Old 01-06-2016, 10:50 PM   #401
65sub
65sub's Avatar
Re: My suburban's Twisted Little Sister
Originally Posted by Advanced Design View Post
Good progress with getting the cross bracing out. You guys sure stay at it consistently. I have this week and my knees are pretty sore.
Thanks A.D. We were getting kinda tired of climbing over the bracing so its nice to get them out. I think a little pain is the price we all pay for our trucks.
Originally Posted by Bomp View Post
Always a good feeling when making progress in the right direction. Mad skillz you have.
Thanks Bomp
Originally Posted by lower50's View Post
Nice the rear body is standing by itself When you get there if you want a small seat look for one from a Jeep. My CJ rear seat is small 2 adults= real cozy.
Thanks for the idea Lowers I'll check a Jeep next chance I get. Seats are a ways off but it won't hurt to look.
Originally Posted by Jferrante View Post
Great work! - Builds like these have motivated me to learn how to weld and fabricate, need to start somewhere. Keep up the great work.
Thanks J Remember good welding takes practice and patience .
In the last couple of days we got the sheetmetal for the corners behind the rear wheel tubs fabricated and mostly welded in
Dale
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 01-07-2016, 09:16 PM   #402
65sub
65sub's Avatar
I got the prototype door hinge version 2.0 assembled today. This one is smaller and tipped slightly to align the pivot points. I also made a matching nut plate that will be welded into the center roof
Dale
Old 01-13-2016, 10:07 PM   #403
65sub
65sub's Avatar
Monday and Tuesday we built some mounts and links for the rear sway bar. For the mounts we modified the originals. To mount the links we used the original transverse leaf spring mount and made brackets to hold the bushings. Then we made the links with threaded rod and some 1/8 by 1 steel.
Dale
Old 01-13-2016, 10:37 PM   #404
65sub
65sub's Avatar
I have been looking for a gas tank to fit in the back of the truck but didn't find any that filled the available space. So today we started to make one to fit. The space for the tank is 38" X 15 X 10. We started with a sheet of stainless and bent a large box 37" X 14.5" X 9". Put a few beads in it to stiffen it a bit. Then we made two baffles and two end panels. Tomorrow we will hopefully start welding.
Dale
Old 01-13-2016, 10:59 PM   #405
lower50's
lower50's's Avatar
That will be a nice tank. What gauge stainless did you use?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-14-2016, 11:41 AM   #406
AJCK87
Nice work! Coming along great
AJCK87 is offline   Reply With Quote
Old 01-14-2016, 02:22 PM   #407
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Looks like you're having lots of fun! I'm curious to see how you close up the end panels.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 01-14-2016, 10:30 PM   #408
65sub
65sub's Avatar
Thanks Lowers. We're using 18 gauge stainless. Working with it is tough enough I wouldn't want any thing thicker.
Thanks AJ We getting there a bit at a time.
Hi John Any day in the shop is a good day. The end panels will just be butt welded all around the edge.
Today we got the baffles tacked in and part of the seam welded
Dale
Old 01-14-2016, 10:59 PM   #409
IWanna49
IWanna49's Avatar
Love it! Don't have it, can't find it, MAKE it!!!
-Greg
'51 3600/s10 swap- in progress
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=641511
IWanna49 is offline   Reply With Quote
Old 01-14-2016, 11:38 PM   #410
62stepside longbox
62stepside longbox's Avatar
Very nice work. Love to see awesome fabrication like this. What some see as just metal others see as an art.
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 01-18-2016, 11:25 AM   #411
lower50's
lower50's's Avatar
Nice detail on the tank. I used 16ga for my stainless tank but had it bent up for me. How many liter will the tank be?
1951 MG TD
Old 01-19-2016, 06:32 PM   #412
winslowgoodwin
very nice work!
winslowgoodwin is offline   Reply With Quote
Old 01-20-2016, 12:10 AM   #413
Bomp
Bomp's Avatar
Dropped in, got caught up to date.
Yup, Blown away
Always get excited when I see your thread at the top.
Bomp is offline   Reply With Quote
Old 01-23-2016, 08:48 PM   #414
65sub
65sub's Avatar
Thanks Greg. Nothing on this truck just fits so everything we do takes so cutting and welding.
Thanks Nik. I don't know if it's art but it sure is fun to build.
Thanks Lowers. My tank is 76.5 litres or for our US friends about 20 gallons
Originally Posted by winslowgoodwin View Post
very nice work!
Thanks Winslow
Yup, Blown away
Glad you got caught up I'm just trying to inspire you to go out and do some welding on Steiner so we can all get a update
We got a bit more done on the tank. We welded in the end panels. Then we used a hole saw to cut three holes in the top. 1 for the filler neck, 1 for the sending unit and one for the in tank fuel pump. Then we drilled the mounting holes and tacked the split rings inside the tank.
Dale
Old 01-23-2016, 09:25 PM   #415
Advanced Design
Advanced Design's Avatar
Nice work on the tank!
Advanced Design is offline   Reply With Quote
Old 01-23-2016, 10:39 PM   #416
Bomp
Bomp's Avatar
Diggin' that custom tank and all the other things you take on.
Old 01-25-2016, 10:40 PM   #417
65sub
65sub's Avatar
Thanks Doug.
Thanks Greg
Today we got all the pieces ready to go in the tank. Fuel pump, filler with cap and the sending unit. Then we made the first panel of the floor above the fuel tank.
Dale
Old 01-25-2016, 11:40 PM   #418
62stepside longbox
lookin good
Old 01-28-2016, 09:53 PM   #419
65sub
65sub's Avatar
lookin good
Thanks Nik
We did a test fit of the gas tank today. After some trimming of the sway bar bracket it's tight but it fits. We pulled the tank back out and spot welded the panel above the front of the tank. The straps that will hold the tank in will mount to this panel. We also spot welded one of the side panels on.
Dale
Old 01-29-2016, 09:21 PM   #420
piratexpress1369a
piratexpress1369a's Avatar
just read your build .. rhis is AWESOME ...i would love to see this up close and trhe speed you are building this blows my mine ....
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 01-29-2016, 10:16 PM   #421
Advanced Design
That tank fits like it was made for that space...oh wait, it was. Great work 65!
Did you make the panel that goes to the front (toward vehicle front) of the tank?
Old 02-01-2016, 10:25 PM   #422
65sub
65sub's Avatar
Thanks Pirate. If you're ever in the area let me know and maybe we can get together.
Space is definitely at a premium at the back so making a tank was the best option.
We did make that panel. We just ran a bead around it to stiffen it a bit
We started today making the panels that are beside the back of the tank. Then we spot welded them in. Next made the panel that goes above the gas tank. This panel will go in after the back panel. The last picture is one of the back panels
Dale
Old 02-01-2016, 10:45 PM   #423
62stepside longbox
Lookin good Dale
Old 02-02-2016, 06:40 PM   #424
lower50's
lower50's's Avatar
I love the panels you made. Looks like you bought them Will the filler be outside above the bumper?
1951 MG TD
Old 02-03-2016, 10:43 PM   #425
65sub
65sub's Avatar
Lookin good Dale
Thanks Nik
Thanks Lower. These panels will never be seen but it's good practice making them. Yes the filler will be above the bumper behind the licence plate.
We worked on the rear sheetmetal some more today. We clamped the rear panels in place. Then we trimmed the floor panel and made some spacer blocks out of plastic. We screwed the spacers to the bottom of the floor panel and then clamped the floor in place.
Dale
