01-20-2018, 09:09 PM | #51 |
Re: The Family Truckster- 66 Suburban Build
looks great not to far from you either. We dont get many 60-66 popping up on CL that are worth looking at, nice score
01-23-2018, 09:16 AM | #52 |
Yeah I was pretty shocked when I cam across it locally, once I looked at it I knew I had to have it.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
02-19-2018, 10:59 PM | #53 |
Haven’t updated in a while but I have been busy the last couple of weekends working on the Burb. Got the rear suspension all buttoned up. I added some Ridetech HQ shocks and changed direction on the rear brakes. I initially was going with the Captain Fab brackets and some Wilwood D52 calipers but I decided that I really should run a emergency brake so I sent the Wilwood calipers back and picked up a Wilwood Dynalite Rear Disc Conversion Kit with the internal parking brake. This kit also makes it easier to get the rear wheels on and off as the caliper mounts in the middle of the rotor instead of towards the top like the D52’s did. I’ll be listing the captain fab brackets and rotors in the for sale section. I also made a decision to not run the rear wheels with a spacer or adapter so I called up Travis at Pro Performance and ordered 2 new custom built polished TTII’s with the exact backspacing I needed. This was really the best option I had! I really like the way the TTII’s look on my burb and didn’t want to spend a ton of money at this time on a expensive set of billets that would only look marginally better! Just waiting for the wheels to show up now.
I also picked up a rear seat for the Burb from member richard2717. It’s a pretty nice seat out of a squarebody K5. It’s got the right brackets to easily mount it to the burb rear floor. It’ll eventually get recovered along with the original front seat.
02-19-2018, 11:04 PM | #54 |
nice! sent you a message on the rear discs
02-20-2018, 12:44 AM | #55 |
60-66 Nut
FYI to have an e-brake with the D52 brackets all you need are the '76-'78 Eldorado calipers.
02-20-2018, 01:03 AM | #56 |
WOW...what a improvement a elevation change and wheels makes....looks great
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 02-20-2018 at 01:21 AM. |
02-20-2018, 09:16 AM | #57 | |
Thanks, I'll send you over the info you need.
Thanks, its crazy the difference in how it looks now.
02-20-2018, 09:56 AM | #58 |
Moderator
Do you have a picture of the new rear calipers now?
02-21-2018, 12:43 PM | #59 |
Forgot to take one with the wheel off but this gives you an idea!
02-21-2018, 03:49 PM | #60 |
Moderator
Interested in the parking brake info - Which Kit did you buy?
02-21-2018, 07:42 PM | #61 | |
http://www.wilwood.com/BrakeKits/Bra...%2c+5+Lug+only
02-21-2018, 11:37 PM | #62 |
Just keeps looking better and better, Keith. Reckon it stops a lot better now too.
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
02-22-2018, 11:38 AM | #63 |
Thanks Vic, hopefully it stops better than the 4 wheel drum manual brakes it had before
02-22-2018, 12:20 PM | #64 |
Great looking rig!
Seth Instagram: sethrosa11 My Build Thread: "Betty" http://67-72chevytrucks.com/vboard/s...d.php?t=613225 1966 C10 Patina: http://67-72chevytrucks.com/vboard/s...d.php?t=716802 1978 Big 10 http://67-72chevytrucks.com/vboard/s...d.php?t=771383 |
02-26-2018, 09:19 AM | #65 |
Thanks Seth, can't wait to see how yours turns out after the suspension overhaul.
02-26-2018, 06:31 PM | #66 |
Looking good! What's next on the list? Almost time for a test drive?
02-27-2018, 09:08 AM | #67 |
No test drive until the LS is in and running. I pulled the front clip off on Sunday in preparation for the LS swap. I need to pull that old greasy straight 6 out so I can clean and paint the frame rails and front suspension before stuffing the LS in. The 4L80e has been dropped off to be rebuilt as well.
02-27-2018, 05:08 PM | #68 |
Current pic of how the Burb looks. Still have to pull the steering shaft so I can get the driver side inner fender out of the way. Ran out of gas on Sunday and didn’t finish it
02-27-2018, 05:12 PM | #69 |
Oh and these showed up today! Really like the way they look and the extra backspacing makes for a nice looking lip! Went with a 20x10 with 4.5” BS, going to trim the fender lip about a half inch to give me some clearance on the outside of the wheel well. Definitely won’t rub on the inside anymore!
02-27-2018, 05:17 PM | #70 |
Oh yea! What are the specs on the LS you're throwing in? I can't recall what all you had planned for your truck. I really need to chase this lead on a 6.0/4l80e that I have before it gets away. Those wheels look great!
02-27-2018, 06:20 PM | #71 | |
I'm just glad to be here!
The blue arrow in the picture shows the slot left from removing the smaller panel that covers the steering shaft as it passes thru the panel.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 02-27-2018 at 06:26 PM. Reason: added picture... |
02-27-2018, 09:00 PM | #72 | ||
02-28-2018, 10:26 AM | #73 | |
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
02-28-2018, 01:09 PM | #74 | |
02-28-2018, 09:48 PM | #75 |
nice!
