Old 11-01-2012, 05:03 PM   #226
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Project: B.A.D. 1976 K30 CCLB
I've been compiling a list of parts for this truck so I can try to get it going before the new year. I did get a 73-80 front clip for it, so the newer one is off of it. We happened to get a rebuilt diesel 47rh, so now I have to get my triple disc billet TC re stalled for this truck. I've been talking with the wife and the sun visor is coming off, and the truck will be a magenta color with upper and lower mouldings. The interior is going to be black now. Since this is her truck, she's getting to make some calls. (I hope the color doesn't bite me in the...)
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-01-2012, 05:06 PM   #227
tecky11
i doubt it. it was great meeting you in person too
Truck: 1972 International Harvester 1210
Engine: Caterpiller 3116 220 HP 630 tq
Transmission: Eaton Fuller rt 6610
Axles: Merritor I beam front axle
tecky11 is offline   Reply With Quote
Old 11-01-2012, 11:08 PM   #228
jbclassix
Junk Yartist
jbclassix's Avatar
For a while i was wondering if this was going to get sacrificed for your 67-72 crew build
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 11-02-2012, 10:07 AM   #229
Mattman2010
Mattman2010's Avatar
That's a lot of work to get done. You and your dead lines , really looking forward to seeing this one!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 11-05-2012, 11:27 AM   #230
82ccshorty
82ccshorty's Avatar
when this truck was lifted the 22inch?(ithink thats what you said) was it drivable? as far as steering and stoping? im thinking about doing this to a truck/suburban and i need to get a parts list. Did you ever have shocks on it? what all did you have to use to correct the steering? as far as drop pitman arm, steering block? what all did you have to use for that? Thanks and awesome truck
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 11-16-2012, 12:44 AM   #231
68burbanontherocks
68burbanontherocks's Avatar
If ryan doesnt mind i think i could answer this question haha. First off you need to think about what direction you want to go with the truck... e.g. mall crawler, mud bogger, ect. If you are considering going with that big of a lift and tires (12" and heavy military 53's) i would strongly look at going to at least 2 1/2 tons. the 6.72 gear ratio will allow you to compensate with a under powered motor if thats the case. Again really depends on what your intentions are with the vehicle, as well as budget! But leafs run pretty bad when they get that arched cause they typically add leaf packs as well as if its going on a truck or even a suburban i would look at a dot tire cause the military tires are really friggen heavy and dont flex on rocks at all i think some of the bias ply ones are like 12 or 14 ply. I would look into a set of coils or nitrogen shocks and do a single or double triangluated 4 link. Also i would look into hydraulic steering unless you are wanting to do a frankenstein steering setup that at the end of the day your still counting on a stock pump to turn big heavy tires with alot of stress on the whole steering setup. Brakes if you run rocks go with pinion brakes 6 times as strong as wheel brakes but spin 6 times as fast so they heat up pretty quick.
I speak 100% from experience ha, i built my truck with big gawdy 25" leaf springs and 54" boggers and it ran like crap really stiff, very unstable and sucked driving anywhere.
So i pulled it apart built a tube frame chassis, running a double triangluated 4 link setup a blown alcohol injected 572 big block boggers and race blown nitrogen shocks.
http://67-72chevytrucks.com/vboard/s...d.php?t=510400
If you have any questions at all please just ask and ill do my best to help as much as i can, hope this helps ya out a bit... sorry ryan for hacking your build thread its pretty schweet!
68burbanontherocks is offline   Reply With Quote
Old 11-16-2012, 05:37 PM   #232
Dieselwrencher
Hey man, no problem here at all. If anyone argues with you, they don't have a clue. I'm all about putting the info out there so the more the merrier.
Ryan
Old 12-29-2012, 06:33 PM   #233
legendman
legendman's Avatar
Great build, subbed, hope you finish it
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 03-08-2013, 02:24 PM   #234
dieselmec1993
grerat built wish i had my truck back with the 10 inch lift i had and 44's it road rough but was beautiful truck
1977 k20 frame with 85 cab and hopefully 6.5 diesel.
1981 c20 long box 250 3 on the tree daily driver.
1982 k25 with 86 cab tired 350 4speed trans 37in military tires.(project Frankenstein). 8.
1984 c30 crew cab dually 6.2diesel next project
only 18 and finshed 5 projects started when i was
dieselmec1993 is offline   Reply With Quote
Old 05-22-2013, 01:58 PM   #235
mcbassin
Still Learning
mcbassin's Avatar
Very cool project Ryan. I didn't realize you had so many irons in the fire....subscribed
mcbassin is offline   Reply With Quote
Old 05-22-2013, 08:32 PM   #236
Dieselwrencher
Mike, this truck is really on the back burner now. It's storage and a yard ornament until further notice. Haha
Ryan
Old 05-22-2013, 08:33 PM   #237
jbclassix
Junk Yartist
jbclassix's Avatar
Do you have enough burners?
