Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 06-18-2007, 09:00 PM   #301
Hart_Rod
Hart_Rod's Avatar
Re: 1969 Burb build-up (Bags, 5.3/4L60E, repaint, interior....)
Originally Posted by texanidiot25 View Post
Man, the buick didnt take much of a hit compared to the Nissan.. Glad she's all right!
I love those seats, where can I pick up a set for the front? And any custom color combos?
The Buick was in worse shape than the picture shows. Seats are 67/68 Buddy buckets. You can find them if you look around. I had an upholstery shop custom make the covers. Here's another link:
http://67-72chevytrucks.com/vboard/s...=1#post2079024
Hart_Rod is offline   Reply With Quote
Old 06-18-2007, 10:32 PM   #302
blaznhot_23
blaznhot_23's Avatar
those seats look hot...
blaznhot_23 is offline   Reply With Quote
Old 06-19-2007, 01:35 AM   #303
shaneschevys
Its always something!
shaneschevys's Avatar
Those seats look great! You cant beat the look of the hounds tooth interior.
79 p10 stepvan
72 Short Fleetside
72 Suburban
67 GMC One Ton Flatbed
64 Short Fleetside
57 Chevy 2DR Hard Top
57 Chevy 2dr wagon
65 f*** short fleet
63 C 60 Flatbed
Member of the patina club
shaneschevys is offline   Reply With Quote
Old 06-20-2007, 02:01 PM   #304
Hart_Rod
Hart_Rod's Avatar
Got the holes cut out for the a/c. I'm going to use the new "GEN 4" from vintage.
Old 06-20-2007, 02:37 PM   #305
shifty
Questionable
shifty's Avatar
i might as well ask now - is there an indicator to know where to drill the holes, or is everyone just drilling those "wherever"? if you did "wherever", how did you measure/mark where to drill?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 06-20-2007, 06:50 PM   #306
Hart_Rod
Hart_Rod's Avatar
67ChevyRedNeck is doing a write up where he describes the install:
http://67-72chevytrucks.com/vboard/s...d.php?t=245132
You can download the templates and print them out (pages 19 and 20):
http://vintageair.com/DownloadsSecti...ols)%20Ine.pdf
I ended up moving the location provided by the template because the vent wouldn't fit quite flush (the dash is curved). I measured 1 1/2" away from the side of the door (inboard) and 1 3/4" up from the bottom of the dash. There's a brace behind the dash that you will have to trim to allow the back side of the vent to screw on correctly, but it was pretty simple. I can take pictures if you need. I borrowed one of my billet aluminum vents from my 48 to test fit and it fit quite well.
I talked to Vintage Air the other day and I think this is evaporator/control panel I'm going to put in the Suburban/CrewCab, the Gen IV an it's all electric.
http://www.vintageair.com/cat2006/19.pdf
http://www.vintageair.com/products2006.asp
They are also working on retro-kit that will allow you to use the factory unit with this kit (no time frame given).
Old 06-25-2007, 10:25 PM   #307
Hart_Rod
Hart_Rod's Avatar
Did a little more work on the round a/c vent holes. Hammered and dollied them a little to get the vent to fit flush to the dash.
Old 06-26-2007, 03:32 PM   #308
Frizzle Fry
Frizzle Fry's Avatar
I like those vents.
Frizzle Fry is offline   Reply With Quote
Old 06-26-2007, 04:33 PM   #309
shifty
Questionable
shifty's Avatar
I like the vents you'll find in a lot of new cars - like the ones I had in my RSX before I sold it. They look like this:
http://www.handa-accessories.com/rsxtrim.jpg
Basically, you can push them flat (closed) or push them open. They spin 360º to put the air wherever you want it.
Old 06-26-2007, 04:46 PM   #310
Hart_Rod
Hart_Rod's Avatar
Those are pretty cool. Here's some more:
http://www.hotrodair.com/index.cfm/p...rod/prd173.htm
http://www.billetspecialties.com/pro...cid=8&scid=113
http://www.streetrodstuff.com/Products/1300/
Old 06-26-2007, 05:04 PM   #311
BowTieOgre
Man the ones in the first link are pretty sweet!
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 06-27-2007, 12:39 AM   #312
randomhero472
randomhero472's Avatar
hart, looking good!! Why are you going with the GEN4 kit rather than sure-fit for our trucks?
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 06-27-2007, 08:19 AM   #313
Hart_Rod
Hart_Rod's Avatar
There's a couple of reasons I'm using the GEN IV. First, the "Surefit" is a retrofit kit meant to be installed with the factory holes and requires no firewall modifications. I smoothed my firewall and eliminated all the factory heater/ac holes. Secondly, the GEN IV is the most modern unit that Vintage Air sells. It's all electronic, no slide cables or vacuum pods like the sure-fit kit.
R
Old 06-27-2007, 01:50 PM   #314
shifty
Questionable
shifty's Avatar
Hmmm, uses the factory holes eh? I still haven't welded mine shut Question is - is it the same big bulky SIZE as the factory setup?
Old 06-27-2007, 02:29 PM   #315
Hart_Rod
Hart_Rod's Avatar
Gen IV or the SureFit??
Old 06-27-2007, 08:37 PM   #316
shifty
Questionable
shifty's Avatar
Surefit. You said it plugs into all of hte factory firewall holes - but is it as big and bulky in the engine bay (heater core, blower setup) as the stock unit?
Old 06-27-2007, 10:29 PM   #317
Hart_Rod
Hart_Rod's Avatar
Here's some pictures and a link to a SureFit install:
http://67-72chevytrucks.com/vboard/s...ad.php?t=61810
Vintage Air Surefit manual:
http://www.vintageair.com/DownloadsS...ir)%20Inet.pdf
Link to a CAA install:
http://67-72chevytrucks.com/vboard/s...d.php?t=161402
Old 06-27-2007, 10:32 PM   #318
Hart_Rod
Hart_Rod's Avatar
Finished off the transition are from the rear tail pan to the truck quarters. It will be covered by the bumper, but I didn't want it to look like an after thought. I also got the body ready to come off the chassis (this weekend hopefully!).
R
Old 06-27-2007, 11:21 PM   #319
shifty
Questionable
shifty's Avatar
Oh, it's THAT setup. Yeah. I'm still waiting for someone to develop a kit that pulls fresh air from outside the truck - something innovative, like ... that will put the blower in the kickpanel vent and pull from outside, allowing people to shave their firewall, install a bulkhead, and still get fresh air to cool down.
Old 06-27-2007, 11:37 PM   #320
Hart_Rod
Hart_Rod's Avatar
With the Gen 4, you could always pop open your vents in the kick panel for some fresh air, .
Pictures with the bumper on:
Old 06-28-2007, 05:37 PM   #321
shifty
Questionable
shifty's Avatar
Looks superb, you do great work! How many hours you reckon you have in that? 35?
Old 06-28-2007, 06:13 PM   #322
Frizzle Fry
Looks Awesome!
Old 07-17-2007, 12:22 AM   #323
Tucson72
I really like this project. I am very interested in some of the parts you listed from ECE, where can I see the parts online or where can I get a catalog? Any help would be graet thank you.
Tucson72 is offline   Reply With Quote
Old 07-17-2007, 12:37 AM   #324
shifty
Questionable
shifty's Avatar
Google for Early Classic Enterprises.
Old 07-17-2007, 12:54 AM   #325
Rokcrln
Rokcrln's Avatar
Well I have been gone awhile but this thing is looking good. I really like the tail lights, stock burb lights never sat well with me.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
