12-01-2013, 01:08 PM | #276 |
Re: Project "Captain Insano"
Here's the caddy taillights I did. I doubt I would do that again. I think I was just wanting a challenge.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
12-07-2013, 02:41 PM | #277 |
12-07-2013, 02:45 PM | #278 |
Laid Back
Looking good!
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
12-08-2013, 10:26 PM | #279 |
Awesome build, can wait to see you get this thing on the road
1969 C10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=580422 1981 C10 SWB 1995 ECSB Bagged |
01-28-2014, 10:34 PM | #280 |
Wheels are in today! I was pushing my luck with the 5" BS but it looks like I have about 3/4"-1" clearance. We'll see once I get the tires on. Hopefully this weekend. I think Friday is supposed to be in the 60's, so I'll be able to open up the garage and get some better photos. Thanks again Kyle for hooking up some savings.
01-28-2014, 10:41 PM | #281 |
Thanks again Mike for the core support. swapping out the headlight area wasn't bad at all. I reblasted it last weekend, now ready for some primer.
Steering column came in today also. It's Summit brand $300 one. (actual brand, I don't know) but I've heard good things about them. SUM-770700
01-28-2014, 10:56 PM | #282 |
Still Learning
The wheels look great! Congrats!!
Killer work on the core support. Glad to see it go to good use. Keep the pictures coming. |
01-28-2014, 11:28 PM | #283 |
Wow nice wheels, can't wait to see it with the tires on
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-30-2014, 08:41 AM | #284 |
01-30-2014, 10:12 AM | #285 |
Laid Back
Awesome work on the pulleys...
01-30-2014, 05:46 PM | #286 |
Man, that's nice to be able to make your own pulleys. Do you work somewhere that lets you do that, or do you own the machines to do it at home?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
01-30-2014, 07:19 PM | #287 |
Very cool!
01-30-2014, 09:29 PM | #288 |
I like the pullys! I did the exact same thing on my core support. Couldnt bring myself to spend money on a new one when I have a perfectly good 72 support I could cut up!
Rob 1971 c10 - ground up in progress Tripp's Speed Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=589750 |
01-30-2014, 11:25 PM | #289 |
Still Learning
Killer work on the pulleys Daniel! Love fringe benefits
02-02-2014, 12:21 AM | #290 |
The wheels are awesome but I think I'm more impressed by the pulleys you made wow... If you had a bigger lathe and or mill you could make your own wheels
BTW, Where did you get the billet accessory brackets?
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
02-02-2014, 12:29 PM | #291 |
Thanks for all the comments. I use the machines at work when I have spare time. I would like a mill and lathe at home, but I don't have room for a shop in my neighborhood.
mcbassin - I'm sure if you took the time to program some pulleys, you could break out some nice ones on the cnc. Now that the idea is planted. Dan - Those are March Alt/AC & Power Steering brackets. Your welcome to print these brackets up and make them if you want to. Their only mocked up on the engine right now. I just have them up temporarily to take measurements for the pulleys.
02-02-2014, 12:32 PM | #292 |
02-02-2014, 02:10 PM | #293 |
Project looks great! Is that column the factory length for our trucks? Do you have a picture of the shift linkage? Thanks,
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-02-2014, 02:27 PM | #294 |
Still Learning
The wheels look right at home with the rubber on them. That's a huge step forward.
02-02-2014, 03:26 PM | #295 |
I believe the column is 1" shorter than stock. I'm 6-1"/6-2" so I prefer to lose an 1" plus it's tilt. The shift linkage is like stock. But now I've got to figure out how to hook up the shaft. Needs a double D verses stock spline. I'll probably cut up my stock shaft rather than spend $150 on a new one. The column is just sitting in there now. I'm going to try and set it as close to the gauge cluster as I can get it while still being able to remove the cluster.
02-03-2014, 10:50 PM | #296 | |
Is that measurement to the very end of the column (double D)? Also, is the column collapsible? This is for my 16 year old son and I want it to be as safe as possible. Thanks for the help.
Rob Quote:
02-04-2014, 12:14 AM | #297 |
Laid Back
Wheels and tires look great Daniel!! Perfect tire size..
02-04-2014, 10:26 AM | #298 |
I will pull it out tonight and take some measurements. It's not collapsible. I'll make sure the shaft to the gear box stays collapsible though. I added summit racings part number a few posts back if anyone wants to check it out on there site. They have pretty decent descriptions.
02-04-2014, 10:29 AM | #299 |
Thanks! I was a little worried that I chose too short of a tire, but I wanted the same height front/back. I love the look now.
02-04-2014, 10:34 AM | #300 | |
