04-12-2018, 07:16 PM | #276 |
Re: Roushinator's 72 C10 Stepside Restore/Build
Trying to sort out the routing of my Speartech Wiring Harness. Going to try and hide the wires as much as possible
Ryan... 1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain http://67-72chevytrucks.com/vboard/s...11#post5532411 |
04-12-2018, 11:50 PM | #277 |
None of my business but I would suggest using a Y and distribute fuel equally to both rails.
If your pump is not up to the task the last couple cylinders might get thirsty. |
04-13-2018, 09:46 AM | #278 |
That would only change the location of which cylinders are thirsty, as you say. If the pump isn't up to the task, the pump would need to be changed.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
04-13-2018, 09:48 AM | #279 |
Looks good Ryan! Might I suggest trying to run the injector and throttle body section of the harness under the intake? That might help conceal it a bit. Just a thought though.
04-13-2018, 10:00 PM | #280 |
Yeah i'm going to do that. I am taking the intake off to get a Ceramic clear coating. So when i get that back i will do that.
04-13-2018, 10:02 PM | #281 |
I have a Boyd Welding tank with a In-Tank Aeromotive Stealth 340 Pump. I will double check to see if it good enough.
04-15-2018, 08:48 PM | #282 |
A little more progress....
04-15-2018, 09:02 PM | #283 |
Looks great Ryan!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-16-2018, 10:13 PM | #284 |
04-20-2018, 08:43 PM | #285 |
A little more work done..
Got my steps primed* and had my radiator core support painted.
04-28-2018, 08:34 AM | #286 |
Awesome build!
That pump should be plenty for that setup. As you said no need to change the fuel line routing. Mine deadheads same way and is a TT LSx427 making 1000+ (I have bigger pump obviously). |
04-29-2018, 09:11 PM | #287 |
Trying to get a little work done on either my truck, car or garage organization. Here is wht i did today...
Here are the custom badges. Dont know if this will be the final location. Going to wait until the fenders are on the truck before deciding.
04-29-2018, 09:14 PM | #288 |
Maybe this has been answered, but I'll ask again cause i didn't see it. What radiator and fans are you running? Looking for something for a similar build in my C10 (LY6/6L90e planned). Want to be sure it'll stay cool towing!
04-29-2018, 09:33 PM | #289 | |
https://www.entropyrad.com/1967-1972...uck-radiators/
04-29-2018, 09:39 PM | #290 |
Excellent thanks. I've been looking at cheap (champion) and more expensive C&R. Just trying to figure out my costs for swapping.
06-02-2018, 12:15 PM | #291 |
I like the radiator mounts and brackets. Nice work on everything.
65 short step edited by staff |
06-02-2018, 09:50 PM | #292 |
Any updates?
08-25-2019, 10:32 AM | #293 |
Got rid of my cab and opted for another one.....
08-25-2019, 10:35 AM | #294 |
Here is some progress pics of the current one..
08-25-2019, 11:00 AM | #295 |
Cab is looking excellent. Is that Nsane doing the cab work?
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
08-25-2019, 11:19 AM | #296 |
Thanks. Yes.
08-30-2019, 10:37 AM | #297 |
Getting Closer...
08-30-2019, 03:59 PM | #298 |
Better than new! It will be nice to not have to tweak anything but adjusting your doors and fenders going back on.
09-03-2019, 03:58 PM | #299 |
Wow, they did a great job on the metal work, cab looks fantastic
09-04-2019, 05:23 PM | #300 |
Looking great. That motor looks MEAN AF. Can't wait to see this build progress!
