Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-18-2010, 04:37 AM   #251
Rack Man
Re: "FRAME OFF" Has Begun - Wish Me Luck! - Pics
Thanks Guys!.....I have been working away trying to get her done....She's close!....Got nearly all of the interior in and done..It looks pretty awesome if I do say so myself ....but now I am having some issues getting the body panels aligned...AARGH!......I'm close but I can't seem to get to get the "gaps" fitted quite right yet!....you adjust one area and it throws off another area.....It's a royal "B"...The "play" in the core support seems to be where the final adjustments are going to come from.
Also, the weatherstripping on the doors has proven to be a real challenge....I have to SLAM the passenger door hard to get it to close....Hopefully it will get better with time!
Should have some more pics posted up real soon!.....She will be going to get a little front end alignment/adjustment work soon, as right now she is all over the road (steering wise) and I have no idea how to fix it!
All in all I'm pretty happy with the resto.....Everyone who see's the truck loves it!...
Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 04-18-2010, 04:43 AM   #252
Rack Man
Originally Posted by Mr-Jack View Post
looks good...even with the dust on the seats did you paint your shift knobs or are those new?
Those are the original shift knobs....I tried to "restore" them but I couldn't find away to make them look new...No matter what I did the "Haziness" always came back...I couldn't find NOS (at a decent price) or Repop knobs so I just decided to live with the old ones!...
Dan
Old 04-18-2010, 04:44 AM   #253
Rack Man
Originally Posted by sdailey View Post
Looking good Dan. You're almost there.
Thanks Shannon!.....Your well on your way!...I have been watching your build intently!......Keep up the good work, she's looking Awesome!
Dan
Old 04-18-2010, 07:45 AM   #254
msgross
msgross's Avatar
There isn't much alignment work that can be done on these solid axles. You replaced all of the ball joints right? (drag link, tie rod, knuckles etc...) The steering box is new as well? If there is "play" in the system id' have a buddy turn the wheel slightly while you look at all of the components to look for a loose item.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-18-2010, 04:18 PM   #255
Rack Man
Yea, I think the "caster" and "Toe" are the only adjustments on the solid axles...And yes I did replace all those parts you mentioned and I even upgraded the steering box to a quick ratio unit!.....I hope betweeen those two adjustments it will fix it.....
Old 04-18-2010, 10:13 PM   #256
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
There is a set screw on the steering box with a lock dwon nut on it.
That takes the play out of your steering.
I bet it is set lose from the factory.
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
Old 04-18-2010, 10:19 PM   #257
Conroe trucker
What are you doing for carpet?
That Blue sure looks good!
Let us know how that interior paint holds up.
Have you tried to see if it will flake off or split?
01 C5 convertable
08 Z06
Old 04-19-2010, 12:11 AM   #258
Rack Man
I ordered everything from stockinteriors.com.....I got the molded carpet, the gas tank cover and the carpeted kick panels....They had a lot of color and style choices....I went with the 80/20 Loop in medium blue (#552)....All of the carpeting is in and fit really good!
I have handled the dyed interior pieces quite a bit and there has been no flaking whatsoever....The stuff I used really soaked in well, I was pretty amazed to see it work...so I think its going to hold up well!
Here's the lnk to the carpet I got:
http://www.stockinteriors.com/AutoCa...=31&ModelId=88
Oh and thanks Conroe for the steering box tip...I'm sure that is a lot of the problem....I'll keep you posted!
Dan
Old 04-26-2010, 09:25 PM   #259
Billhilly
Billhilly's Avatar
Just wondering how you are getting on with the wheel alignment thing?
One thing I did with mine during the build up of the chassis was snap a centreline lenghtwise under the chassis and then drew lines under where the front and rear diff's sat. I also measured the distance between the two diffs. Turns out both diff's wern't square to the centre line, and not parallel in relation to each other. I sratched my head for a long time and ended up turning one rear leaf end for end, and slotted out the hole in the right side of the front diff to allow the diff to be squared up. Got it 'pretty close' to everything heading in the same direction! Have no idea if any of this made it drive nice. Years away from finishing!
