Old 12-16-2012, 12:59 PM   #276
farmtrucks
farmtrucks's Avatar
Re: LS swappers, post up your pics!!
Originally Posted by cjohnson6772 View Post
First off let me say that this truck is PERFECT on so many levels. I love love love the design and execution here. Was hoping for some more details on your a/c compressor bracket. Am I correct that you had to notch the stock bracket for adapter plates? I've heard this discussed a few times but never seen any pictures of it done. Thanks in advance.
I basically used glock35ipsc modified engine bracket design, and did what RocketKing done, except with v8 mounts and put them in the front frame holes - there is no modificactions to the a/c bracket, it worked perfect.
http://67-72chevytrucks.com/vboard/s...d.php?t=413855
farmtrucks is offline   Reply With Quote
Old 12-28-2012, 04:11 PM   #277
Frostflowz
Frostflowz is offline   Reply With Quote
Old 01-08-2013, 05:38 PM   #278
Indian113
Indian113's Avatar
I have my S10 on the road and loving every mile!!
Indian113 is offline   Reply With Quote
Old 01-08-2013, 10:26 PM   #279
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
oh that ought to be some fun!!!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-08-2013, 10:32 PM   #280
Indian113
Indian113's Avatar
OH YEAH ! It is,worth all the headaches and trouble
Old 01-20-2013, 04:00 PM   #281
Benlugchev
Benlugchev's Avatar
Originally Posted by farmtrucks View Post
Another TN truck
What heater core are you running on this rig. I want heat but dont like the looks of the stock bulky heater core hanging on the firewall.
71' Chevy C10-Turbo 6.0L-80e-JFR218-738hp/700tq-10.1@133mph... 1.54 60' (3737lbs)
00' GMC-c2500-Turbo 6.0L-80e-JFR212-500hp/560tq -11.67@116mph (5182lbs)
Benlugchev is offline   Reply With Quote
Old 01-21-2013, 07:11 PM   #282
effects66
effects66's Avatar
Here is mine, LSX on a freshly powder coated frame. About to get everything plumed and wired.
____________________________
My build:
1970 C10, 550hp LSX, Ridetech suspsension
http://67-72chevytrucks.com/vboard/s...d.php?t=556610
effects66 is offline   Reply With Quote
Old 01-21-2013, 07:16 PM   #283
Frostflowz
Nice headers, what size are they?
Old 01-21-2013, 07:19 PM   #284
effects66
effects66's Avatar
Thanks, They are 1 7/8"
Old 01-21-2013, 07:55 PM   #285
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
How did you get the a/c compressor to fit in there? I have a 72 GMC with a 01 6.0 DBC and no such luck making the compressor fit down there.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 01-21-2013, 07:57 PM   #286
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
How did you get the a/c compressor to fit down in there? I have a 72 GMC with a 01 6.0 DBC and I have had no such luck.
Old 01-21-2013, 08:56 PM   #287
Street Smart
Street Smart's Avatar
I used the ac comp that came with my 6.2, fit no problem, no cutting at all. I used adapters on the lines from "Docs Blocks" but i don`t think they are still in business.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 02-05-2013, 09:40 AM   #288
farmtrucks
farmtrucks's Avatar
Vintage Air A/C unit
Old 02-05-2013, 05:05 PM   #289
flamingbig10
6.0 powered square
flamingbig10's Avatar
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 02-10-2013, 09:52 PM   #290
Benlugchev
Benlugchev's Avatar
Originally Posted by flamingbig10 View Post
thats a sweet looking engine bay! I love it. how did you get your wiring harness through the little hole you made in your fire wall? im looking to do the same mount the ECU under the dash.
Old 02-10-2013, 09:57 PM   #291
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I ran my wire harness thru plate that clutch rod would go thru.
Old 02-10-2013, 10:22 PM   #292
mooseknuckles
mooseknuckles's Avatar
that hole is there from the factory...the psi harness comes with a grommet on the harness hat fits in the hole...
mooseknuckles is offline   Reply With Quote
Old 02-10-2013, 10:50 PM   #293
Benlugchev
Benlugchev's Avatar
I understand, I realize this was 73'+ but by judging the size of all my connectors on each end of my LSx harness, I dont think I could feed them through a hole that small?
Old 02-11-2013, 02:07 AM   #294
flamingbig10
6.0 powered square
thanks I ran them from the inside being careful with all the connectors, it takes time but its not to bad
Aaron
Old 02-13-2013, 12:56 PM   #295
aggie91
I'm just glad to be here!
aggie91's Avatar
Here is our inprocess pic's, My son's Red Rover '82 C-10:
Since that picture, we have redone the motor/frame mounts. We are changing the pan to an LSA pan for more clearence. The set up is a5.3/4L60e out of a 2000 GMC. We are using the stock truck front accessories, just going to smooth up the brackets and paint them.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 02-14-2013, 04:42 AM   #296
hilljob26
hilljob26's Avatar
well, heres mine at its current state
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 02-14-2013, 09:32 AM   #297
71K20chevy
71K20chevy's Avatar
That's pretty awesome, I love LS motors in lifted trucks.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 02-14-2013, 01:35 PM   #298
hilljob26
hilljob26's Avatar
thanx man,its been quite a bit of work so far,,but its coming along
21 2500hd duramax
58 apache
My build thread
4l60 to an NP205
Old 02-21-2013, 03:47 PM   #299
short-t
short-t's Avatar
1968 C10 SWB with ECE 3.5/5 drop and a 2007 TBSS LS2. Drove it for the first time yesterday after the swap... Holy poop!
1968 C10 LS2/4L70e swb fleet side. ECE front disk conversion and 3.5/5 drop. SOLD.
1968 C20 Custom Camper 396 50th survivor! SOLD to northerngmc
short-t is offline   Reply With Quote
Old 02-21-2013, 05:56 PM   #300
Indian113
Indian113's Avatar
Nice looking Truck,they sure are a lot of fun with the LS motor!
