#126 |
Re: 57 Truck build
This weekend was all about fixing some of the rust holes that came up after blasting I only had a few and after I finished that I installed the Vintage air mock up box so I can start doing the body work. Thanks to Slammed 57 for the install advice. It made the install less painful.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 Last edited by Rickysnickers; 02-07-2021 at 05:34 PM. Reason: flipped photo |
#127 |
Re: 57 Truck build
Had a week of extreme cold weather here in Texas. Today it warmed up so I decided to go out and finish the cowel. Finished all the welding and grinding and decided to start doing some filler work. Cowel is done now on to smoothing the firewall.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#128 |
Re: 57 Truck build
Like the clean look of the cowl. Nice work. We are going through a cold and snowy patch here in upstate n.y. Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
#129 |
Re: 57 Truck build
I like it! Hope you don’t mind, but I’m copying that clean cowl look. Keep up the progress, it’s looking great!
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
#130 |
Re: 57 Truck build
Thanks!
#131 |
Re: 57 Truck build
No problem. I copied it too.
#132 |
Navy Radioman Veteran
Re: 57 Truck build
Nice work on the cowel... will be doing something similar... LMC sells a one piece replacement unit cheap. Gonna try that first.
Ken
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside Last edited by 87Lowrider; 02-21-2021 at 11:25 PM. |
#133 |
![]() Join Date: Jan 2015
Re: 57 Truck build
Man ,looks real nice John. came out great. quick question,where you live does it have a lot of humidity? reason Iam asking if so you might want to get the cab in epoxy primer then you can put filler over that..... filler will soak up humidity and if over bare metal it may give you issues down the line( especially if its goin to be sometime before you paint) . Dont mean to intrude and I know others have difference of opinion,but its just cheap insurance , hate to see you go through hard work you been doing then to have issues.
#134 | |
Re: 57 Truck build
#135 |
Re: 57 Truck build
saw myself in a couple of pics, looking good John. I havent been on here in a while, nice progress
A C Ward Retired US Army 66 El Camino 67 SWB underwent major Surgery- http://67-72chevytrucks.com/vboard/s...d.php?t=776475 |
#136 |
Re: 57 Truck build
Finally got it it in epoxy! Next step is roof replacement and body work.
#137 |
56 - autocross
Re: 57 Truck build
Question: When you did the shaved cowl, did you cut out the understructure or just laid the new cover on top like the old one bolted in and just fillet weld it in.
#138 |
Re: 57 Truck build
I bought one that didn’t have the vents in it. I first bolted it in to get the proper placement and the. Cut and welded it in. It still has the same support structure under it. See the pics. One is where I used each primer and the other is the cowel just bolted on before cutting. I cut it on the mounting hole bend.
#139 |
56 - autocross
Re: 57 Truck build
Thanks for the clarification.
#140 |
Re: 57 Truck build
is that a 3rd brake light hole?
#141 |
Re: 57 Truck build
Yes, I thought I needed something a little different.
#142 |
Re: 57 Truck build
Took two days off to install the new roof. Removal wasn’t to bad just a bunch of spot weld cutting. Once removed. I found more rust and warped inner roof that I had to fix. Then coated the inner roof with por 15. I decided to buy a spot welder to make the job easier. Thanks to Slammed 57 for helping me out! It came out real good!
#143 |
Re: 57 Truck build
I put the front of the truck back together to finalize the gaps and start the body work. It’s funny how these things move after you fix them and take them apart. I have a few fixes on the body but an overall good fit.
#144 |
Re: 57 Truck build
Some recommend using the drivers side front cab mount as a stationary pivot and with the other mounts loosened off, pivot the cab a bit to get the gaps like they need to be. Especially hood gaps are affected.
#145 |
Re: 57 Truck build
Good idea. I will try it.
#146 |
Re: 57 Truck build
I ran across this video on youtube. Has a similar starting point at dsraven pointed out.
https://youtu.be/RgUwd9PdWiA |
#147 |
Re: 57 Truck build
Lookin great John, all the hard work is starting to come together
#148 | |
Re: 57 Truck build
#149 |
Re: 57 Truck build
Thanks! I found more problems when I put it back together. It will get there.
#150 |
Re: 57 Truck build
Worked on the right side today. Have all the lines straightened out except the front where it meets the fender. I have to add some rod to the door to get the gap right. It a little over 1/4 and I want it to be 3/16. Once done then I can move over to the drivers side and start over with the welding and grinding lines.
