Old 07-10-2008, 10:49 PM   #276
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Re: GMC V-12 powered '91 Chev crewcab
looks great!!!
That is going to be a wild headturner when you get it on the road..
tommie is offline   Reply With Quote
Old 07-11-2008, 10:31 AM   #277
Storm Chaser
Storm Chaser's Avatar
Wow, that's a pretty good looking cab! You just don't see 'em like that around my parts. You're doing great work there- keep it up and keep it coming!
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 07-14-2008, 08:04 AM   #278
That is wild looking!
Old 07-14-2008, 10:04 AM   #279
cayoterun
Junior Member
cayoterun's Avatar
Hit an interesting detour. This cab is from a different year model 3/4 ton. Has more rust than the one from the '62 1/2 ton which I plan to use. Was just going to use this one for a pattern for cab mounts, etc. to reduce the chance of dings, and bangs on the "good" cab during fit. Rechecked both, and found cab mount location and some other stuff was different than the good cab.
Soo, it's off with this one, and use the good one for fit. '62 cab has very little rust, but some dinged doors typical with this year model trucks, but alot easier to repair than structural rust damage.
The front clip will end up being a hollow shell/w a fake 26"+- extention panel to accomodate the motor and big radiator.
Hoping to get Turbojunker's look, post #150,/w no hood, maybe some tool boxes under the bed, lower rear end some, and running boards for old people.
There are bits and pieces of all you folks ideas incorporated in this, so
Thanks,
Cayoterun
Add: If someone wanted to chop a pic with the added wants mentioned, I'd appreciated it. Need one to print & post in shop for inspiration.
Cayoterun
Okla. Panhandle
I think I'll do it myself and pay the extra $500.
cayoterun is offline   Reply With Quote
Old 07-18-2008, 06:26 PM   #280
cayoterun
Junior Member
cayoterun's Avatar
First fit '62 cab and clip
Looks like the clip will be stretched about 28" and overall hood length about 6'4". Probably stacks will go and 4 exhaust pipes under cab later on. I think they make it look too cluttered. What do ya'll think?
Cayoterun
Cayoterun
Okla. Panhandle
Old 07-18-2008, 06:56 PM   #281
watahyahknow
watahyahknow's Avatar
it doesn't look to bad now that i see it in real life with the streched noze
maybe you schould make the exaust like they have on old fighterplanes like the mustang sticking out the sides that makes it eazier to stick a bonnet on there too .
imagining hitting the trottle driving next to some import with the windows rolled down
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 07-18-2008, 08:27 PM   #282
It's coming together pretty nice. I like the stacks, but wonder also about it being nicer looking routing underneath.
Old 07-18-2008, 10:43 PM   #283
cayoterun
Junior Member
cayoterun's Avatar
We need to reduce the exhaust noise also with mufflers of some kind. The noise level is so loud above an idle, you couldn't stand to drive it. It would be ok for a parade, nothing else.
Passing a small car might blow all the windows out. It sure makes the metal shop rattle.
Cayoterun
Cayoterun
Okla. Panhandle
Old 07-19-2008, 10:31 PM   #284
Storm Chaser
Does the exhaust ports match up to any popular V6 out there? If so, you could maybe get 2 pairs of "shorty" style headers.
That thing is lookin' pretty wild!
1988 R2500 Crew Cab
Future plans-
Old 07-19-2008, 11:51 PM   #285
cayoterun
Junior Member
cayoterun's Avatar
Good Idea. I'll look for headers for the old V6s to see if anything is available that might work.
I had it running today, and those stacks has gotta' go. Not only loud, but with the fenders, it's almost impossible to work on the motor. I'm afraid some kind of custom headers will need to be made. The pipes will need to come over the top of the frame and back on the outside.
Our son pulled some 5" chrome mufflers and stacks off his Pete, so we were thinking of maybe trying to build a reducer for the headers to those stacks and run them horizontal on the outside the frame under the cab, then tip them out in front of the rear tires. They have heat shields around them, so burnt legs shouldn't be a problem. Improvise as we go, then do it again, right?
Cayoterun
Cayoterun
Okla. Panhandle
Old 07-20-2008, 06:52 AM   #286
watahyahknow
if push come to shove you could use the original cast headers and make a y pipe to the pete exaust , if you find the shorty header for the V6 it just might be they fit in place of the originals on the adapterpipe
or youcan make one big log type exaust 12 in one out can make it in stainless and it will look good , its not a performance item so you should be ok and it dampens the sound too
i found this one rod runnin logs thats a bit fuzzy don't mind the flames its just for the idea
Old 07-20-2008, 11:43 AM   #287
cayoterun
Junior Member
cayoterun's Avatar
Watahyaknow, When you call it a "log" type, are you refering to something like this? If so, I imagine that's what will be needed for space reasons.
On something like this, do you guys ever get what we call "Think blind"? Thought process seems to lock up on one idea, then someone suggests something "outside the box" and bingo, they have the obvious solution.
Thanks for the help
Cayoterun
Cayoterun
Okla. Panhandle
Old 07-20-2008, 02:18 PM   #288
89 crew
If you want it to be quieter, go for 4 standard mufflers.
