Old 09-19-2017, 09:01 AM   #751
oldman3
oldman3's Avatar
Re: 1956 Chevy Pro-Street Build
Says I'm not in a group, so I can't see it...Jim
oldman3 is offline   Reply With Quote
Old 09-19-2017, 01:49 PM   #752
ptc
ptc's Avatar
Sorry Jim - -had to make it a PUBLIC post ---- try it now.
https://www.facebook.com/paul.christ...8155982304738/
thanks
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 09-19-2017, 02:31 PM   #753
Black_Sheep
Black_Sheep's Avatar
Sounds good and rowdy Paul! Congrats...
Black_Sheep is offline   Reply With Quote
Old 09-19-2017, 04:00 PM   #754
BAM55
BAM55's Avatar
Great job it sounds really healthy.
BAM55 is offline   Reply With Quote
Old 09-19-2017, 07:08 PM   #755
oldman3
oldman3's Avatar
Got it now, and you are correct it sounds ANGRY...Jim
Old 09-19-2017, 07:42 PM   #756
Kim57
Kim57's Avatar
Sounds great.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 09-19-2017, 10:07 PM   #757
Rickysnickers
Marvelous!!!
Old 09-19-2017, 10:57 PM   #758
mongocanfly
mongocanfly's Avatar
ABREED!!!!!!!!! sounds awsome!!!!!!
Old 09-19-2017, 11:21 PM   #759
Dan in Pasadena
Dan in Pasadena's Avatar
She's a mean sounding beast! Daily driver, huh?!
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 09-19-2017, 11:53 PM   #760
mud.man.rj
mud.man.rj's Avatar
Just plain nasty, love it.
Mudman.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline   Reply With Quote
Old 09-20-2017, 02:47 AM   #761
Nut Case
Nut Case's Avatar
ptc
The national earthquake center reported a disturbance in the force about the time you started that fire breather. MUUUUUMMMMMMM
Strong work
You have 6, 2" gauges, what are they? Fuel, oil pressure, volts, and gas---
Keep on keepin on
NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 09-20-2017, 07:46 AM   #762
lower50's
lower50's's Avatar
Oh sooo gooood!! I love the idle when you can count the 4 on each side.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 09-22-2017, 07:00 PM   #763
ptc
ptc's Avatar
Thanks all.... its been a long hard row to hoe.... but its very close now. The brake pedal system is becoming a head scratcher for me because that one system has to WORK BETTER THAN ALL THE OTHERS.... or theres gonna be trouble. Im gonna take the whole assembly down to a machine shop and see what they can design that can go back in easy enough. Would a slave cylinder have enough pressure to push that booster rod ? or would it be just full ON and full OFF?
The P/S psi line is also a problem, it has blown the -6AN line off the psi side of the pump twice now. I think its blowing under higher revs. These are good Earls type hose ends, and the second time I put the hose together I made sure it bit good and hard so I dont know quite what is happening there. Just wondering if the hydroboost is messed up or something.
NUTCASE --- the small gauges are 2 1/16" dia. and they are VOLT, WATER TEMP, OIL PSI, OIL TEMP, FUEL LEVEL and ---- BOOST!
anyway ---- still working it.... Thanks again!!
Old 09-22-2017, 07:26 PM   #764
idbeast
[QUOTE=ptc;8038156]Oh well dont need brake lights anymore cause I just broke off the brake pedal assembly.... can you say MAJOR SETBACK!!!! --- this thing is ready to run! and no brakes!!!
Remember this custom thing I made out of a Wilwood multi-res assembly to go under my floor?
Well I just snapped the end of that long 1/2" bolt off that pushed the ram into the booster. I guess Im just gonna have to take the whole thing out and start over with a different idea.... tear up the firewall again and weld in
some type of STANDARD brake pedal assembly like regular "white-folk" do..... instead of this redneck backyard mechanic stuff!
oh well.... thank God - good thing it happened now instead of out on the street!!!!
I need a vacation --- think I'll go to Florida!
Okay so this is what I essentially made (from scratch)
This is an $80 Porsche clutch lever.....
I used just a 1/2"-13 Bolt black steel and then I had to drill and thread 1/4-20 "pins" on either end for the pedal and the lever. So I removed 50% of the bolt material on both ends
and thats why it failed right at the 1/4" threaded hole on the lever end.
