Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 10-23-2019, 01:28 AM   #326
RookDogg7
Re: DBW Gas Pedal Adpater bracket for truck/suv pedal
Sent PayPal payment for one bracket. 2006 LQ9 going in 1970 2wd Blazer
RookDogg7 is offline   Reply With Quote
Old 10-23-2019, 07:00 PM   #327
Hart_Rod
Hart_Rod's Avatar
Shipped. Thanks!
Hart_Rod is offline   Reply With Quote
Old 10-26-2019, 08:42 PM   #328
SS68
SS68's Avatar
Sent paypal payment just now for a 70c10 with an 06 LQ9 with a plastic pedal - thanks
SS68 is offline   Reply With Quote
Old 10-26-2019, 09:12 PM   #329
Hart_Rod
Hart_Rod's Avatar
Got it, thanks! Will ship the first of the week.
Old 11-04-2019, 03:30 PM   #330
C10agent
C10agent's Avatar
Payment just sent through PayPal for my 1972 C10 LS Swap project - thanks! Neil
Neil...............
1972 C10 SWB - Shop Truck in the Works
5.3 LS / Full Air Ride / Rear Notch
20" American Racing Daytonas
IG - neilioustx - pictures of build/progress
Born and Raised in the Promised Land....
TEXAS Y'ALL!!
C10agent is offline   Reply With Quote
Old 11-04-2019, 06:53 PM   #331
Hart_Rod
Hart_Rod's Avatar
Thanks! Will ship tomorrow!
Old 11-14-2019, 01:16 PM   #332
C10agent
C10agent's Avatar
PM Sent
Neil...............
TEXAS Y'ALL!!
Old 12-12-2019, 11:25 AM   #333
clemsonteg
Do you have anything available for 60-66? Specifically a 66.
clemsonteg is offline   Reply With Quote
Old 12-25-2019, 02:10 PM   #334
SS68
SS68's Avatar
Originally Posted by CJM72 View Post
Rob,
Bought one of your brackets way back for my LQ9 (2006 Escalade) swap into a 1972 Blazer, but it isn't working out. Any recommendations based on the pictures below? The pedal part number appears to be correct for the Escalade, but the bolt pattern is more like the Vette pedal.
Probably should have double checked it before I powder coated it! Thanks
Attachment 1755543
Attachment 1755544
Attachment 1755545
Finally got around to installing the bracket and have ran into the same issue. Did drilling new holes solve your problem? I’ve thought about it but not liking the position of how it’ll sit
Old 12-30-2019, 01:57 PM   #335
2014sierraAT
2014sierraAT's Avatar
I had the same problem, I ended up having another plate welded to the bracket for the pedal assembly to bolt to, and cut off the plastic pedal and drilled a hole for the rod from a factory style pedal to slide into. It’s drilled/bolted and epoxied to the plastic base.
2014sierraAT is offline   Reply With Quote
Old 01-02-2020, 11:19 AM   #336
GeronimoApache
Sorry if it was already asked. Do you have a bracket that will work in a 55.5-59 cab? I have a 05 DBW pedal
GeronimoApache is offline   Reply With Quote
Old 02-02-2020, 11:29 AM   #337
Cmillwheels
Cmillwheels's Avatar
Hey Rob - just want to check availability. I’m swapping a truck DBW pedal into my 1968 C10. If you have more I’ll PayPal you and get one.
Thanks!
Chris
Cmillwheels is offline   Reply With Quote
Old 02-02-2020, 03:37 PM   #338
Hart_Rod
Hart_Rod's Avatar
Thanks!
Chris
Yes sir! Ready to ship.
Old 02-26-2020, 05:58 PM   #339
C.I.Blazer
Payment sent for my 71 Blazer. Thanks!
C.I.Blazer is offline   Reply With Quote
Old 02-26-2020, 06:39 PM   #340
Hart_Rod
Hart_Rod's Avatar
Got it, Thanks!
Old 04-11-2020, 05:20 AM   #341
Ghost's68
Ghost's68's Avatar
Will this bracket work with a 09 pedal? I thought I read somewhere they have same mounting hole spacing? Thanks
Ghost's68 is offline   Reply With Quote
Old 04-11-2020, 08:41 AM   #342
Hart_Rod
Hart_Rod's Avatar
It should be clisr.close. You might hsve to adjust the pedal mounting holes.
R
Old 05-12-2020, 04:18 PM   #343
HTX86chevy
HTX86chevy's Avatar
Hey Rob, Sent payment for a 1972 c10.
hope you have some in stock. I should have asked 1st.
HTX86chevy is offline   Reply With Quote
Old 05-12-2020, 04:29 PM   #344
Hart_Rod
Hart_Rod's Avatar
I do. Need a shipping address. Thanks
Old 05-28-2020, 11:22 AM   #345
sircrunch
I ordered one of these and painted it and it does not work. the description states it will work with 03-09 suv/truck pedals. however my 2006 suburban pedal is all wrong for this. it doesn't even come close to fitting.... even if i redrill new holes, the overall shape of the pedal and arm are such that it will not allow movement of the pedal. So i went on rockauto and i see that many other suv pedals look exactly like mine. And heres the bad part. Even if i am able to source an earlier model pedal, say one from 2004 (which according to rock auto pics is the one i need) won't i also need the throttle actuator control module thing also? it looks like my pedal and TAC control have different connectors from other pedals. Is there any other workaround? Looks like these have been sold for about 6 years. Why is it that I am having this issue just now? My bad luck? or what?
sircrunch is offline   Reply With Quote
Old 05-28-2020, 11:34 AM   #346
sircrunch
IT DOES NOT WORK
IT DOES NOT WORK
Old 05-28-2020, 11:55 AM   #347
sircrunch
UPDATE, the seller is going to have me try the corvette style pedal bracket. I will update when i give that a try.
Old 05-31-2020, 12:36 AM   #348
yellowGT
yellowGT's Avatar
If it don’t work for you I will buy the bracket from you
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 05-31-2020, 12:27 PM   #349
thehata1
Payment sent.
thehata1 is offline   Reply With Quote
Old 06-01-2020, 08:18 AM   #350
Hart_Rod
Hart_Rod's Avatar
The corvette bracket shipped Friday. Let me know when you get it.
Originally Posted by thehata1 View Post
Payment sent.
Your bracket will ship today. Thanks!
R
