11-30-2017, 06:05 PM | #51 |
Re: Marks Diesel 46 project
lookin good!
12-01-2017, 11:02 PM | #52 |
The first rear differential that I had was bad. The clutches had ground down into the carrier. I found out when I took it apart to check the bearings. I made a few calls and found another one for $150. I took that one apart and it had some pits in the bearings. I decided to just put all new bearings and seals in it. Gear mesh pattern and backlash all turned out good first try.
46 Chevy Pickup (project) 60 Chevy Biscayne 93 Caprice wagon(Impala SS style) 99 Corvette convertible 2014 Silverado 2500HD 92 Chevy 1500 (Shop/plow truck) 02 Silverwing 05 H-D Springer Classic 2011 Civic (Wifes car) 03 Highlander (beater) 96 Honda Elite 80 |
12-01-2017, 11:12 PM | #53 |
Started on the control arms. The ball joints popped out easy, and the uppers were just bolt in, but getting out the bushings is a pain. An air chisel seems to work the best. Ready to clean them up and reassemble.
12-01-2017, 11:19 PM | #54 |
Sandblasted and painted some more parts.
12-02-2017, 12:04 AM | #55 |
I set em on fire. they fall out after that.
12-02-2017, 07:20 PM | #56 |
Nice work Mark. Freshly blasted parts always look so good.
12-04-2017, 07:14 PM | #57 |
What kind of blaster do you have?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
12-08-2017, 10:54 PM | #58 |
I have heard of doing it that way. I bet that smells good!
12-08-2017, 10:57 PM | #59 |
Yea, I wish it would stay that way and didn't have to put paint on it.
12-08-2017, 11:09 PM | #60 |
Its a Brut sandblaster. The smallest model they make. Made in Ohio. I bought it at the Carlisle swap meet a while back. Got tired of the Harbor Freight one.
12-08-2017, 11:21 PM | #61 |
Cleaned up the steering box, looked perfect inside so I put new seals in it and adjusted it. Put some silver hammered paint on it.
12-08-2017, 11:37 PM | #62 |
Finished rebuilding the control arms, then put the front suspension, steering and brakes together. Its good the late 70s G body cars share a lot of brake and suspension parts with S10 it makes them easer and cheaper to get.
12-08-2017, 11:51 PM | #63 |
Got the rear installed. Put all new rear brakes on. Now I have tires back on the ground.
