#276 | |
Re: Brave or crazy? crewcab build
I should get two of each just to be safe! |
#277 |
Thanks for the feedback guys!
When are u bringing that hood by? |
#278 |
Very well done!
Posted via Mobile Device |
#279 |
Any progress brother???
#280 |
Loving it!!! I've wanted to try it myself!!
Apologize for the any progress reply, didn't see the latest and greatest updates. I'm a rookie to this site... |
#281 |
Got some more work done today I worked on the rocker for the 4th door.
I used two new rockers to make one.I also worked on the back side of the b pillar I used the rear of the pass side b pillar off another sub. I flipped it upside down to fit also worked on upper door channel I used the same method on this area. Everthing is roughed in I wanted to get more done but it got late and I ran out of argon. |
#282 |
Lookin good though!!!
-Rus |
#283 |
Man I have been keeping a eye on your build. Man luv what your doing. Great ideas and like the fourth door. Subscribed!!!!!
LIFTED OR LOW THE ONLY WAY TO GO!!!! Check out my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=517346 Projects 56 Chevy pickup Porterbuilt FR/RR dropmembers |
#284 | |
Hopefully I can start work on the door soon |
#285 |
Time for some door pics, after lots of measuring its time to cut up a super clean rust free arizona door. This door was coated with under coating on the inside so I had to strip some off so it would sit flush.
#286 |
Heres some more pics
#287 |
Junk Yartist
This is the fun part!
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#288 |
more pics
#289 |
Oh man you are making it look easy!
-Rus |
#290 |
#291 |
I'm sure you probably measured it 10 ways from Sunday before you started, so chances are it will fit.
#292 | |
man look at at all those holes I have to fill! |
#293 |
Junior Member
![]() Join Date: Jan 2008
Sweet, Your making great progress. Looks awesome.
#294 |
lol!
Did you roll the front edge of the door skin like it would be from the factory? |
#295 |
#296 |
That works too.
#297 |
Junk Yartist
Duse you have done more in 2 months than I have in 3 years
#298 |
67cheby
![]() Join Date: Sep 2008
Killing it man !
#299 |
chevy only
![]() Join Date: Sep 2006
great job!!
CHEVY ONLY... Nothin Else ! |
#300 |
Junk Yartist
Do you have your hinges attached in that picture?
