04-21-2017, 10:53 AM | #501 | |
Re: What did you do to your Blazer/Jimmy today?
04-21-2017, 07:13 PM | #502 | |
Much safer having something over my head when the top is off.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
04-21-2017, 07:42 PM | #503 |
Shot a coat of raptor liner on the frame. Used two bottles but sprayed it with an hvlp gun instead of the shutz gun. I didn't thin it at all and it sprayed on fine. I like how the texture came out. If you held the gun close it left a smooth surface almost like paint but backing up a few inches gave it a nice even texture. Looks sandpaperish but still feels smooth. Kinda wish I did the underside like that now.
04-23-2017, 12:15 AM | #504 |
New crate motor. Just a plain Jane 350. I already miss my stroker...
'72 K5, known as 'the Fox.' |
04-23-2017, 08:01 AM | #505 | |
i can really appreciate what you're doing |
04-23-2017, 08:36 AM | #506 |
Took her for a drive with the pups
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
04-23-2017, 08:54 AM | #507 |
I got the roll bar placed and all tacked up and ready to finish weld....
my dogs hung out in the back. Before I could take it back out..I had to take them for a ride...hahaha ready to do the finish welding...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
04-23-2017, 09:00 AM | #508 | |
Also plan on drilling some small holes to fish a wire up from the bottom to the top of the bar......I want to put in some small LED interior lights that will come on with the courtesy lights under the dash.....
04-23-2017, 10:36 AM | #509 | |
Dave
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
04-23-2017, 11:02 AM | #510 | |
Hi, I bought the truck from HUGGER*(USMC to USN! ) about a year and a half ago. Great guy, unfortunately his health wasn't the greatest so my son and I flew to Phili to purchase the truck. Most of the build is posted on this site too! |
04-23-2017, 11:07 AM | #511 |
Nice, I don't know where I'm going to end up remounting mine. Right now, it's in the rear mid section housing stereo equipment (I cut 6.5 JL's in the sides with a remote Pioneer TV unit embedded) and I have brand new black spare console in case I want to switch back.
04-23-2017, 11:11 AM | #512 |
Trim looks great on these blazers. I'll measure 5 times just to be sure! Did you repaint the holes in the area you drilled?
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
04-23-2017, 11:14 AM | #513 | |
Nice blazer, treat her well, Rg
04-23-2017, 11:27 AM | #514 |
What did you do today?
The OG gas pedal broke a few grocery store trips ago and now I'm just stepping on the "stick." I've got a new Lokar pedal and measuring for fit now. Seems like I'm going to end up mucking with it all the way to the carb. |
04-24-2017, 06:53 AM | #515 |
A week ago I was in the Blazer on my way home from a car show and smelled coolant.. and noticed the temp. gauge was a little above 200*. It never runs hot. I found the radiator had split a solder seam between the core and the tank on the pass. side. I got the repaired radiator back on Fri. from the shop... $95. Radiator looks nice. I cleaned & painted a little on the rad. support yesterday and set the shroud and radiator back in. Looked at the hoses & decided to replace 'em, - they're 5+ years old. Belts are old too, but look fine. Off to the auto parts store after breakfast with a couple of other old truck geezers I hang around with, both have pretty nice '51 Chevy trucks. I'm the "youngster" at 65.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
04-24-2017, 10:00 AM | #516 |
Scored some 15x8 slotted mags of good ole Craigslist! 50$ for all 4!!! just a little simple green goes a long way
04-25-2017, 11:48 AM | #517 |
I had a set of those wheels on a brand new '72 Cutlass. First time I replaced tires on the car the mounting machine busted about a quarter of the rim off the inside of one of 'em. Still remember the funny noise it made. 'Course the wheels were out of stock, so I rode around on the mismatched spare for about 3 weeks.... Thanks for the memories Lieferson
04-25-2017, 10:09 PM | #518 | |
Also cut the drum brake mounting brackets off my 14 bolt. Going to weld on some brackets to accept the rear discs from the gmt800 trucks. |
04-27-2017, 01:19 PM | #519 |
Got the frame already for the motor and trans.
04-27-2017, 02:56 PM | #520 |
Frame looks good. Almost have mine finished up. Trying to get paint on everything can be a pain, have to go it each spot from 10 different angles. Seems like every time I look at mine I see a crevice somewhere that I didn't get coated.
04-27-2017, 05:03 PM | #521 |
A bath, to knock the winter dust off. Leaving shortly to take a herd of 7 yr. Olds to soccer which is the BeSt part of the day.
05-01-2017, 12:52 PM | #522 |
My old high school had a car show fund raiser this weekend so I drove down and showed her off.
05-01-2017, 01:16 PM | #523 |
05-01-2017, 01:17 PM | #524 |
05-01-2017, 01:19 PM | #525 |
Motor is almost already to drop in.
