Old 03-24-2008, 03:34 AM   #326
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good Blazer...
Originally Posted by jlaird View Post
gringo, Ive got that same crossmember but its from performanceonline.com Why did you need more exhaust clearance? isn't there plenty of room to run it above the x-member? Also, why did you move the mount 1 inch up? I wasnt planning on hacking this thing up.
Going under gives a straight shot for the exhaust pipes from the collector through the trailing arm crossmember- I'm building a mandrel bent exhaust and didn't like having all those bends right after the collector. Just personal preference- you don't have to hack it, I just prefer it this way. I moved the tranny mount up 1" to match the Dropmember engine mounting position. It is a little higher to clear the rack...
This is Hart_Rod's pic, but it illustrates why I modified my crossmember:
Originally Posted by bagged74 View Post
isnt that the blazer that board member slogo built?
Yep. That's even slogo's pic...
Originally Posted by abadsvt View Post
Looking real good Gringo! Keep up the great work.
Josh
Thanks Josh! Yours too.
Originally Posted by Hart_Rod View Post
Looking real good! Now all you need is a set of these..........
Or two...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-24-2008, 06:27 AM   #327
Hart_Rod
Hart_Rod's Avatar
Gringo,
I think it will clear the stock ECE tranny mount without any bends. Here's some better pictures from the rear.
R/
Hart_Rod is offline   Reply With Quote
Old 03-25-2008, 06:01 AM   #328
gringoloco
A guy with a truck
gringoloco's Avatar
Gringo,
R/
Nice. I'll have to swap back to the straight style when the 5.3 goes in my pickup. I'm gonna try a set of mid length F-body headers on the Blazer to see how they'll work...
-Chris
Old 03-25-2008, 08:09 PM   #329
Frizzle Fry
Frizzle Fry's Avatar
Can't think of much worse than trying to pass off someone else’s ride as your own... oh ya, maybe doing it on the same board where the owner posts
Frizzle Fry is offline   Reply With Quote
Old 03-26-2008, 03:30 AM   #330
5150
C10 Club Tennessee
5150's Avatar
call me an idiot, but either slogo sold the blazer to another guy in Morristown or he paid the money to have his Board Name changed.
I'm going with #2
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 03-26-2008, 04:50 AM   #331
Frizzle Fry
I'm going with #2
Well, that would explain it I hope that's the case because slogo deserves credit for what he did.
Old 04-27-2008, 10:46 PM   #332
killer71
killer71's Avatar
R we dun yet?
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 04-29-2008, 06:45 AM   #333
1lo67
1lo67's Avatar
Not to Hi-jac this but I am slogo or (use to be)....long story. just so everybody knows i didnt buy it and now trying to take credit for something that's not mine. sorry for the hijack.
BTW I think your blazer rocks
1lo67 is offline   Reply With Quote
Old 04-29-2008, 04:18 PM   #334
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by killer71 View Post
R we dun yet?
Hah! Not even close. I've been playin' with the truck too much...
Thanks! Yours aint too shabby either
-Chris
Old 06-30-2008, 01:58 AM   #335
randomhero472
randomhero472's Avatar
come on!!!!!!!!!!!! WHERES THE UPDATES!!!
67' in the "build" process.. soon to be bagged, big wheels ect, finally got it back home!!
randomhero472 is offline   Reply With Quote
Old 07-02-2008, 06:40 AM   #336
Rokcrln
Rokcrln's Avatar
I guess with the price of scrap metal he has decided to go a new direction
Come own now anything new, even I am needing a fix!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 07-02-2008, 04:18 PM   #337
hgs_notes
GEARHEAD
hgs_notes's Avatar
Kevin
LFD Inc.
You haven't exactly been lighting things up lately either. Time to man up and get back to work.
hgs_notes is offline   Reply With Quote
Old 08-05-2008, 10:04 PM   #338
98L150
///Relaxed Atmosphere
98L150's Avatar
hey gringo what shock did you use in the front of the blazer?
looking good
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 08-05-2008, 10:46 PM   #339
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! I used the PB recommended Monroe shock(32245) with the supplied upper mounts. Works perfectly.
-Chris
Old 08-05-2008, 10:56 PM   #340
Hart_Rod
Hart_Rod's Avatar
What oil pan did you end up going with?
Old 08-06-2008, 08:37 AM   #341
gringoloco
A guy with a truck
gringoloco's Avatar
I'm using the F-body pan. Clears the Dropmember fine.
For the stock crossmember you may try GM's swap specific pan: LH8 Pan.
There is also a Moroso Camaro swap pan- p/n 20140. I think it requires a remote oil filter though...
-Chris
Old 08-06-2008, 10:59 AM   #342
Hart_Rod
Hart_Rod's Avatar
I was just curious. I tried the Camaro pan and it was about 1" to long back to front (it just barely hit the back of the front crossmember). I ended up using a Cadillac CSTv pan. It works perfect with the ECE motor mounts. The LH8 pan would have worked also, but it hangs down lower. I gained about an 1" clearance with the Caddy pan.
Here's a link that discusses the different pan options:
http://67-72chevytrucks.com/vboard/s...40#post2818040
Old 10-16-2008, 10:33 PM   #343
gringoloco
A guy with a truck
gringoloco's Avatar
TTT!
I finally got my ass in gear and did some work on the Blazer: I built a narrow ('63-'70) 12 bolt rear axle for it; everything is new/rebuilt except the housing. It is stuffed with an Eaton posi and 3.73:1 gear and converted to 5-lug with CPP axles.
This rear is 3/4" narrower per side to better match the front Dropmember's width. It will also help the 295s tuck a little easier.
Obligatory pics, since you can't have an update without pics Sorry, but no in progress shots- it's hard to take pics covered in 90 weight More to come soon...
-Chris
Old 10-16-2008, 10:38 PM   #344
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Sweet, now hurry up & get it in
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 10-16-2008, 11:11 PM   #345
68 short step
bout time this is back to the top. glad to see some progress
68 short step is offline   Reply With Quote
Old 10-17-2008, 07:06 AM   #346
Frizzle Fry
You still have that Blazer?
Old 10-17-2008, 07:58 AM   #347
72BlckButy
Tot Roddin'
72BlckButy's Avatar
'bout time we see some more progress....
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-17-2008, 08:26 PM   #348
quandel_garage
nice ride
Quandel Garage......Making MONSTERS one ride at a time!
quandel_garage is offline   Reply With Quote
Old 10-17-2008, 11:04 PM   #349
gringoloco
A guy with a truck
gringoloco's Avatar
The first pics show how close the tires are to the quarter panels at full dump. The narrow axle will remedy this, and since I'm building custom tubs, I'll be able to clearance towards the inside as well.
I did manage to get the old axle pulled, but I have a lot of cleanup/painting to do before the new one goes in. Don't laugh at my layers of dust- at least I knocked off the cobwebs before i took pics...
-Chris
Old 10-17-2008, 11:24 PM   #350
Rokcrln
Rokcrln's Avatar
Dang by the time you get this beast back on the road the 4x4's will be the new craze
PS love the tire/rim combo!
Kevin
LFD Inc.
