Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-30-2013, 09:45 AM   #251
Hart_Rod
Hart_Rod's Avatar
Re: My build thread.. 63 LS powered C10
Sweet! I guess your motor likes a little back pressure.... Do you have the part number for the wire?
Hart_Rod is offline   Reply With Quote
Old 06-30-2013, 01:07 PM   #252
Marv D
Registered Truck Offender
Marv D's Avatar
Any idea what's going on? We both know you should have been UP on power not down!
Is there a fuel stability issue there in the fuel your running?
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-30-2013, 10:08 PM   #253
Super73
Super73's Avatar
GRN-28-1545HT From summit
Marv, I don't think it is a stability issue, I think it is a design flaw in my exhaust system. The cut outs are on the straight portion of the y. They are 3" cut outs but the hole is actually 2.5" so there is a 1/4" lip. 3" means they bolt to a 3" collector. I am wondering if the lip is causing a weird reversion pulse.
Won't really know for sure as I am expecting a new set of headers. Sure hope they fit.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-29-2013, 11:05 AM   #254
Super73
Super73's Avatar
It has been almost a year since I have taken the truck for a ride, but I did this sat and sun. Since I had it on the dyno I:
Fixed vacuum pump
Swapped to 2" headers
adjusted my power enrichment. Multiplier for wide open throttle
I stood on it yesterday and all I can say is WOW. Fueling is right where it should be, there is no traction in low gear even from a roll and rolling in to the throttle. Once in se@ond and wide open, this thing flat out fly's.
Noy sure if it will be enough to go 9's on motor, but I think it will definately be faster than the 10.5x before.
Old 07-29-2013, 02:54 PM   #255
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
That's BAD A Shaun. Congrats.
I busted my timing belt last Sunday. Bent all the valves and push sticks.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 08-01-2013, 10:02 PM   #256
Super73
Super73's Avatar
Graph to come later..
540rwhp on motor
650rwhp with a 57n/35f jet
710rwhp with a 70n/42f jet
Both n20 tunes a little fat
Old 08-01-2013, 11:47 PM   #257
Super73
Super73's Avatar
Correction, forgot SAE correction..
516rwhp is on motor
615rwhp is with a 57n/35f jet set up
687rwhp is with a 70n/42f jet set up
Old 08-03-2013, 02:50 AM   #258
BigDan3131
BigDan3131's Avatar
Well once you put all those fiberglass parts you mentioned a while back on it you should be able to hit the 9's. Are you, were you going to move the radiator to the rear?
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 08-03-2013, 11:42 PM   #259
Super73
Super73's Avatar
By the way, open exhaust netted more power this time. I figured out my flaw with the other exhaust system.
Old 09-03-2013, 10:05 AM   #260
smoky02
Location: Sunny, Florida, some might call it South Alabama
What was the flaw?
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 09-04-2013, 08:31 PM   #261
Super73
Super73's Avatar
The cut out placement put the exhaust exit 12" in front of the flat spot on the front of the muffler. I think it was causing a pressure wave to bounce off the muffler at WOT. Basically causing reversion and the two pulses were colliding not allowing the exhaust to move from the pipe freely.
I go to the track on Friday though
Old 09-11-2013, 01:03 PM   #262
70shortwide
Well???? do we have any more track results?
70shortwide is offline   Reply With Quote
Old 09-11-2013, 02:35 PM   #263
68 C-10 KID
Mean Green
Ya we want some wheels up videos!
AKA MEAN GREEN.
Old 09-12-2013, 02:22 PM   #264
Super73
Super73's Avatar
Sorry guys, not every track outing can be great. I had a lot of issues the were pretty much all by me being lame..
First pass, I am the 2nd vehicle down the track. Do my burn out, put it on the brake and it blows the tires off, I peddled it but it was already in high gear, went 12.x at 124.. Check shock settings and everything seems normal.
2nd run, burn out, on the brake leave, again, blows tires off.
3rd run, same damn thing.
4th run decide to foot brake it. I roll in medium lay aggressive and it hooks a 1.67, goes 10.7x at 123.4.
Figure track must be coming around, try it off the brake again on pass 5 and again blows the tires off. I happen to look at the log for something and something caught my eye. There was an rpm dip when I would first leave. 5kish to 4,600ish. Son of a gun, my 2step ain't working. Dummy me, I moved it out of the way before coming to the track, thought I reset it to 3,500 but mixed up the 100 and 1000 increments. I had it set for 5,300.
With it reset at 3,500, it dead hooked a 1.57 and went 10.6 at 123.5 with only 23 of the normal 27* timing.
The next 2 passes were nothing but trouble with the N20 controller. First time using one and it tested good in the garage and at the track in the pits running. Disconnect both N20 and fuel noids, bring it up to 3,500-4,000 and have my buddy hit the throttle switch. Both noids puls and there is fuel from the fuel side. Pull timing from the tune, bring it to the line, leave and the N20 does not come on.
