Old 08-03-2015, 04:23 PM   #226
smbrouss70
smbrouss70's Avatar
Re: Project Cannonball C10
Originally Posted by mikentosh View Post
They are 19x12 Forgeline RB3Cs with Michelin Pilot Super Sport tires in 345/30R19 fitment. I forget the exact offset right now but we've done a fair amount of modifications to the front fenders to get the wide stance.
Are your wheels the same offset front & rear? If they are, I assume that your rear end width matches the front width, correct?
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 08-04-2015, 10:50 AM   #227
mikentosh
mikentosh's Avatar
Yes, its a square setup so wheel offsets are same front and back. Rear end width is very close, if not identical, to front width based on how close the tires sit to the fenders.
mikentosh is offline   Reply With Quote
Old 08-04-2015, 12:24 PM   #228
OutlawDrifter
nice build, just jumped in today and read through everything.
the ramp truck will be a nice touch at sema.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 08-10-2015, 12:53 PM   #229
Low Elco
Diggin' the ramp truck!
Low Elco is offline   Reply With Quote
Old 08-31-2015, 12:59 PM   #230
Low Elco
61 days! What's going on?
Old 08-31-2015, 04:24 PM   #231
mooseknuckles
mooseknuckles's Avatar
Sema crunch..
mooseknuckles is offline   Reply With Quote
Old 09-01-2015, 01:23 AM   #232
mikentosh
mikentosh's Avatar
Originally Posted by mooseknuckles View Post
Sema crunch..
Yeah pretty much that. There has been a lot of progress in the last month, but nothing that really photographs well 😊
Old 09-01-2015, 01:24 AM   #233
mikentosh
mikentosh's Avatar
We've got the hood back from initial bodywork. This is a US Body Source fiberglass 73-80 hood, which has been modified to remove the aero peak along the front edge to retain the early 70's look.
Old 09-01-2015, 01:26 AM   #234
mikentosh
mikentosh's Avatar
To keep the smooth firewall look, we put in a modern wiper motor sunk into the back of the cowl area. With the plans we have to drive this thing I want to make sure its got proper wipers 😊
Old 09-01-2015, 01:36 AM   #235
mikentosh
mikentosh's Avatar
Got around to another subtle modification that I'd been thinking about since the inception of this project...shaved pinch welds. In my opinion the pinch welds on the front fender and under the cab makes the truck look like it was snapped out of a mold, so off they go! This will also help when we go to fit the belly pans 😊
Old 09-01-2015, 01:39 AM   #236
mikentosh
mikentosh's Avatar
We took a minute to put it on the scales and see where things sit. Remember that this is sitting without any glass, interior or cage in it right now, so we'll be putting back on several hundred pounds. Still, its well on its way to achieving my two goals of < 3500lbs and 50/50 weight distribution 😃
Old 09-01-2015, 01:41 AM   #237
mikentosh
mikentosh's Avatar
Thought you might like to see the rendering that @Rickthedutch made up for me. If you've been following on Instagram then you've probably seen his buildup to this.
Old 09-01-2015, 01:48 AM   #238
mikentosh
mikentosh's Avatar
Then we moved onto the roll cage. I have specific requirements for this cage so it won't be an easy build. First thing is to build out proper supports for it.
These pieces are pretty much my favorite thing done to the truck so far. It integrates the front cab mount and ties it into a reinforced front rocker section with the landing pad at the top for the cage to attach to. The sections bolt together for cab removal.
Time to break out the plasma table...
...put it together...
...and onto the truck...
Old 09-01-2015, 01:55 AM   #239
mikentosh
mikentosh's Avatar
One more for the night: Here's the electronics backplate cutout and mounted to the rear cab wall. This will hold all the stereo equipment (amps, crossovers) and truck electronics (Dakota dash modules, fuel pump computer, e-brake module, fuses, relays).
Old 09-01-2015, 05:27 PM   #240
tinydb84
tinydb84's Avatar
Man that thing is so well thought out. I think I saw the shop truck a few times over by the airport.
Do you have more pics/details of how you shaved the pinch? Mine will have to go but I haven't really thought out how I want to do it.
David
Instagram: myfabguy
Old 09-01-2015, 06:49 PM   #241
mikentosh
mikentosh's Avatar
Yeah, the shop is down near SJC off Reed so you've probably seen us bombing around in the ramp truck a few times 😃
I don't really have any more detailed pics of the shaved pinch on my phone. Will try to grab some when we put the truck back up on the lift. Here's the closest I've got:
I like this photo as you can see all the sand that came out of the rockers a year after getting the cab blasted.
Old 09-01-2015, 07:13 PM   #242
tinydb84
tinydb84's Avatar
Thanks for the pics. I work right near there. Too bad I don't make enough to have him work on my junk hahaha
David
Instagram: myfabguy
Old 09-02-2015, 01:57 PM   #243
Low Elco
Very tidy work. I like the shaved pinch.
Old 09-24-2015, 12:55 PM   #244
Low Elco
Dude, we're dyyyyyin' over here! What's going on?
Old 10-05-2015, 01:45 PM   #245
mikentosh
mikentosh's Avatar
We've been busy, but progress hasn't been as quick as hoped, so...
The Bad: We are not going to make SEMA this year I didn't want to rush the details on this thing, and reassembly is the part I'm looking forward to...would have been sad to rush it in a couple of weeks.
The Good: We can spend some time on a few more custom details that I've been thinking about.
Oh yeah, I also picked up another project truck to add to the madness: Project Two - '74 Sierra Grande
Anyway, the main focus over the last month has been getting the cage completed.
Old 10-05-2015, 01:56 PM   #246
Trixxterr
Mmm, can't wait to see the finished product. Going be one he'll of a nice ride.
Trixxterr is offline   Reply With Quote
Old 10-07-2015, 12:55 PM   #247
Low Elco
Awesome now- gonna be a game changer when done. Would be cool to target Sema next year and just blow it completely out of the water. Love this truck, as if you couldn't tell.
Old 10-07-2015, 01:02 PM   #248
mikentosh
mikentosh's Avatar
Yeah, this time we should be good to make Power Tour and SEMA for 2016. I'm sure in a year from now I'll look back at this post and wonder how I could think that hahahahahaha.
A preview of some interior ideas: we tore down one of the original seats I had for measurements, as you can see in the pics above. I find the stock bench is not wide enough so you end up sitting on the corner when driving. The plan is to do a 1 1/2 inch wider frame all in aluminum, then cover it in OEM inserts with leather surrounds. Hopefully this will dump another 50+lb from the assembled truck weight.
Old 10-10-2015, 03:55 AM   #249
mcmlxix
Collector of Projects
mcmlxix's Avatar
I'll grab a few more pics tonight.
Our plan is to get to SEMA but we've got a lot of work ahead of us to get there.
In case you aren't following my Instagram feed, Wes made a new purchase for the shop for our trip down to SEMA in November...a '73 Squarebody C60 ramp truck. Like we need another squarebody project ��
I heard SEMA overbooked display car space. Are you still going to bring the truck? Do you have a place to display it yet? I live in Vegas and try to go if I can score a pass.. otherwise I like to at least check out the outside and entry hall...
Rich
1972 K5 Blazer CST Click HERE
Old 10-10-2015, 05:16 AM   #250
mikentosh
mikentosh's Avatar
No we can't make it this year. Just too much stuff I want to do on it still. We did get a pass but gave it up to another aquantence. They got the denial letter because of the overbooking.
TBH, I'd much rather go to Dino's Get Down and Scottsadle Goodyguys anyway.