-Jeremy
Rebuilding an NP205
Old 05-22-2013, 08:34 PM   #238
Dieselwrencher
No, that's why they're all not done.
Ryan
Old 07-27-2013, 12:06 PM   #239
msblackbetty79
msblackbetty79's Avatar
Originally Posted by Dieselwrencher View Post
Back then, 8' boxes were bringing a premium. So being a novice at metal work, I'm not saying I'm a pro now, I purchased some bed patches and I welded all the DRW fender holes shut and installed patches to make it a SRW bed. Boy it sucked.
Here is a shot of lifting the rear some more.
And here is a shot of one other time when it was drivable, kind of.
this is an awesome project ryan! im kinda new to here but ive read this forum and ive decided to switch my plans! i got a question for ya though. ((on the bottom picture)). I love the stance of your truck, at that stage. could you tell me the size of lift you were running body and suspension? and also what size tire rim combo were you runnin?
this is an awesome truck man are you still wrenching on it??
79 Chevy 3/4 Longbed = just parts now
http://67-72chevytrucks.com/vboard/s...d.php?t=572221
Wanting to Start: HELP!
79 Crew Cab, 1st got to get the basics.
http://67-72chevytrucks.com/vboard/s...99#post6192399
msblackbetty79 is offline   Reply With Quote
Old 01-11-2014, 12:52 PM   #240
glimmertwin01
glimmertwin01's Avatar
i think it will look great as the 76 it is... although im partial to the round headlights. and high hood. i have only owned 2 short beds.. and wasnt too fond of them as I tend to use my trucks as trucks.. that thing will be cool as hell but not sure about Magenta... but I guess that will discourage you from using it....lol
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 01-12-2014, 12:26 PM   #241
Dieselwrencher
Sorry for not responding msblackbetty79. If I remember correctly in that picture it had 6" springs in the front with the 4" tube inbetween the front spring hangers and frame, and longer shackles netting about 11-12". The rear had a shackle flip with 4" blocks. Then the body was stock, no body lift. The tires were 36" military goodyears with 16.5x9.75 american racing wheels. Thanks, I plan to finish it someday and it can be one of my kid's first vehicles. We shall see.
Ryan
Old 01-12-2014, 12:30 PM   #242
Dieselwrencher
I think we dodged a bullet on the magenta as now the wife has an Excursion and I can do whatever with the old 76 now. On the short bed, I have plenty of long bed trucks and have never owned a 4wd short bed so I figured, why not. I'm planning on taking the front leaf springs from the Longhorn and putting them in this when I switch to air bags on the front of the Longhorn. Engine will probably be a p-pump 12v that Mathew, Brothers69C10, has as he borrowed it for mock up. It'll probably still get a 47rh and NP205 because I still have them for it. When will this all happen? Who knows really.
Ryan
Old 07-02-2014, 08:42 PM   #243
Dieselwrencher
There may be hope for this truck yet. I sold the front doors off it and my friend who baught them put the GM doors I had laying around back on it. I'm picking up a different bed this weekend for it, and have plans to put a 12v p-pump engine in it with a NV4500 and maybe a 241c tcase in it. This will happen after I can actually drive the Longhorn. I want to put this link on here for the GM hinges so I don't forget to buy these for it as well.
http://www.gmpartsdirect.com/results...number=6262007
Ryan
Old 07-02-2014, 08:48 PM   #244
Dieselwrencher
Here are some pics of the different doors on it. Poor truck.
I will be going with the newer type of mirror that is on the LH front door. I have a pair of NOS mirrors I picked up a while ago for it. Plan is a cowl hood and a dark green metallic paint job with maybe a pewter center and new trim. We'll see if I can swing all of that.
Ryan
Old 07-02-2014, 11:12 PM   #245
COS399
COS399's Avatar
Glad to see some progress. Keep it up.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 07-03-2014, 12:15 AM   #246
mcbassin
Still Learning
mcbassin's Avatar
Good progress Ryan. Love to see GM parts staying on the road
Old 07-07-2014, 01:25 AM   #247
Dieselwrencher
I'm trying to stay with as many facrory pieces for the body as I can. But it's getting tough for these pre 81 trucks it seems.
Thanks to my brother Nick and friend Adam, we went and picked up another short bed for this today. I plan to use the bed sides from this bed on my old floor. This bed came with an access toneau cover, a rust free tail gate, and an aluminum fuel cell. Not a bad deal imo.
Ryan
Old 07-07-2014, 11:18 AM   #248
COS399
COS399's Avatar
Ryan your going to have to change the title name to CCSB.
Old 07-07-2014, 02:23 PM   #249
Dieselwrencher
That's a good idea.
Ryan
Old 07-07-2014, 10:01 PM   #250
Ackattack
Ackattack's Avatar
Re: Project: Little Truck 1976 K30 CCSB
Just think if I would have bought this thing before I bought my '97 someone would be driving it!
Ackattack is offline   Reply With Quote
