Old 12-11-2015, 12:42 AM   #376
pimpston65
pimpston65's Avatar
Re: My suburban's Twisted Little Sister
should be soon, but i got myself cornered with the house. now I'm buying NOS mortised lock sets!!! and i pulled all the plastic windows in order from my window guy to make new solid wood sashes for me, the house is from 1919 so I'm keeping it right. once the burb is back and the garage is cleaned and prepped its ON!!!
pimpston65 is offline   Reply With Quote
Old 12-14-2015, 08:06 PM   #377
65sub
65sub's Avatar
Cool. Even your house gets NOS parts.
I made these brackets for the front shockwaves. They bolt to the LCA where the original leaf spring used to sit.
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 12-16-2015, 09:20 PM   #378
65sub
65sub's Avatar
We got the passenger side wheel tub widened 4". Then added a small angle strip and spot welded the tub to the frame.
Dale
Old 12-17-2015, 12:17 AM   #379
lower50's
lower50's's Avatar
Fender looks good. Is the body going to welded or hard mounted to the frame?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 12-17-2015, 04:43 AM   #380
Grizz1963
Grizz1963's Avatar
Done my daily exercise.... It includes a lot of head shaking in amaze,net at your progress. Makes my crawling about under my truck for a few minutes look pretty shi7.
Looking good man.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 12-17-2015, 02:12 PM   #381
Scott2
This build is amazing! I am merely struggling with repairing a few panels and typical rust on mine. Projects like this give me inspiration and some great ideas. Great work and I can't wait to see how it all comes together.
Scott
______________
my '51 build: http://67-72chevytrucks.com/vboard/s...d.php?t=677979
Scott2 is offline   Reply With Quote
Old 12-17-2015, 04:31 PM   #382
Kainedogg
Kainedogg's Avatar
Very cool build. Twin turbos off the V12 would be awesome/r
Science flies you to the moon; Religion flies you into buildings.
LeMans Turbo build http://ls1tech.com/forums/forced-ind...rbo-build.html
C10 build (twin-turbo) http://www.performancetrucks.net/for...didate-501987/
Kainedogg is offline   Reply With Quote
Old 12-17-2015, 10:44 PM   #383
65sub
65sub's Avatar
Thanks Lowers. The body is being welded solid. With the narrow roof at the front I wanted the truck to be as stiff as possible.
Looking good man.
Thanks Rian I'm amazed watching your truck progress too. You're building it on the other side of the ocean from all the suppliers. It has to be quite a challenge at times.
Thanks for tuning in Scott. I spend a lot of time in the shop and have a lot of fun doing it.
Thanks Kainedog. Twin turbos could be fun.
Today we finished the last patch on the passenger side wheel tub and started on the other side
Dale
Old 12-17-2015, 11:00 PM   #384
62stepside longbox
62stepside longbox's Avatar
Nice work, what are your plans for interior?
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 12-23-2015, 09:17 PM   #385
65sub
65sub's Avatar
Thanks 62. The interior is going to be aircraft inspired. Aluminum panels, bomber seats, modified '62 dash, lots of gauges, a little bit of black leather.
We decided to fill in the space from the front of the wheel tub to the frame. We made a panel for the passenger side and welded it in place.
Dale
Old 12-23-2015, 09:31 PM   #386
65sub
65sub's Avatar
We also started working on the rear hatch sill. we cut the last of the old sill off. This showed some rust behind it so we cut some more out which showed more rust. We will have to keep cutting until we find something solid to weld to. We also made the first piece of the new sill so we could test fit it.
Dale
Old 12-23-2015, 10:03 PM   #387
Advanced Design
Advanced Design's Avatar
Coming along really well! The filler panel looks good.
Advanced Design is offline   Reply With Quote
Old 12-23-2015, 10:48 PM   #388
62stepside longbox
Stunning work just as usual
Old 12-23-2015, 11:03 PM   #389
lower50's
lower50's's Avatar
Sweet!! How much room will you have between the rear fender and the front seat?
1951 MG TD
Old 12-25-2015, 09:11 PM   #390
65sub
65sub's Avatar
MERRY CHRISTMAS EVERYONE
Thanks A.D. No one will ever see the panel when the truck is done but I'll know it's there.
Thanks 62.
Thanks Lowers. I took some measurements after Christmas dinner tonight and I figure about 23" behind the seat. Maybe just enough room for a small back seat
Dale
Old 12-29-2015, 10:31 PM   #391
65sub
65sub's Avatar
Got some more welding done in the last couple of days, We finished welding the panels at the front of the rear wheel tubs. We also patched the rusty areas at the bottom of the drivers side back corner.
Dale
Old 12-30-2015, 12:30 AM   #392
Bomp
Bomp's Avatar
Phenomenal work.
Is it me or is the drive line running over the frame?
Bomp is offline   Reply With Quote
Old 12-30-2015, 04:43 AM   #393
Grizz1963
Grizz1963's Avatar
[QUOTE=65sub;7414342]
Thank you as well.
If I were making excuses, that would be one of them, the others include being a white collar worker who has to try out scanners to figure which one fits where, and often having to redo stuff as I cannot "see" the sequences as some people can.
Still, it makes for some fun at times.
Your progress on the other hand..... Just wow !!
Old 12-30-2015, 10:18 PM   #394
65sub
65sub's Avatar
Originally Posted by Bomp View Post
Phenomenal work.
Thanks Bomp. You're right the driveshaft will go over the frame but since it doesn't move up and down as long as there is room to install it I should be ok.
Thanks Rian It sure is a lot of fun just making stuff up as we go.
Today we decided to work on the rear lower valance. So to start we drilled some bumper mounting holes. Then we finished making the two pieces ( since my bender is to short to make it in one piece) drilled the holes for spot welding. A bunch of clamps to hold everything in place and then a little welding and it's done.
Dale
Old 12-30-2015, 11:24 PM   #395
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Looking good Dale. I'm loving the sheetmetal work.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 12-31-2015, 08:09 PM   #396
65sub
65sub's Avatar
Thanks John
Today's progress we added a couple of sheetmetal corner braces on the back corners. Then we finally removed the last of the cross bracing from the back.
Dale
Old 12-31-2015, 10:25 PM   #397
Advanced Design
Good progress with getting the cross bracing out. You guys sure stay at it consistently. I have this week and my knees are pretty sore.
Old 01-01-2016, 05:30 PM   #398
Bomp
Bomp's Avatar
Always a good feeling when making progress in the right direction. Mad skillz you have.
Old 01-05-2016, 01:46 AM   #399
lower50's
lower50's's Avatar
Nice the rear body is standing by itself When you get there if you want a small seat look for one from a Jeep. My CJ rear seat is small 2 adults= real cozy.
1951 MG TD
Old 01-05-2016, 08:48 PM   #400
Jferrante
Jferrante's Avatar
Great work! - Builds like these have motivated me to learn how to weld and fabricate, need to start somewhere. Keep up the great work.
Jferrante is offline   Reply With Quote
