Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > 67-72
Old 06-16-2022, 10:51 PM   #76
Gregski
Gregski's Avatar
Re: "Drum to Disc" conversions 67-70 pics and videos
the shimmy shim shims got sum luv too (paint though, not powder)
Gregski is offline   Reply With Quote
Old 06-16-2022, 11:05 PM   #77
Gregski
Gregski's Avatar
me trying to contact Clint Eastwood tech support, you can't make this stuff up folks:
Old 06-17-2022, 01:59 PM   #78
Gregski
Gregski's Avatar
I live for these type's of tech support replies, note the personal touch, super helpful
Old 06-18-2022, 10:44 AM   #79
Gregski
Gregski's Avatar
well shoot maybe a third time is the charm, so I took this one down to bare metal
Old 06-18-2022, 10:50 AM   #80
Gregski
Gregski's Avatar
and then I powder coated it again, and although this time it took, ie the powder stuck, it dried all dull ie matt instead of glossy
and I powder coated a door hinge at the same time and that dried nice and glossy like all the other parts, so I have no idea what is up with this saucer and honestly as long as it's black and protected from rusting I really don't care
Old 06-19-2022, 12:30 AM   #81
Gregski
Gregski's Avatar
so big day tomorrow all this stuff gets bolted on
Electruck EV Conversion Update 2 Front End Rebuild / Disc Brake Upgrade
Old 06-20-2022, 04:18 AM   #82
Gregski
Gregski's Avatar
just adding this thread as an additional resource for the steering linkage part: TECH-FAQ: DiscBrake/Tie-rod End/Interchange
pic from Geoff with a G aka gcburdic 71-72 center link who informs us: "just another fyi....difference b/w 67-70 center links and 71/72 center link (holes are bigger...thus the reason for different inner and outer tie rods needed)"
Old 06-20-2022, 04:21 AM   #83
Gregski
Gregski's Avatar
happy to report the final assembly has commenced and with the help of two great new friends and forum members without whom there is no way I could have done what we did today, we got the trans mounted, the cab mounted, and the crossmember installed (we could not mount the control arms as I am still waiting on the rubber seals
Fun Level: 11.2
Old 06-21-2022, 02:18 AM   #84
Gregski
Gregski's Avatar
so picked up a center steering link today from a '72 3/4 ton
Old 06-21-2022, 12:38 PM   #85
lolife99
67-72 parts collector,…
lolife99's Avatar
Just an fyi,…c20/c30 parts are different than c10 parts.
That centerlink won’t work with your c10 inner tie rods.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 06-21-2022, 01:57 PM   #86
Gregski
Gregski's Avatar
Noooooooo, side by side they are exactly the same lengths and inner tie rod holes are larger on the 71-72 one as they should be, also the only thing I see on Rock Auto for the MOOG inner tie rod specs is that the C20 are longer
C10 MOOG ES403L Length Stud Center to End (IN) 8.740
C20 MOOG ES409LT Length Stud Center to End (IN) 8.858
Part number es409lt has a stud diameter at the top of .66 inches, a stud diameter at the bottom of .748 inches, and the stud thread is 5/8-18.
what did you notice that would prevent this center link from working with the C10
Old 06-21-2022, 02:30 PM   #87
lolife99
lolife99's Avatar
I was just going by the fact that the inner tie rods were different.
I guess it’s possible to run a c20 inner and a c10 outer.
I’ve just never done it.
Plus I didn’t know if the pitman and idler arms were the same.
All of my disc brake write up was for c10s because that’s where the bulk of the questions were from.
I’ll be interested to see what you find out.
Keith
Old 06-21-2022, 02:34 PM   #88
Gregski
Gregski's Avatar
I just plan on running both C10 inner and outer tie rods in this supposed C20 center link (with these old trucks I don't trust anything especially without part numbers on it, and this truck had after market tubular lower control arms that were hacked and lowered and welded all up funky so who knows what other steering parts it had)
Old 06-23-2022, 01:32 AM   #89
Gregski
Gregski's Avatar
so both upper and lower control arm seals showed up today from Classic Parts and they seem hefty and pretty nice, we shall see how they fits
Old 06-23-2022, 01:33 AM   #90
Gregski
Gregski's Avatar
and here's how the Classic Parts uppers compare to the flimzy junk LMC tries to pass on as their uppers
Old 06-25-2022, 11:14 PM   #91
Gregski
Gregski's Avatar
used an impactor to press the lower control arm ball joints
Old 06-25-2022, 11:17 PM   #92
Gregski
Gregski's Avatar
got the old 67-70 upper and lower control arms mounted as well as the new 71-72 spindles
Old 06-25-2022, 11:18 PM   #93
Gregski
Gregski's Avatar
test fitting the A5 inner bearing (heavy duty) and the A3 outer bearing
Old 06-28-2022, 09:08 AM   #94
Gregski
Gregski's Avatar
so nice to put clean bits back on
Old 06-28-2022, 09:10 AM   #95
Gregski
Gregski's Avatar
test fitted the 1 1/16" stabalizer bar, this is an optional component I decided to add, felt it was as good of a time to deal with it now rather than later
tell us if you are running a anti sway bar and if it made a difference for you?
Old 06-28-2022, 09:10 AM   #96
Gregski
Gregski's Avatar
and here she is back on her feet - and I couldn't be happier
yes we are building a 100% electric truck here: My Dusty 71 GMCe Electruck
Old 06-28-2022, 09:13 AM   #97
Gregski
Gregski's Avatar
now I gotta deal with this junk, I know I will need a new proportioning valve one designed for drum/disc brakes instead of the drum/drum one, but can I salvage any of the original tubing, donno yet, I will let you know after I transfer all that dirt and grime off them parts and on to my face
Old 06-28-2022, 09:15 AM   #98
Gregski
Gregski's Avatar
a little motivation
WILWOOD Combination Proportioning Valve (pronounced: adjustable)
Old 06-28-2022, 11:14 AM   #99
Gregski
Gregski's Avatar
me going to plumb the brakes
Old 06-28-2022, 07:23 PM   #100
Gregski
Gregski's Avatar
on a second thought let's do some steering link common core math
So there are two ways to get there as far as I know, which Kevin has said already 7 different times, lol
OPTION 1: keep 67-70 center link and 5/8"-18 inner tie rods (new MOOG es370r)
will need: Classic Performance tie rod sleeve adapters part #cp4sc-sab $80 bucks
and 71-72 MOOG es415rl 11/16"-18 outer tie rods
OPTION 2A: get all 71-72 C10 steering linkage
will need: a used C10 center link (getting more difficult to find these days and not available brand new)
and new MOOG es403L 11/16"-18 inner tie rods
and new MOOG es415RL 11/16"-18 outer tie rods
OPTION 2B: get 71-72 C20 steering linkage (center link and inner tie rods, the rest from a C10)
will need: a used C20 center link (only difference is larger inner tie rod holes, aka the two in the middle)
and new C20 MOOG es409LT 11/16"-18 inner tie rods
and new C10 MOOG es415RL 11/16"-18 outer tie rods
