Equal opportunity joke ofender
![]() Join Date: Oct 2011
suspension question
I am thinking about digging my 68 panel out of storage this week and go ahead and get it road worthy and just drive it for now. Kills me seeing it just sit there. I have been collecting parts for quite a while to do all the rust work and have most everything, just not the time or extended space. One thing I want to do is upgrade the front brakes to disc. I have a complete cross member out of a 69 pickup that I parted and put up on the shelf in order to do this.It had just been converted to 6 lug disc and appears to have dropped spindles & new ball joints. I have two questions
1) Can the entire cradle be changed out with the motor still in the truck? It kinda looks possible but there was no engine to worry about when I took it out of the 69'. I do have a 2 post lift and tall transmission jack I am hoping will make it go smoothly. 2) There was no drag link or tie rod ends on it when I got it. How do I determine what year tie rods I would need for the spindles short of buying a new set and seeing if they fit? I am hoping it is a 71/72 spindle since I already have drag link for that. It has manual brakes as well but i have booster and new master cylinder here to upgrade that with the correct PP valve. TIA Richard
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
Re: suspension question
here are some pics of the cradle
BlahBlahBlah
Rust repair? Who needs that ... too bad you are on the other side of the US
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=767937 |
The Older Generation
Look through Keith's thread. (Lolife99) http://67-72chevytrucks.com/vboard/s...d.php?t=456889 The information you need should be in post #4 or below. I always have to read each section a couple of times before it soaks in..... ![]() LockDoc
Thanks, I will take a look. I did a few searches but missed that one for some reason
#6 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
The easiest, would be to figure out what tie rod fits your spindle.
Buy a 1970, 1972, and a 1973 outer tie rod. Take them home and see which tie rod taper fits your spindle. That will tell you what year they are. Take back the two that don’t fit. Remember,... the centerlink needs to match also. Or you’ll end up needing tie rod conversion adapters. The center links aren’t sold new.
#8 | |
Guess i should have looked at the link provided by Loc Doc that you wrote up 1st. Looks like you are saying center link is the same 67-70 so I should be covered in either case. I found a brand new tierod I had on the shelf but i did not mark the year on it so i am going to try to stop by napa with the part # to see if they can tell me the year
Its a Truck Thing......
I changed out the cradle with the motor in and it was easy. Ran a new 4x4 over the fenders and used a heavy strap to secure it. You may have to play with the holes to get them to fit.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
