Old 03-23-2018, 10:26 AM   #126
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Project daily drivable 62 C20
A stud was welded to except the new brake hose "T" ... and the hardlines were hand bent, and flared....
The driveline came up to be a tad too long, but a quick trip to the driveline shop made quick work of that.
Thanks to the awesome GF who ran it to the shop, so it could be picked up the next morning....
I ran the line thru the track mount, and used the hook off of the stock rearend to keep a somewhat stock look...
Driveline length a tad too long....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 03-23-2018, 10:47 AM   #127
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
After a brake adjustment, and bleed...we were back on the ground and ready for a test drive.
Very happy with the way it turned out, and again it was a pleasure working on such a nice truck...and the fact the customer provided ALL THE CORRECT parts for a change is definitely a PLUS !!!
John
CURRENT BUILDS:
62 BurbMaster
Other Builds:
ACC on FACEBOOK
Old 03-24-2018, 11:47 PM   #128
72cs20
Firstly, thanks to John, aka " Chief Rocka ", for contributing to this build thread describing the axle swap phase of my project.
I ended up deciding not to attempt this particular task myself but instead contacted American Customs & Classics( ACC ) of Hollister, Ca. to see if they would interested in taking on this axle swap. John said sure, no problem. We then set up a date to drop off the truck at the shop. The customer service was outstanding. From daily photo updates via text to they're willingness to accomodate my schedule. I look forward to working with them again.
I found ACC through the 60-66 Suburban & Panel sub-forum, once again proving how valuable this forum is when needing solutions.
This axle swap is a huge success. The drivability of the truck has been greatly improved. Spent this afternoon test driving and re-calibrating the speedometer for the new gear ratio. The 3.73 gear ratio seems to be a good compromise taking into account engine type, non-overdrive transmission and present tire size. And that previously mentioned drive-line vibration is gone.
More to come...
1966 K20 flatbed build thread - http://www.67-72chevytrucks.com/vboa...d.php?t=768827
62 C20 build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=703583
72cs20 is offline   Reply With Quote
Old 04-13-2018, 09:53 PM   #129
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I just came across this thread.
I really really like the direction you went with your truck!
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is online now   Reply With Quote
Old 04-14-2018, 08:14 AM   #130
notsolo
notsolo's Avatar
Fantastic!
notsolo is offline   Reply With Quote
Old 04-14-2018, 09:30 AM   #131
CRGRS 66
CRGRS 66's Avatar
Love your build, very cool project, thanks for sharing so much detail.
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 04-14-2018, 04:13 PM   #132
72cs20
Thanks for all the positive comments everyone.
I now have 268 miles of real world usage showing on the odometer. I've been using her for dump and lumber yard runs and general errands. Made a run to the recycler and finally disposed of the old torsion bar front end.
Name:  Torsion Xmember.jpg
An impact gun, pickle fork and a 5 pound hammer reduced it to 5 manageable pieces in maybe 10 minutes.
I also built some side boards and bought a 6.5x8 cargo net to make hauling easier and safer. Uncovered loads are seriously frowned upon around here.
Name:  Cargo net 1.jpg
That cargo net is a real nice addition. Very high quality. It is made by Gladiator Cargo Nets and I bought it through Amazon.
The next phase of the project are the doors. I'm doing the passenger door first. I'm expecting all of the parts to refurbish this door in the next day or so. All new glass, rubber seals, window channels, paint and inside handles. The outside mirrors will be addressed as well.
I'm also going change up the seating and get the three point belts put in. I have an end goal for this truck and the seating arrangement will help meet this goal.
More soon. Thanks.
Old 06-17-2018, 05:19 PM   #133
72cs20
Well, I'm officially calling this project completed. The goal of the post title "daily drivable" has been met. I've been using the truck every weekend and everything is working great. So I will be seeking a new owner and passing it on for someone else to enjoy, and will free up space for project 66-K20.
I'd also like to say thanks to all who commented during this thread. It greatly helped to keep me going during this two year project.
Old 07-31-2018, 11:13 AM   #134
66K20
66K20's Avatar
Great build. I love the truck. The build was easy to follow and detailed! Thank you for taking the time to post.
Do you have a report for the Alaskan camper shell work or the trip, that I believe was planned for this year?
Brett | 1966 K20 - 292/SM420/T221
66K20 is offline   Reply With Quote
Old 07-31-2018, 04:22 PM   #135
72cs20
I sold that Alaskan camper earlier this year, so no build report. I also have the 62 C20 sold and will be starting in on the 66 K20 very shortly. In fact, it is going into the garage this afternoon.
I ultimately decided not to use the Alaskan because of it's weight. Instead I contacted All Terrain Camper in Sacramento Ca. and had them build me one of their Cougar models in shell configuration(this means I have to build out the interior). This camper is about 800 lbs lighter than the Alaskan and is designed for trail use. Here is the ATC on my F-250 -
My road trip plans are still on but instead I'll be using the K20. I'll be needing 4wd during my travels. The ATC will be mounted to the flatbed on the K20 and this will be my road trip/back country adventure rig.
Thanks for reading my 62 build thread and thanks much for the compliments.
Old 03-26-2023, 11:09 PM   #136
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
Originally Posted by 72cs20 View Post
Worked on getting the brake booster and brake pedal set up. In post number 12 there is a photo of the booster I wanted to use but it turned to be too big in diameter. It is from a 1995 C1500 and it is approximately 11 inches wide in diameter. Too big to fit between the clutch master and the engine valve cover. The truck that gave its engine for this project, a 1990 K1500, had a smaller 9 inch booster. I took it and installed on the 62. Perfect fit!
Attachment 1572149
Attachment 1572150
Attachment 1572151
For the pushrod I just mated the 1990 push with the 62 pushrod for adjustability. I also decided to use another great idea from this board and drop the brake pedal height with an extended bump stop.
Attachment 1572152
Attachment 1572157
What master cylinder is This from? 72? And where did your the prop valve and lines where they pre bent?
Thanks!
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 03-27-2023, 07:29 PM   #137
72cs20
Yes, the master cylinder and prop valve are from a 72 C20. The lines are pre-bent from in-line tube.
