borgeson kit. ![]() ![]() ![]() Stock washer on the bottom, Borgeson on the top ![]() Got the pump back on the block and made 2 AN lines for the feed and return. ![]() Also started rebuilding my vent windows. This is what I started with. Pretty beat up, lower pivot was broken on one frame and the glass in both was from the 68-72 trucks. ![]() Fixed the frames and had them powder coated also ordered the Precision seals from GMC Pauls. ![]() ![]() Now I am just waiting for the glass shop to finish cutting the new glass to finish them up. The seals weren't fun but with a little patience they went in. I will say that the tool for the factory rivets that comes with the kit is only useful for the hinge rivet. The flat seal where the rest of the rivets are doesn't allow you to get a good hit on them because it is too wide. I ended up cheating and used pop rivets for this piece as I am not concerned with look over function ![]()
#372 |
Re: Project Beatrix
#373 |
Re: Project Beatrix
Can I ask where you bought the valve covers? Did you have to do any modifications to them?
#374 |
Re: Project Beatrix
I bought them through Summit.
https://m.summitracing.com/parts/amd...uBMaApIT8P8HAQ As for modifications I added an oil fill bung and cap and 2 -6an fittings for the pcv system. If you want more info let me know.
#375 |
Still Learning
Re: Project Beatrix
Everything looks great Brandon!
