Old 01-02-2013, 11:44 AM   #426
fastcam1
Young gun
fastcam1's Avatar
Re: Slosh Tubz new company project "Square Peg" frame laying 1987 GMC Jimmy
Originally Posted by 67cheby View Post
How about a shot of my ghetto fabulous mock up rear axle and a teaser shot of the stance ! I also had to trim out a little more of the rear floor and remove a set of body mounts to make room for the notch
man this thing is gonna look sweet fully laid out!!!!!!!!!
67 SWB Custom "JANE"
http://67-72chevytrucks.com/vboard/s...d.php?t=554024
Northwest C10's
http://www.facebook.com/#!/groups/Norhtwestc10s/
Cameron sparks
fastcam1 is offline   Reply With Quote
Old 01-02-2013, 11:55 AM   #427
67cheby
67cheby
67cheby's Avatar
Page roll....^$%#@$%#@& , Frame reinforcement idea (w/steel, LOL) and layed out mock up
67cheby is offline   Reply With Quote
Old 01-02-2013, 12:29 PM   #428
gringoloco
A guy with a truck
gringoloco's Avatar
My $.02 on the 2x4. Use thick wall tubing and weld as much as possible. Plenty of plug welds on the tops and sides as well as the seams. Same goes for the notches- I like to overbuild these types of things...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-02-2013, 12:30 PM   #429
thor
thor's Avatar
I'm liking the frame mod idea (though I keep hearing "custom frame" in my head).
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 01-02-2013, 12:38 PM   #430
fastcam1
Young gun
fastcam1's Avatar
X2 better safe than sorry
Northwest C10's
Cameron sparks
Old 01-02-2013, 12:43 PM   #431
67cheby
67cheby
67cheby's Avatar
[quote=gringoloco;5791054]My $.02 on the 2x4. Use thick wall tubing and weld as much as possible. Plenty of plug welds on the tops and sides as well as the seams. Same goes for the notches- I like to overbuild these types of things...[/QU
What do you think for thickness ? it will be plug welded and welded solid on the top and bottom of the frame from front to back , for sure !
LOL, if i had a frame table and alot of extra time i might just do that ....but i dont !
exactly ! i am a BIG OVERKILL person myself, my friend that builds rock crawlers thinks i dont even need to put the 2x4 in, he says just cut it off and plate the bottom and add a few gussets.....but i think this is the best idea ? but i am open for other ideas also !
Old 01-02-2013, 01:20 PM   #432
N2TRUX
Happy to be here
N2TRUX's Avatar
What your considering for the frame is common for a "stock floor" body drop with a Z'ed frame.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-02-2013, 01:29 PM   #433
67cheby
67cheby
67cheby's Avatar
Do you see any issues in doing it this way ?
Old 01-02-2013, 01:49 PM   #434
mooseknuckles
mooseknuckles's Avatar
is that a precut or econo stud?.....I would def use pressure treated instead!....lol.
mooseknuckles is offline   Reply With Quote
Old 01-02-2013, 01:51 PM   #435
67cheby
67cheby
67cheby's Avatar
LOL....oh no the pressure treated ones are way to expensive !
Old 01-02-2013, 03:23 PM   #436
Oklahoma_k5
Those frames flexed like crazy stock so just about anything will make it more rigid. The stock frame was about 10 gauge metal so I would be comfortable with at least 10 gauge tubing and I like the idea of plug welding it in quite a few places and if you can add a cross member or two that will certainly help out.
I fully boxed and added three 2 1/2 inch tubing cross members to my K5 and now the suspension flexes not the frame.
Remember the dimensions of a wood 2x4 and 2x4 box tubing are not the same. Don't let that mess you up in planning where to cut. That is one of those things that I manage to forget about when the plasma torch starts cutting.
Oklahoma_k5 is offline   Reply With Quote
Old 01-02-2013, 03:28 PM   #437
Oklahoma_k5
One tool I use when working on frames is a laser level that has projects a vertical and horizontal beam at the same time. Requires the body out of the way but with a bunch of measuring i can be sure the frame is level and straight as well as square.
Old 01-02-2013, 03:31 PM   #438
67cheby
67cheby
67cheby's Avatar
any pictures of yours?
