04-04-2012, 12:22 AM | #4126 |
1 thing at a time is progress.
Re: Project Vitamin C-10
Thanks Phillip!!
With the help of rbar he pointed me in the direction of these pics.
Alan
Philippians 2:14-16 |
04-04-2012, 10:55 PM | #4127 |
Drove it to work today for a 16 mile trip. It did pretty good. The temp gauge was between 3/4 and 7/8 of running hot. I got to work and the used a lazer temp gun and the hottest spot I found was 220 most spots were around 200. The upper rad hose was 190 i think. I'm thinking of cutting some reliefs in the fan shroud so when it's moving down the road more air is able to move thru the rad. I've heard that when an electric fan is on going down the road it actualy inhibits cooling.
It was blowing a little antifreeze out, but not much. It never boiled over. I got the hood on and tried a little too lined it up. The hinges were really stiff from sand blasting, but with some PB Blaster they freed up a bunch. It's still sticking up in the back and trying to get it down. I don't have a latch in it right now. The latch might help. I'm wondering if the cowl seal is keeping it up. It's spongy in the back. If I push the hood down in the back and let go it comes back up. I used my GPS and it is reading 10 MPH faster.
Alan
04-04-2012, 11:00 PM | #4128 |
Looks and sounds good Alan...
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
04-04-2012, 11:12 PM | #4129 |
Coming together nice. Love the sound
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
04-05-2012, 09:47 PM | #4130 | |
I spent 2 hours measuring 2 times and drilling once in the right door and fender. Then touched upthe holes and installed the fender trim. Can't install the door trim until I paint the silver. Installed the hood latch and got it opening and closing. The back of the hood is still up some. I taped down the cowl seal and it helped some.
Alan
04-05-2012, 09:47 PM | #4131 |
1961 crewcab
alan, are you going to have to pull the bed off to paint the silver? gm painted the stripe pretty far in on the back of the cab..
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
04-05-2012, 09:53 PM | #4132 |
1961 crewcab
hood looks good, are you going to paint the inside of the vent and the vertical bar satin black like the factory did? IMO that is the best look on a gmc hood..
04-05-2012, 09:55 PM | #4133 |
Looks killer Alan!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
04-05-2012, 11:16 PM | #4134 | ||
Thanks man!
Alan
04-06-2012, 12:36 PM | #4135 |
Congratulations Alan,
The truck looks amazing! Sorry if you've already addressed this somewhere in your build thread, but I've found out that you need either a nos or properly calibrated temperature sending unit that matches your older gauges to get them to read correctly. I incorrectly thought that my truck was overheating last summer with the a/c on, but it turns out that the sending unit from Napa doesn't have the correct calibration for older vehicles. As soon as the vehicle gets to operating temperature, the gauge would spike to hot. I'm not sure how this all works with your Impala gauges, but I figured I'd let you know what i learned. I purchased a new sending unit from Lectric Limited and it seems to work great now. |
04-06-2012, 02:42 PM | #4136 | |
Getting a voltage regulator to accomodate this is more than I can wrap my head around, which is why I am just going to to with all new guages and set the truck up for 12v all around.
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
04-06-2012, 07:35 PM | #4137 |
also on a new motor it is going to run hot because everything is tight. my truck ran about 200 for a good while untill things got broke in. now stays about 190
04-06-2012, 07:49 PM | #4138 |
One day...
Dude that thing is sweet, you did a very good job on it!
04-06-2012, 09:43 PM | #4139 | |||
Thanks Scott, I appreciate that. Today I was able to drill the other side and it only took an hour since I had the lay out figured out. So now I'm ready to paint the silver. Had a little issue with the finish on the mouldings. Discussion link i snapped the turn signals in, but not wired. Took it outside for a few more shots.
Alan
04-06-2012, 10:46 PM | #4140 |
SSN 706
The trim is really going to tie everything together. Great job.
04-07-2012, 10:49 AM | #4141 |
Daring to be Different
Sweeeeet.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
04-07-2012, 11:53 AM | #4142 |
Wow, that really looks great.
At 200 mph you have no friends. |
04-07-2012, 01:47 PM | #4143 |
04-07-2012, 07:57 PM | #4144 |
man am i ever jealous, that is nice, when you get the silver and the trim on it i would take a vacation, maybe the rod run in pigeon forge this weekend and drive it with a great big grin on my face. oh yeah if you cant get anyone to go with you stop by and get me i am on the way
my 65 fleetside build http://67-72chevytrucks.com/vboard/s...d.php?t=442370 big back glass conversion http://67-72chevytrucks.com/vboard/s...dow+conversion |
04-09-2012, 12:13 PM | #4145 |
Your truck looks awesome! The trim is definitely going to tie it all together and look great!
04-09-2012, 09:44 PM | #4146 | ||
Thanks guys!! Quote:
Got the silver done today. Mar-K also called me and said they hand picked some mouldings and sent them out today.
Alan
04-09-2012, 10:12 PM | #4147 |
Rollin' Old Skool
looks awesome, Alan...i knew that would break up the orange nicely...now when you get those side trim pieces installed, you'll be set!
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
04-09-2012, 10:18 PM | #4148 |
Alan, Your truck looks GREAT!! I love the stance of it. I know you probably covered it in your thread somewhere already but what did you do to the suspension to get that stance? I put 4 inch drop springs in the back of mine and ordered 3 inch drop springs for the front.
69 chevelle malibu, 64 C-10 shortbed |
04-09-2012, 10:34 PM | #4149 |
Totally cool & sweet ride
04-10-2012, 01:49 AM | #4150 |
I just bought a 60 swb stepside and got on this site for some ideas. I just spent the past 4 nites reading every post on your thread. You made an absolutely breathtaking truck. I can't wait to get cutting and building my truck. Thanks for the inspiration.
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
