Old 10-29-2020, 12:06 AM   #101
Kevin_C
Re: 55 in NH build
The project is evolving again lol . I was able to pick up a 2016 LT1 and 8L90 transmission with 26k. 455hp 460tq should move it along. I'll be collecting parts for a while. I'm going to do the DOD delete and have an LT5 cam on order. I'm hoping I can make enough room to keep the factory accessories. This Gen V stuff is a pretty big learning curve for me but I'm pretty excited about the prospect.
1955 chevy longbed shortened, C4 vette suspension front and rear with flatout kit. Gen V LT1/8L90
http://67-72chevytrucks.com/vboard/s...d.php?t=746958
Kevin_C is offline   Reply With Quote
Old 10-29-2020, 02:36 AM   #102
Kermitt47
Kermitt47's Avatar
Re: 55 in NH build
Nice work on the build. That power train will make things interesting. Subscribed
Kermitt47 is offline   Reply With Quote
Old 10-29-2020, 09:32 PM   #103
Last_Paladin
Re: 55 in NH build
Your neighbor must hate you.
Last_Paladin is offline   Reply With Quote
Old 10-30-2020, 12:59 AM   #104
Jason 56
Re: 55 in NH build
Looks familiar If you run into any questions, feel free to ask. How complete is the engine?
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build
Jason 56 is offline   Reply With Quote
Old 10-30-2020, 09:26 AM   #105
Kevin_C
Re: 55 in NH build
Thanks Jason. the engine was complete but the harness... looks like the salvage company just lopped off the BCM section and I had to purchase a new TCM that is being programmed. I figured I'll have to create a new trans tunnel as you but not sure if I will need to touch the firewall as much. im trying to keep the camaro accessories with the AC and Alt down low so I'll be moving the engine forward a bit to make some room.
Old 10-30-2020, 09:53 AM   #106
Jason 56
Re: 55 in NH build
Having the BCM section cut off isn’t that big of a deal. You’ll just have to continuity track all the hots for the stand alone fuse/relay panel. Are you doing your own harness or sending it out? Are you planning on running The PWM fuel and cooling fan? Mitch at swap time is a great resource for these gen V engines.
Old 10-30-2020, 10:10 AM   #107
Kevin_C
Re: 55 in NH build
Ya I plan on having Mitch build the harness along with adding his hot rod module. Going to run the PWM fan and pump as well.
Old 10-30-2020, 10:11 AM   #108
Last_Paladin
Re: 55 in NH build
You should keep all the GM stuff they spent millions on, as intact as possible.
Old 11-01-2020, 08:25 PM   #109
Kevin_C
Re: 55 in NH build
Got the drive train pulled today. the SBC looks tiny next to the LT1. Hope to start mock up soon.
Old 11-14-2020, 09:45 AM   #110
Last_Paladin
Re: 55 in NH build
Nice tractor.
Old 12-11-2020, 07:38 PM   #111
Kevin_C
Re: 55 in NH build
Been ordering parts while I wait for the engine upgrades to be finished. Got a shifter in. HDX gauges have been ordered. Vaporworx ZL1 pump ring and and fittings are in.
Old 01-11-2021, 08:25 PM   #112
Kevin_C
Re: 55 in NH build
Got the engine back from the builder today. A bit of sticker shock later... Ordering the wire harness this week. They said it will take 6-8 weeks.
Old 01-13-2021, 12:13 AM   #113
Jason 56
Re: 55 in NH build
You’re making great progress. What fuel pump are you planning on using?
Old 01-13-2021, 10:20 AM   #114
Kevin_C
Re: 55 in NH build
I have a ZL1 pump with a Vaporwokx lock ring welded into the tank. Im curious as to the sound level. The PO had an external holley pump that was crazy loud
Old 01-13-2021, 02:50 PM   #115
jwhotrod
Re: 55 in NH build
chances are with a internal pump in the tank you wont hardly hear it at all. I have been using Walbro internal pumps in my streetrods for years (original equipement in Mustangs and Camaros) i love em and they last forever since the fuel cools them in the tank.
jwhotrod is offline   Reply With Quote
Old 01-13-2021, 02:58 PM   #116
Jason 56
Re: 55 in NH build
That’s cool. I just ordered the same pump and ring to mount in my tank.
Old 01-13-2021, 04:05 PM   #117
Kevin_C
Re: 55 in NH build
I still need to order a fuel pump controller and low pressure sensor but will add that into my harness order
Old 01-17-2021, 09:37 AM   #118
Last_Paladin
Re: 55 in NH build
You won't hear it.
Old 01-21-2021, 12:01 PM   #119
Kevin_C
Re: 55 in NH build
Last_Paladin and his boys helped me mock up the engine. So far its tight but looks like everything will fit. Getting closer
Old 01-24-2021, 12:53 PM   #120
Kevin_C
Re: 55 in NH build
started bolting on as many bits as I can before finalizing my engine mounts. So far it doesn't look like I'll need to cut the firewall at all. Also ordered a high hump transmission cover to clear the center of the 8L90E. It was only $45 so I figured it would be a good starting point if I need to modify further.
Old 01-28-2021, 07:53 PM   #121
62 Barnfind
62 Barnfind's Avatar
Re: 55 in NH build
Engine mock up looks good! I ran into the same problem with my 4l60e. The high hump gave me plenty of clearance.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 01-29-2021, 01:10 PM   #122
57FleetsideC4
Re: 55 in NH build
looking good. What radiator are you using? Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054
57FleetsideC4 is offline   Reply With Quote
Old 01-29-2021, 03:48 PM   #123
Kevin_C
Re: 55 in NH build
The radiator came with the truck. Seems like decent quality but can't find any name on it. Haven't decided if I will keep it long term. May have the top port relocated but I got a ways to go before I need to decide.
Old 01-29-2021, 06:48 PM   #124
57FleetsideC4
Re: 55 in NH build
Thank You. Steve
Old 03-15-2021, 11:26 PM   #125
Kevin_C
Re: 55 in NH build
My friend was able to relocate the inlet and outlet on my radiator and match up the size to the LT1 engine. Camaro fan installed and still has good clearance.
