Old 04-04-2020, 04:42 PM   #51
SCOTI
SCOTI's Avatar
Re: Cgt project
Originally Posted by vet57air View Post
So this what I did for tire clearance. I cut 5/8" out and left 1/2". I then welded some 3/16" x 1/2" FB on top for added strength. By leaving the 1/2" I didn't cut through any spot welds. The braces then had to be lengthened and welded. Seems like a lot of work but if you have a large wheel and tire (31" tall) at this ride height you need all the room you can get.
Yep. Thats what I had in mind. Trim back just to the edge of the spot welds (~.625") and reinforce the remaining lip for reassurance. I haven't decided on bolt-in or welding the reinforcement.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-04-2020, 09:24 PM   #52
vet57air
vet57air's Avatar
Re: Cgt project
Almost done my fabricating, details. Battery box and transmission cooler mount.
vet57air is offline   Reply With Quote
Old 04-07-2020, 08:16 PM   #53
vet57air
vet57air's Avatar
Re: Cgt project
Please help. Going out of my mind with my rear wheels. They are 22 x 12. I went with this backspace because sometimes when you have little backspace you loose the look of the wheel as all you see is lip. Not sure if I have enough lip. Am willing to change out the rear wheels but I cannot make up my mind. What do you think? Opinions...
Old 04-07-2020, 08:41 PM   #54
SCOTI
SCOTI's Avatar
Re: Cgt project
Looks good from here.
What are the F/R back space numbers?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-07-2020, 10:00 PM   #55
vet57air
vet57air's Avatar
Re: Cgt project
F is 5.5 on a 9" wheel. Has clearance lock to lock, at this ride height.
R is 7 on a 12" wheel. If I change it would go down to 4" backspace.
Old 04-08-2020, 12:23 AM   #56
SCOTI
SCOTI's Avatar
Re: Cgt project
Yikes.... 4" backspacing on a 12" wheel is closing in on race car/Pro Street territory. I'm ok w/about 4"BS on a 10. Beyond that the wheel detail seems to be lost (especially on these 6x-66 trucks). So 10"/4"bs; 11"/5"bs; 12"/6"bs.... You're pretty much spot-on where I feel the 'look' is now but thats a personal thing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-08-2020, 10:12 AM   #57
vet57air
vet57air's Avatar
Re: Cgt project
Thank you for your opinion. Those were some of the reasons I went the way I did. Yes it is a personal thing, but want to see what others think.
I want my truck to handle. Yes 22's are not optimal for that, but I like the look. My front track width is 59" so when designing my frame I went with 59" for the axle because somewhere I read this is good. Set the B.S. on the wheels to fit my suspension. ( some do it the other way around).
Old 04-08-2020, 10:56 AM   #58
aggie91
I'm just glad to be here!
aggie91's Avatar
Re: Cgt project
Personally I like your set up now with the lesser lip so the detail of the wheel center is more clearly seen. I agree with Scoti's comments on bs measurements.
I think the big lip trend is going to play out at sometime, but the lesser lip/more center detail is timeless.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-08-2020, 11:45 AM   #59
SCOTI
SCOTI's Avatar
Re: Cgt project
My plan (according to MY math) is 10.5" w/4"BS on the rear. I know the housing is ~58" but I can't remember if that was w/the rotors on or not when I measured for a 'true' WMS-to-WMS dimension. So..... It could be it was slightly over the 58" mark. I know I'm under 59" max.
My front track width should be 60-61" (OE truck disc brake fronts @ 64; PB Dropmember -1.5", PB 1" narrowed arms, & CPP modular spindles -.5 x2= 60.5"). Wheels will be 8-9" w/5.25 - 5.50"BS.
I think your set-up will work well.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-08-2020, 01:43 PM   #60
vet57air
vet57air's Avatar
Re: Cgt project
What diameter wheels will you run? What year of truck?
Old 04-08-2020, 03:20 PM   #61
SCOTI
SCOTI's Avatar
Re: Cgt project
20's & it's a 64 short fleet.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-26-2020, 12:18 PM   #62
vet57air
vet57air's Avatar
Re: Cgt project
Finally received the parts I needed for the steering. Never had to use 4 joints before ( two doubles). My frame manufacturer laid back the rack making the conntection more complicated.
Old 04-26-2020, 05:18 PM   #63
SCOTI
SCOTI's Avatar
Re: Cgt project
Wow.... You had to utilize two different support bearings.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-26-2020, 07:45 PM   #64
vet57air
vet57air's Avatar
Re: Cgt project
For every universal over 2 you need a support bearing. Would have been dead easy if the frame guy had the rack mounted "straight up" rather than angled.
Old 04-27-2020, 12:27 AM   #65
SCOTI
SCOTI's Avatar
Re: Cgt project
I guess they figured exhaust would be easier w/the steering routed low & under the motor-mount tower.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-07-2020, 09:20 PM   #66
vet57air
vet57air's Avatar
Re: Cgt project
Doing body gaps. Pretty happy with door and fender gaps. Have the hood and cowl pieces left. I like the gap between the hood and fenders but the cowl is high. Anyone have any tricks besides me slicing the cowl piece?
Old 05-08-2020, 06:34 AM   #67
Hammered 77
Hammered 77's Avatar
Re: Cgt project
Just found your build. Nice work!! Do you have enough clearance to allow for a 4" back space on the rear wheel?
Rick
Hammered 77 is offline   Reply With Quote
Old 05-08-2020, 11:33 AM   #68
vet57air
vet57air's Avatar
Re: Cgt project
Rick
Yes
Old 06-07-2020, 11:52 PM   #69
vet57air
vet57air's Avatar
Re: Cgt project
My new full time job.....my body and paint. Done all the body work and gaps. Just put some high build on the cab and now some blocking.Name:  Primer.jpg
Old 06-08-2020, 01:10 AM   #70
Warrens69GMC
Warrens69GMC's Avatar
Re: Cgt project
Nice, How did I miss this?
Old 06-08-2020, 09:53 AM   #71
SCOTI
SCOTI's Avatar
Re: Cgt project
Well.... I guess that's good. Work detail should easily pass ownership QC. But then again I've heard when the same person wears both hats (owner & QC) there can be a struggle.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-08-2020, 10:34 AM   #72
vet57air
vet57air's Avatar
Re: Cgt project
Don't get me wrong, I hate body work. I do it out of necessity. I'm pretty picky detailed kind of guy and can't afford to pay someone to do it.
Old 06-08-2020, 11:13 AM   #73
SCOTI
SCOTI's Avatar
Re: Cgt project
I get it. I can/have done body-work so I understand what it takes and learned because I knew I wouldn't be able to pay the going rate for the quality I expected.
My #1 problem always was knowing when to stop & that it was 'good'. Heck, it still is. This also is a factor in why I seek out clean, patina, survivors so I can live w/how it came from GM
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-08-2020, 11:39 AM   #74
vet57air
vet57air's Avatar
Re: Cgt project
I get what your saying. I did consider buying a nice original paint SWB truck but the price kind of killed that, not to mention all the mods I wanted to do didn't make it practical. I have come to grips with building a show worthy truck and driving the wheels off it. Truthfully I have done this before. I just had to get it clear in my mind that when you drive it, **** happens..... then you fix it. My 1954 COE Tourliner is a good example. I finished it 10 years ago and have put 20,000 miles on it and it still looks fresh.
[ATTACH][/ATTACH]
Old 06-08-2020, 03:13 PM   #75
88Stanger
88Stanger's Avatar
Re: Cgt project
Beautiful work, its as simple as that.
88Stanger is offline   Reply With Quote