It is now 9:30 and the track closes at 10. I decided to bypass the controlled since it just grounds the noids. I am going to roll in to the throttle with now tbrake so I don't over power the tires. Leave, bottle comes on and it is pig rich shooting ducks. About the 1000' mark I have water on my windshield. Looks like I may have lifted the heads.
So, I have a few changes I plan on making to help that situation. I think the NOS launcher will be coming out and I will be trying a different controller. But with a baby coming in the next 2-6 weeks, it will sit in the garage.
Old 09-14-2013, 07:16 PM   #265
djracer
djracer's Avatar
The nitrous controller that Nx sells is the stuff. I forget the name of it but hey are out of Canada. It's cheap and works great.
Good luck on the little one.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-16-2013, 08:48 AM   #266
68 C-10 KID
Mean Green
Dang that's some intense stuff to go through. Congrats on the soon to be new born.
AKA MEAN GREEN.
Old 09-17-2013, 12:17 PM   #267
Super73
Super73's Avatar
I have heard great things about this from 2 local guys: http://www.daytona-sensors.com/downl...structions.pdf
Old 09-22-2013, 03:17 AM   #268
BigDan3131
BigDan3131's Avatar
Sorry to hear about the water but congrats on the baby coming soon!
Old 09-23-2013, 01:52 PM   #269
Marv D
Marv D's Avatar
I didn't even see that you had been to the track Shaun, CONGRATS
Hey nothing broke so it was a good trip right!!!
What kind of air were you running in? 10.6's on the motor is pretty darn respectable.
Is lifting the head a common issue when your up in the 600-1000HP range? Wha are some of the big boys with TT doing to keep it sealed up?
As I remember,, isn't D getting real close to delivering??? You better get all the racing in you can buddy. I suspect it's going to be a while before you get any 'free time' to go play.
Old 09-23-2013, 04:30 PM   #270
Super73
Super73's Avatar
Marv,
Weather was similar to my 10.54 pass, but I only had 23* in the tune up.
There are a few things I am planning to adjust when the heads come off:
ARP's original tech file said tq heads to 65lbs. Then moved them to 80lbs. Now they recommend 90lbs. Mine were at 80lbs.
I have been told by some turbo guys and heavier N20 guys, the newest thing is taking apart the cometic gasket and dusting copper coat between each layer.
My quench was at .044 which the bigger N20 guys are running between .065-.100 to take some efficiency out of the the quench. Too tight and the resolution of timing might be an issue. Heck, my combo was efficient as it only wanted 25-27* total timing on motor.
Danielle is due in 2 weeks. I won't be doing much for the next 6 months.
Old 09-24-2013, 02:36 AM   #271
BigDan3131
BigDan3131's Avatar
Is there any difference between the cometic gaskets and the LS9 gaskets? I have been hearing quite a few people are using the LS9 gaskets.
Old 09-24-2013, 10:25 AM   #272
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The ls9 cam and gasket have been GM's choice for in house forced induction projects, and it's what I've seen used in some FI lsx projects in the industrial markets as well (which is cool as hell)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-24-2013, 05:35 PM   #273
Super73
Super73's Avatar
The LS9 gasket is a great gasket. There are turbo guys using that gasket to right about 1000rwhp. But in my case, it won't work due to the issue of quench. It would put me where I am now.
Old 12-17-2013, 09:11 PM   #274
Super73
Super73's Avatar
Well boys and girls, I was ready to sell my truck and buy a car from a member here. Thought long and hard and decided I just couldn't do it. So instead, I am yet again making some major changes and in some cases going back the opposite direction then what I have.
No, I am not planing on going slower, quite the opposite actually, but I do plan on making the truck more streetable again.
I have decided I am going twin turbo, will most likely loose the glide and go back to an 80e with a 3.73 gear as apposed to my current 4.56. I will also be moving over to a 6 bolt LS block at some point, just not any time soon, well unless someone really wanted my motor
The attached pic is the newer PTC6768 turbos. Long term goal is somewhere around 1200rwhp on high boost and a solid 8.50 to tap the cage cert yet be able to drive it from my house to LA if I wanted.
My xmas consisted of:
(2) CEA6768's with a .96 AR
(2) PW46 waste gates
(1) XS 50mm BOV
(2) Bell 4 1/2" x 16" x 10" air to air intercooler cores
Eboost 2 controller
And a bunch of misc silicon fittings, clamps, and flanges.
In addition to that, I was able to get an auger for my tractor. This will help me turn the 288 railroad ties I have in my driveway in to some retaining walls, level a big area that some day I will put a shop on.
Old 12-17-2013, 09:32 PM   #275
71Dragtruck
71Dragtruck's Avatar
Very nice!!
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
