06-22-2018, 10:26 AM | #1 |
fender fix/repair?
I've got a fender thats in great shape but has the spare tire cutout...I've got a nonspare tire fender that's in sad shape...
Its going to take a lot of work and patching to fix the non spare fender...I'm considering cutting out a section of the bad fender to fix the spare tire hole in the good fender....any suggestions? I've been looking for a good nonspare fender for about a yr and they're nearly impossible to find...theres lots of spare tire fenders out there...
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 06-22-2018 at 10:33 AM. |
06-22-2018, 03:49 PM | #2 |
Re: fender fix/repair?
Man, that is a tough one. Cutting that fender and welding the piece onto the one with the well is NOT easy. A patch, cutting off the bottom and welding it on, piece of cake. But that area up there is pretty tough, I am thinking by the time you get it done you could have fixed the old fender.
Now, if you had a really rough fender that was wasted but that one section was good, hell yeah, cut it off and see how nice it fits and see if you want to keep going. But to cut up your best rough fender, that sucks. This is the thing I am thinking about, and this is a big one. There is a very real possibility that those fenders aren't shaped the same there! That one with the spare wheel well may be completely different from the stamping! If they had a whole different dies, and made the fender on them, without a doubt it could be different. If they made the cut one from basic stamped well-less fenders and simply modified them, they could still be different. A slightly different shape could make doing that a LIVING HELL. So if I personally didn't have another fender to cut up and give it a try I would be leaning towards repairing the well-less fender. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
06-22-2018, 07:31 PM | #3 |
From the pictures posted, I don't see much wrong with the fender you want to use. I'm with Brian, spend your time and energy getting it ready for paint.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
06-22-2018, 10:17 PM | #4 |
you both have great points.....I hadn't even thought about different dies stamping the fenders different....
the "bad" fender is worse than it looks in the pic...the flange edge where it bolts to the bed is really bad or gone on the rear half after giving it some thought I will try to fix the bad fender...ive got nothing to loose...if it doesn't work out then ill have a donor...
06-22-2018, 10:34 PM | #5 |
these are the really obvious areas on my bad fender
1.rusted out and dent full of filler 2. was big dent...I had already hammered the worst out of it 3.big dent full of filler 4.big dent full of filler 5. big dent and rust thru 6. big dent,rust thru.full of fiberglass and filler and mounting flange rusted off 7.rear mounting lip mostly gone 8.wheel well lip needs replaced just will be a bunch of work..thanks guys
06-23-2018, 12:15 AM | #6 | |
06-23-2018, 12:31 AM | #7 |
I wish it was as good as the white fender...it doesn't have a single dent on it that I could find...and solid as a rock....practically no rust
ill get the bad fender blasted next week so I can really see what ive got to work with
06-23-2018, 07:55 AM | #8 |
Lost amongst the CORN
Are you any where near Huntsville?
Currently working on How To Videos and custom metal 70 Chevelle gettin Sliced and Diced Anything But STOCK 70 Chevelle SS455 not a typo its a BUICK BABY 49 and 72 Chevy Trucks restored to original...close to it Drommer Stor....Norwegian for Dream Big http://s969.photobucket.com/albums/a...lle/?start=all https://www.flickr.com/photos/47922830@N03/ Pictures of my work and projects |
06-23-2018, 11:41 AM | #9 | |
Brian
06-23-2018, 12:10 PM | #10 |
Chevelle....I'm about 20 miles from h-ville...
Martin I'm up to my ears in fab work on this truck....I know it can be fixed...just gonna take some doings At first I was just thinking scab in the piece on the white fender...but when you pointed out the different die stamps a light came on.....wouldn't be the first 2 of kind things on this truck that didn't match....I'm gonna give repairing the rusty fender a try first before I try a scab.....
06-23-2018, 01:10 PM | #11 |
I was even thinking of sectioning it like this. Just so that shape stays the same and that if there is some difference it would be easier to join them like this. Cutting right below that body line.
Brian
06-23-2018, 02:30 PM | #12 |
This exact repair was done by Janne Jarvinen (Finland), his video here should give an idea the amount of work to fabricate the part...
https://www.youtube.com/watch?v=eGt4XUQ3Wg4 He has a thread on Allmetalshaping covering same, but you'll need to be member on that site to see the uploaded pictures.. http://www.allmetalshaping.com/showthread.php?t=15010
Robert |
06-23-2018, 02:57 PM | #13 |
Thanks Robert for the video....that guys looks like he took lessons from you...I don't have the equipment to fab anything that complicated....I can do small stuff though....I'm gonna try and repair the rusty fender first...I may be over thinking it....it may not be as difficult as I think it'll be...just need to get it blasted first to see what I've got left..
I can see his pics on the allmetalshaping site... Martin...I hadn't thought of cutting it like that....
06-23-2018, 03:07 PM | #14 |
Delmo did this on one of his builds and posted pics on Instagram.
https://www.instagram.com/p/BiHfEqGhdKH/?hl=en
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
06-23-2018, 03:16 PM | #15 | |
Brian
06-23-2018, 03:17 PM | #16 | |
Brian
06-23-2018, 03:19 PM | #17 |
Correct, not the exact same style of spare tire fender. Same idea though.
06-23-2018, 04:11 PM | #18 |
I know a few very well skilled metalmen in Huntsville that might be willing to give you a guiding hand on the repair.
06-23-2018, 04:51 PM | #19 |
Dan Shady?
Robert |
06-23-2018, 05:36 PM | #20 |
Dan Shady, Kerry P also a younger guy that works for NASA. Dan is one of the nicest most knowledge guys you'll find and has a hammer collection that brings me to tears.
06-23-2018, 05:44 PM | #21 |
Jeff Newton, forgot he was from AL...
Robert |
06-24-2018, 01:35 AM | #22 |
Dan Shady from vintage automotive?
06-24-2018, 02:55 AM | #23 |
Yes...
Robert |
06-24-2018, 01:23 PM | #24 |
Sent Dan a link to this thread, he asked me to pass on his contact info to you. PM sent..
Robert |
09-13-2018, 09:48 PM | #25 |
While I've been working on other things...behind the scenes Dan Shady from vintage automotive has been working on my fender...he gave me the ok to share some pics so here is what hes done...his work looks outstanding....
1st pic is making a pattern to transfer 2nd pic is the patch panel clamped in place but not trimmed to fit 3rd pic shows the right fender clamped to the left to make sure the shape is consistent and the patch tacked in.... I think he's doing a great job...