Let us know how you got on.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 04-26-2010, 10:11 PM   #260
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
My axles are the same way, they aren't square or parallel so ill probably end up elongating a couple of the holes in the spring perches to make it right.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 04-29-2010, 10:16 AM   #261
austinleonhardt307
austinleonhardt307's Avatar
Damnit! Now it's between three colors that i'm painting my pickup. Excellent truck man
austinleonhardt307 is offline   Reply With Quote
Old 05-11-2010, 01:37 AM   #262
Rack Man
Well....I'm almost there!.....Got the interior finished, the grill installed and the front bumper on...Also, I also had the truck wet-sanded and buffed by my painter....a quick $800 down the drain for that!
Still need to do a little fine tuning on the body panels..After installing the grille and hood I found some more gap issues....its close but not perfect and Im not positive that it will ever be 100%....aligning those body panels is probably the hardest thing I have had to do....then again I've never done it before, so I'm sure I'm missing some of the tricks.
Also the bumper is way out of whack....looks like I'm going to have to "slot" the bracket holes....the front part of the frame must be tweaked a little bit from the winch that was on there when I got it....
The truck is currently at a buddy of mines shop getting the brakes power bled, front end & steering box adjusted and getting the AC system evacuated & charged.
Here's a couple pics....I'll post some more later.
Old 05-11-2010, 07:26 AM   #263
cjohns
cjohns's Avatar
I'll take it!!!!!Looks great RM!!!!!
cjohns is offline   Reply With Quote
Old 05-11-2010, 07:46 AM   #264
Teck
Teck's Avatar
Thumbs up Re: "FRAME OFF" Has Begun - Wish Me Luck! - Pics
Congrats on the great work. Truck looks awsome.
1986 K5 Blazer
Teck is offline   Reply With Quote
Old 05-11-2010, 08:15 AM   #265
watahyahknow
watahyahknow's Avatar
that truck will win some prices , its beautyful
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-11-2010, 08:55 AM   #266
sdailey
The Few, The Proud
sdailey's Avatar
Looking good Dan.
Shannon
sdailey is offline   Reply With Quote
Old 05-11-2010, 10:23 AM   #267
gcburdic
Restoration Virgin!
gcburdic's Avatar
freakin' fantastic.....awesome build Rack-Man
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-11-2010, 11:15 AM   #268
estig70
estig70's Avatar
can't beat that color blue.
nice truck rackman.
Oh yeah, sweet interior. I use the 72 style door panels in my 70 but I like yours which are what should be in mine. NICE!
Eric
estig70 is offline   Reply With Quote
Old 05-11-2010, 01:09 PM   #269
austinleonhardt307
I saw that you had to replace a rocker panel. Do you have any pictures of what it looked like before? Mine are pretty bad but i don't know which parts to order because they have parts like inner rocker, outer rocker, rocker extended etc.
Old 05-11-2010, 05:53 PM   #270
dammitmitchell
the pollock
dammitmitchell's Avatar
Dang dude!
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 05-11-2010, 08:01 PM   #271
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Damn that turned out nice..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 05-11-2010, 08:52 PM   #272
0331grunt
Now what??
0331grunt's Avatar
That is a beautiful truck!! Congrats
69 Long Fleet - Project
06 Ram 1ton Cummins 4x4-DD
01 Tahoe- wifes
"The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi
"A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell
my, um, build
USMC OIF Veteran SEMPER FI!
0331grunt is offline   Reply With Quote
Old 05-12-2010, 12:28 AM   #273
bowtieguy79
Ephesians 2:8
bowtieguy79's Avatar
Nice Job! Love the color! you can't beat a Blue Chevy with a White top!
bowtieguy79 is offline   Reply With Quote
Old 05-12-2010, 09:20 PM   #274
Rack Man
Looking good Dan.
nice truck rackman.
Eric
Thanks erveryone!.....Its been fun but I'm glad its coming to an end....just need a break to enjoy now!
Old 05-12-2010, 09:23 PM   #275
Rack Man
I don't have any good pics that show that damage....but I only needed to replace the one outer rocker and front pillar patch....You will need to inspect yours to see if there is any other damage.....