Old 01-02-2013, 04:05 PM   #439
aggie91
I'm just glad to be here!
aggie91's Avatar
I think that the tube wall should be 3/16" thick, the stock frame rails are about 0.156" (not 100% sure, but thicker than 10ga) thick which is a little thicker than 10ga(0.135").
I would really consider doing a full 2x4 tube frame rail front to back. The amount of work/time you are going to put into modifying the stock frame, you would probably be ahead of the game with 2x4 rails. You could make them the same width at the front as the stock frame so the Scott's IFS would still work for you. I might be a little far from you, but I might could get you a frame table to use. I will check tonight and see if it is available, I know the project that was next for it was put on hold...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-02-2013, 04:08 PM   #440
67cheby
67cheby
67cheby's Avatar
here is what i want to do with the rear notch, any input on what guage steel to use for this ? This should be much stronger then your cut and butt typical square tubing step notch correct ?
Old 01-02-2013, 05:07 PM   #441
jlsanborn
jlsanborn's Avatar
Looks stout, but I don't really see the need for the honeycomb innards. Maybe a couple just to help get it tacked up. If you'll be attaching things to this area of the frame, then you might be able to incorporate some added strength in those areas.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 01-02-2013, 05:22 PM   #442
67cheby
67cheby
67cheby's Avatar
i agree a couple maybe just to keep the spacing right !
Old 01-02-2013, 06:12 PM   #443
LEEVON
LEEVON's Avatar
Mike, you need any parts from this truck? http://springfield.craigslist.org/pts/3492624912.html
I'm thinking about going to look at it Saturday. The tailgate band looks cherry in the pic.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-02-2013, 06:28 PM   #444
67cheby
67cheby
67cheby's Avatar
WOW, how funny I could use the solid side glasses and the rear glass if it isnt scratched ana a decent dash pad if it has one ?
Old 01-02-2013, 06:45 PM   #445
LEEVON
LEEVON's Avatar
My guess is the dash pad is toast, the guy said the interior was roached because the PO disassembled the drivetrain and put it in the seats. Nice. He has another Blazer too.
You mean side glass for the fiberglass top, not the doors right? I think I could remove those, the rear glass will probably have to come with with me and the tailgate though. I'll probably try and snag the emblems too.
Old 01-02-2013, 06:52 PM   #446
67cheby
67cheby
67cheby's Avatar
yes the top side and rear glass, i am sure the rear glass would have to come with the gate
Old 01-02-2013, 06:57 PM   #447
gringoloco
A guy with a truck
gringoloco's Avatar
Any reason for the rounded notch, other than looks? I like it, but it seems like a bunch of fab work when an 8-piece step notch kit is pretty cheap. Will the notch be exposed? 3/16" thickness for the tubing and plate for the notch as well.
-Chris
Old 01-02-2013, 07:00 PM   #448
67cheby
67cheby
67cheby's Avatar
the only reason is that i wanted solid side pieces because i thought that it would be stronger in case i end up pulling Cloud 9 with it ....as for the round part just looks, and it wont be exposed .
Old 01-02-2013, 07:09 PM   #449
watahyahknow
watahyahknow's Avatar
i think you can do the spacing with a little piece of 4 or bigger inch diameter thin wall exaust pipe as whell its eazier to cut those square with a pipecutter than the plate material , dril a hole where you put the pipe so the wall of the pipe is visible and put a plugweld in to keep it in place , it will be eazier to run wiring though the frame as whell with the pipes nothing to get stuck behind or scrape
the honeycomb structure youre showing would be a lot stronger if you connected the pieces to form triangles butted against eachother but unless you made the structure out of realy thin sheetmetal i dont think its needed aspecially if you weld it to the floor of the body too
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 01-02-2013, 08:56 PM   #450
jtp67-72
jtp67-72's Avatar
Check these guys...lots of options here..reasonable prices for the work saved.....Yeah I'm on the team and lookin'........lol..............jim
http://www.welderseries.com/blog/onl.../frame-curves/
or these....
http://stores.checkeredracing.com/Detail.bok?no=37
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791
jtp67-72 is offline   Reply With Quote
