09-12-2020, 01:35 PM | #1 |
Bigmoe's 65 GMC10 project.
I've been posting occasion pics of my project related to what ever I was needing advice on at the time, etc., but now that it's finally done I thought I'd post some pics of the entire project. It was 2 1/2 years in the making but over a year of that was at the body shop. I bought the truck as a basket case, a 65 GMC. The frame had been cleaned and painted and the cab had been at a reputable body shop to be prepped for paint. It came with two boxes and I also bought a parts truck. The 5.3LS motor I got from a written off 2008 Chev Tahoe that had only 69000km (43000 miles). My apologies for the ones that are upside down. I finally figured out which way to hold my iphone.
09-12-2020, 01:38 PM | #2 |
Re: Bigmoe's 65 GMC10 project.
I acquired a square body front crossmember. 2 1/2" drop spindles.
09-12-2020, 01:39 PM | #3 |
Exhaust holes through the crossmember and modified trans crossmember for exhaust.
09-12-2020, 01:41 PM | #4 |
Engine plates. Ended up using 3rd hole set forward to clear the firewall.
09-12-2020, 01:45 PM | #5 |
Picked up some 2008 Odyssey second row seats. I ended up recessing the mounts to gain more headroom. (I'm 6'3) They can be popped out of the truck by just pulling a release handle.I removed the handles on the back of the seats so they would go back further and removed the inner arm rests. Console is from a newer Silverado.
09-12-2020, 01:46 PM | #6 |
Aftermarket mirrors from Ebay
09-12-2020, 01:47 PM | #7 |
Progress in paint booth
09-12-2020, 01:51 PM | #8 |
RnD rad. Spal fan.
09-12-2020, 01:55 PM | #9 |
Finished the back wall with a piece I got from an ?04 F150 std cab and some Kydex plastic I formed for the corners.
09-12-2020, 01:56 PM | #10 |
motor goes in
09-12-2020, 01:59 PM | #11 |
I used an in cab recirculating heater because I didn't like the Deluxe heater in the engine bay. I had to modify the glove box because it was hitting the heater assembly.
09-12-2020, 02:06 PM | #12 |
Made some licence plate brackets to center the plate.
09-12-2020, 02:08 PM | #13 |
I applied vinyl stripe. The truck had no trim holes so we didn't know where to paint the stripe.
09-12-2020, 02:10 PM | #14 |
I used an Art Carr/Winters shifter. Cable actuated made it easier to position. It also has neutral safety and reverse switches.
09-12-2020, 02:11 PM | #15 |
Trim applied with 3M tape
09-12-2020, 02:19 PM | #16 |
All done!
The wheels are 17 x 8 with 4 1/2" backspace. I have a square body rear end that is 3/4" wider per side. 235-60-17 and 255-60-17 2 1/2" drop spindles and stock springs in front and Jeep 97-06 rear coils (ACDelco 45H2104) Last edited by bigmoe; 09-12-2020 at 02:25 PM. |
09-12-2020, 02:19 PM | #17 |
72 bumper
09-12-2020, 03:31 PM | #18 |
Wow looks good, is that a homemade fan shroud?
09-12-2020, 04:07 PM | #19 |
09-12-2020, 04:15 PM | #20 |
Went with a Dakota Digital universal dash with BIM module. Just plugs into the OBD II port.
09-12-2020, 04:23 PM | #21 |
Engine bay
09-12-2020, 04:33 PM | #22 |
Tanks Inc USPT-GH 15 gallon gas tank. I was going to fill up the middle thruogh the wood but ended up using the fill neck on the side, through the frame, to the corner of the box.
09-15-2020, 02:34 PM | #23 |
I'm just glad to be here!
Truck looks great!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
12-28-2020, 03:57 PM | #24 |
Filler in the corner of the box. Filling it is slowed, probably because of the 45 degree elbow, but it's not too bad.
12-28-2020, 04:48 PM | #25 |
Moderator
Man that's looking sweet!
Love those license plate mounts. I'm going to make a pair for mine.
