![]() ![]() ![]() Join Date: Jan 2018
Which valve cover gasket to go with?
I noticed a fairly decent passenger side valve cover leak on the 283 in my 63 a couple days ago. I put cork gaskets on it last time, but that was over 2 years ago now.
My question is if I should go with a cork set again, or if I should go with the FEL-PRO VS12869T. That's their Permadry gasket that's about $25, so I don't know if I should spend the extra dough if it'll leak after 2 years like the cork one did. If the gasket is worth it, I don't mind spending the extra dollars
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
Re: Which valve cover gasket to go with?
I use cork, but also Permatex black on both sides. I clean both surfaces with acetone first and then bolt them down and let it cure for 24 hours. They stick down hard enough that I bet I could remove the bolts and they still wouldnt leak.
I don't remember using any rtv on them when I put them on 2 years ago, so that might be why the leak has developed so soon. Thanks for the suggestion.
Might have to be cheap this go around and see how long it lasts ![]()
I dunno about cheap, by the time you buy the cork ones and add the Permatex black to the tab....
Good point.
Seems to me that the price of cork gaskets has gone up since the last time I did this. Almost $20 for a cork set local. Sure you can find them online for cheaper, but by the time you add on shipping, it's almost as much as getting it local. Anyways, if there's not really a huge advantage to get the Permadry gasket, cork and rtv will be fine with me
I used similar gaskets to the fel-pro’s You linked.
Rubber/cork composition. On a chrome bbc valve cover. This was back in ‘90 - ‘92. They were an out of sight mere 40 bucks. Best gaskets I ever used. Had the covers off at least six times and never a leak. |
Felpro has a blue rubber version with steel inserts.
Pricey but they can be removed a few times with out leaks. |
I always use the cork gaskets and apply RTV to the valve-cover side only.
In my opinion, there is no reason to put RTV between the gasket and the cylinder head...the head has been machined flat and smooth which makes for a good mating surface for the gasket. Valve covers are notorious for not having flat and/or square mating surfaces. I've never had any issues with leaks. Edit to add: I have taken mine off and put them back on a couple of times and still have no issues with leaks.
-Tim '65 GMC that identifies as a Chevrolet |
I don't remember the number but several years ago I went with a Felpro valve cover gasket recommended in several threads on this forum for my 350. Still holding up well. It was one that folks said you could remove and reuse several times. Haven't had to test that aspect but it has lasted better then the average cork replacements.
I've been using the Fel-Pro blue thick multi-use w/steel shims now for a while. I've had them off and back on over and over without issue. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#11 | |
Thanks y'all. I think I'm going to go with the fancier ones that have the torque limiters in it. I know, the valve cover isn't as important on the torque specs, but I'd prefer not to gorilla tighten them and bend them up since my torque wrenches are all at home. Sure, it's a couple bucks more, but I'm limited in the amount of tools and such that I have here at school versus back at home
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I bought the FEL-PRO VS12869T. They are called PermaDryPlus, but the instructions aren't very good.
They have a marking saying which side is supposed to be the push rod side, but it isn't clear which side lays on the head and which side is the valve cover side. Anyone install these before?
driving is in my blood
If the valve cover isn't pushing the gasket down properly to contact the properly machined head, the straitness won't matter much....
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
#15 |
This is an age-old problem that has plagued SBC valve covers since the V-8 first appeared in 1955. There are only 4 small 1/4" bolts attaching the cover. These 4 widely spaced bolts cannot evenly spread the clamping force over the entire area of the gasket surface. The gasket surface is not machined. Rather it is an "as cast" rough surface. Couple these factors with the contour of some of the various exhaust manifolds over the years that are routed in close proximity of the gasket, and expose the gasket to high temperatures, you have a perfect leak prone design..
Over the years, I very seldom used RTV based adhesives in conjunction with the latest gasket offered. I adhered the gasket to the valve cover with 3M weather strip adhesive, and attached the valve cover/gasket assembly using slightly longer bolts and the "re-enforcement tabs" in this link. https://www.summitracing.com/parts/sdm-pce312-1001 |
#16 |
![]() Join Date: Dec 2014
My mechanic friend uses weatherstripping glue for valve gaskets. I was skeptical but it works.
DAVE Edmonton, Alberta 1959 Apache 1967 K20 1968 C20 1970 C10 1972 GMC 2500 1981 C10 |
#17 |