89 crew is offline   Reply With Quote
Old 07-20-2008, 02:42 PM   #289
joe231
joe231's Avatar
very cool!!!
nice work
CHEVY ONLY
Old 07-20-2008, 04:00 PM   #290
watahyahknow
its kindah like that only it connects to the head itself 6 pipes going in the big log/ tank like thingy and from there the propper sized pipe to the pete stacks you might be able to make some sort of dampening material on the inside of the log but not mush it most likly will only stop the machinegun sound when you lift the trottle
Old 07-21-2008, 09:36 PM   #291
cayoterun
Junior Member
cayoterun's Avatar
Here's to ya, Mickey D. Thanks for the name. Balaur has 4 dragons/w three heads, each head firing one cylinder.
Exhaust manifolds/headers? There's plenty of room for about anything, except the left front head. We only have about 4" of clearance between head and steering sector. I'm sure it will take a homemade manifold of some kind.
Cayoterun
Okla. Panhandle
Old 07-29-2008, 08:06 AM   #292
bb1979
bb1979's Avatar
Cool project, I read that you sourced another piston from a junker motor but did any of the other leads eg Egge result in new pistons being able to be sourced.
I only ask because a hot rodder here in Australia is installing one of these beasts into a 32 Ford 3 window and his pistons are toast
1979 C20 pickup 454 big block turbo 400, 4.56 gears
bb1979 is offline   Reply With Quote
Old 07-29-2008, 10:26 AM   #293
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Hmm, what about tranny?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 07-29-2008, 11:17 AM   #294
cayoterun
Junior Member
cayoterun's Avatar
For my use on this, I'd like to find a 5spd over manual from behind a 401 or 478 V-6 GMC truck and use as high a rear end ratio as possible. GMC used New Process, Clark, and Spicer, but so far, hard, hard to find. I do have a 5spd direct and 3spd aux that can be used, but wouldn't be as simple as an overdrive. There are other options such as a custom adapter for Automatic use, but very pricey. Final choice hasn't been made on this. Lot's of fitting and fabrication to do on the other stuff.
Thanks,
Cayoterun
Cayoterun
Okla. Panhandle
Old 08-08-2008, 09:17 AM   #295
cayoterun
Junior Member
cayoterun's Avatar
Sorry, bb1979. I overlooked your question for piston sources. New pistons and internal parts are almost non-existant. There are places that will custom-build them. All parts new, or used are pretty pricey. When I was looking for pistons, a salvage yard told me he sold used pistons for $80. each, but didn't have any. I was never able to find any source with anything in stock. Good source for info and leads is www.gmcguy.org.
Exhaust manifold: This is what I finally came up with to get past the steering box. I'll probably need to wrap it with insulation as it still runs close to valve cover and steering box. I cut the stacks, connected them, then down & out. Steering box sits in front of pipe. Crude and rough, but hope it works. For now, will use stock manifolds on the other three.
Tranny: Another guy is working on an adapter for an T400 or 4l80E auto. It looks good so far, but not finished. An auto would sure simplify things.
Cayoterun
Okla. Panhandle
Old 08-08-2008, 02:52 PM   #296
Hart_Rod
Hart_Rod's Avatar
Just spent over an hour reading your thread.........this is one of the coolest builds I've seen! Glad to see another Okie likes big trucks, .
Hart_Rod is offline   Reply With Quote
Old 08-21-2008, 05:48 PM   #297
cayoterun
Junior Member
cayoterun's Avatar
Body mount position?
The belt line of the body--front clip, cab, and bed,---needs to run parallel, (level), with the frame? Is that right?
It's time to start mounting body mounts to frame, and wanted to be sure.
Thanks,
Cayoterun
Cayoterun
Okla. Panhandle
Old 08-22-2008, 12:00 AM   #298
MonteSS454
MonteSS454's Avatar
Why don't you just run stack behind the cab like a big rig?
Just collect all 4 header pipes into 2, run a muffler on each side under the cab then stacks behind the cab?
MonteSS454 is offline   Reply With Quote
Old 08-29-2008, 12:48 PM   #299
Damien
Damien's Avatar
Does the V6 share exhaust ports with a V8 that headers could be gotten for such as a big block chevy? If so, one tube could be cut out.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 08-29-2008, 04:06 PM   #300
cayoterun
Junior Member
cayoterun's Avatar
MonteSS454: I like the idea of stacks behind cab, but having a 60gal propane tank mounted on bed in that area, holding indirect heat away from it would be wise. By dumping exhaust underneath would make the safety inspectors alot happier, whether the stacks would pose a safety threat or not.
Damien: I don't know if a V8 header would match. There are headers made for Jimmy V-6, but since this is mounted in a different frame (F--d), headers would have to be custom, so we have ended up with this homemade set-up 'til we see how everything else comes together.
Progress: Radiator is mounted independent of front clip on its own frame crossmember. It's a 5 row tube industrial radiator.
Front clip can be removed by pulling about 8 bolts, and truck will still run and could be driven. Probably no hood to start with. Cab can be pulled by about the same # of bolts, and a few controls and wires. A bunch of improvements could/will be made later.
Tranny question still undecided, but hoping to use a T400 auto tranny.
I ask OHP about front fenders. They think we could run w/o fenders and front clip as long as we have the required lights in front. They couldn't find any statutes that specified certain requirments for FRONT fenders in Okla. REAR fenders/mudflaps, yes. Note: Important body working tool in floor. (trusty sawzall).
Thanks for all the suggestions. There are bits & pieces of any/all used in this, so let's keep thinking outside-the-box.
Cayoterun
Cayoterun
Okla. Panhandle