QUOTE]
ptc, use a pillow block bearing bolted to a plate and mount it under all 4 bolts of your bracket, to support the brake pedal shaft, you are sticking out way too far unsupported!
idbeast is offline   Reply With Quote
Old 09-22-2017, 07:47 PM   #765
MIKESAD50
What type of hose and fittings?. I used a Detroit speed hose my and it's got different fitting and hose than a standard -6 hose
Truck is looking good and hope you can get a linkage for brakes worked out.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 09-22-2017, 07:57 PM   #766
MIKESAD50
you need a fitting with a ferrell that goes on the outside of the hard line in the center.
1950 3100 5 window
Old 09-26-2017, 05:55 PM   #767
ptc
ptc's Avatar
Yep Im using the braided 'soft' lines that are black nylon braid with rubber internal. The fitting I found on there is a crappy Summit chinese thing... see photo below. I guess it wont hold, it just doesnt crimp the line on there tight enough I guess. Im gonna go down to Parker and have them crimp me a custom line in their hydraulic press hose maker.... done with this!
The brake pedal thingy is going to be a whole 'nother project. It was just to move it on the left side of the steering column where the clutch used to be. I should have left the clutch assembly in the frame!
Im thinking I may go with flanged bearings, like this:
and drill a hole in the frame rail and run a shaft right thru from pedal to lever, key it, bolt it. IDeas? Comments?
Old 09-26-2017, 07:00 PM   #768
idbeast
That should do the trick, in the industrial world it is a common practice to use the flanged bearing for support! It most likely will need a key to keep the arm in position.
Old 09-26-2017, 09:24 PM   #769
Black_Sheep
Using flanged bearings is a great idea, you can kind of replicate the wildwood mounting plate with a bearing on each side and a transverse shaft. It's not hard to find steel and stainless steel keyed shaft online, keyed collars are available too.
http://www.surpluscenter.com/Power-T...-2982-50-3.axd
http://www.surpluscenter.com/Brands/...r-1-1563-A.axd
Old 09-27-2017, 07:50 AM   #770
lower50's
lower50's's Avatar
I would go with non swivel flanged bearings. It will help keep the shaft straight.
1951 MG TD
Old 09-27-2017, 11:39 AM   #771
ptc
ptc's Avatar
Thanks for the links! --- Yea thats kinda what I was thinking and we have all that available for our v-drive boat stuff using some pretty nice steel types. All the cav-plate rods are 1/2" dia. material and I can use some of those bearings from it. The frame already has a hole in it so Ill just have to cut the floor up a bit and make the pedal work on the end of that new shaft location.
The wilwood idea was to make the brake pedal assembly part of the cab instead of part of the frame. I guess that one will have to go back to the drawing board at some point or just use some better materials. I have a meeting with my machinist friend today, so we will see what he thinks.
Old 09-28-2017, 05:15 PM   #772
BC Toy chest
BC Toy chest's Avatar
WOW & WOW gr8 to see how far you have come along, looking forward to seeing more photos. GR8 work man.
I'm not tail-gating, I'm drafting.
http://67-72chevytrucks.com/vboard/s...d.php?t=432758
BC Toy chest is offline   Reply With Quote
Old 10-14-2017, 12:00 PM   #773
ptc
ptc's Avatar
Got the doors hung and aligned and now working on the latches from AutoJunk... with no directions at all. Well maybe Ill make a video on how to install them into a TF truck - I guess AutoLoc doesn't believe in support for these trucks.
Also -------waiting --------- on machine shop that said it would ONLY take an hour to rebuild my brake pedal idea the RIGHT WAY.... but that was 3 weeks ago!!!!
HATE TO WAIT!!!!! ----
But I have my day job to keep me busy, what with 2 hurricanes, high rise fire in Hawaii and Northern CAL totally in flames! --- guess Ill be busy for a bit.
Old 10-14-2017, 08:44 PM   #774
slammed57
slammed57's Avatar
been a while since i checked , Its lookin awsome buddy.
My 57 current build
http://67-72chevytrucks.com/vboard/s...d.php?t=662590
slammed57 is offline   Reply With Quote
Old 10-14-2017, 09:56 PM   #775
Dan in Pasadena
Wow, she's looking REAL good! I seriously considered those rims for mine and now I am considering them again! What sizes/widths are you using?
